Inuke NU6000DSP Fan Replace Failed (Shutdown) Help Wanted - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 3 Post By johnson636
post #1 of 25 Old 10-22-2018, 03:43 PM - Thread Starter
Quoted: 44 Post(s)
Liked: 8
Hello All,
I wanted to do the Fan Replacement in my Inuke 6000 and after use the fan recomended in different post here my Inuke still shutdown.
The tried a couple fan from other member recomendations as below:
#1 Noctua NF-A8 FLX Premium : With this one my Inuke shutdown at -50 in volume
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
#2 Then I tried BestBuy Fan as someone said was good in his Inuke, this one shut down it couple minutes with -60 as volume
#3 I installed this one by recomendations Vantec Stealth SF8025L, with this one shutdown at -25 volume
Please Note: If I put back the original fans my inuke didn't shutdown anymore...
Any recommendations for fan to try?
Thanks in advance
Jose
jabe00 is offline
post #2 of 25 Old 10-22-2018, 06:47 PM
rhodesj's Avatar
Quoted: 1010 Post(s)
Liked: 600
Originally Posted by jabe00 View Post
Hello All,
Thanks in advance
Jose
I'd look for something rated over 35 CFM and/or 3000 RPM.
Part of the issue with the stock fans was that they had a lot of mechanical noise. You don't necessarily need an ultra-low-speed fan to have an improvement.
rhodesj is offline
post #3 of 25 Old 10-22-2018, 07:06 PM
johnson636's Avatar
Quoted: 1235 Post(s)
Liked: 716
Yeah, the originals.
Augerhandle, K9woofer and bebb like this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #4 of 25 Old 10-22-2018, 07:44 PM
DaleNixon's Avatar
Quoted: 202 Post(s)
Liked: 115
I have some very quiet aftermarket fans in both my inuke 3000 and 6000. One set is Antec the other some no-names. My amps have never shut down. Did you keep those cardboard deflectors in place that aim the air towards the board?
DaleNixon is online now
post #5 of 25 Old 10-22-2018, 08:15 PM
Nalleh's Avatar
Quoted: 2573 Post(s)
Liked: 3458
Do the fans start when amp is turned on?
Dual Atmos Receivers - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 6xSI18" - 12xJBL 12" w/6xSLAPS M12 downfiring VNF - 3x2 stacked Crowson MA - 4xBK-LFE - 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XBox OneX - Apple TV4K - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873.
Nalleh’s HT
Nalleh is offline
post #6 of 25 Old 10-22-2018, 08:36 PM - Thread Starter
Quoted: 44 Post(s)
Liked: 8
Thanks, I'll try to see what I can get with those references.
Sent from my SM-N950U using Tapatalk
jabe00 is offline
post #7 of 25 Old 10-22-2018, 08:36 PM - Thread Starter
Quoted: 44 Post(s)
Liked: 8
That's the ones I'm trying to change because of the noise.
jabe00 is offline
post #8 of 25 Old 10-22-2018, 08:39 PM - Thread Starter
Quoted: 44 Post(s)
Liked: 8
Cardboard deflectors? What do you mean, attached is the picture from inside my Inuke, so there is not any cardboard, weird.
jabe00 is offline
post #9 of 25 Old 10-22-2018, 08:41 PM - Thread Starter
Quoted: 44 Post(s)
Liked: 8
Yes, they turn on as soon as I turn on the amp.
jabe00 is offline
post #10 of 25 Old 10-22-2018, 08:48 PM
CrusherW9's Avatar
Quoted: 213 Post(s)
Liked: 127
There seems to be different versions of iNUKEs. I believe the older ones have the fan ducts to direct air over the board.
"Becoming educated is more than just acquiring knowledge. It involves the ability to see the world in ways never before conceived."
CrusherW9 is offline
post #11 of 25 Old 10-22-2018, 08:53 PM - Thread Starter
Quoted: 44 Post(s)
Liked: 8
Yes, maybe
jabe00 is offline
post #12 of 25 Old 10-22-2018, 09:20 PM
Nalleh's Avatar
Liked: 3458
Then that makes no sense. I have 5 Nu6K’s all with Notcua’s and none of them has ever shutdown, and i run them hard. The fans on my 2 Nu6K DSP’s don’t even start until 5-10 minutes after turn on.
What load do you have on each channel?
Or does it shutdown even with no speakers connected?
Nalleh’s HT
Nalleh is offline
post #13 of 25 Old 10-22-2018, 09:35 PM - Thread Starter
Quoted: 44 Post(s)
Liked: 8
I have two UM18-22
jabe00 is offline
post #14 of 25 Old 10-22-2018, 10:42 PM
Quoted: 1012 Post(s)
Liked: 1261
If the inukes are anything like the ep4000 the stock factory fans have a pretty high static pressure rating, which the after market "quiet" fans can't match.
Sent from my SM-N920V using Tapatalk
Pradeep2 is offline
post #15 of 25 Old 10-22-2018, 11:23 PM
Augerhandle's Avatar
Quoted: 1252 Post(s)
Liked: 1255
The iNuke fans use sleeve bearings, which are louder at high speeds than ball bearings. Try to match the specs with a replacement that uses ball bearings.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #16 of 25 Old 10-23-2018, 02:41 AM
johnson636's Avatar
Liked: 716
I very much understand what you're trying to do, but it seems as if you're willing to wreck your amp in the process.
post #17 of 25 Old 10-23-2018, 04:33 AM
ttamez's Avatar
there's another thread by user "cuballs2" on here (can't post link, thread title "Inuke nu6000DSP fan direction results") where he did some tests and determined it runs a little cooler if you reverse the fans to pull air out. He had power cycles with the Noctua fans in the default blowing position. It's worth a shot. Also you didn't really mention where you have your amp. I'm guessing not a rack since you're annoyed enough to replace the fans. Is it in an "entertainment center", or on top of/below other equipment?
ttamez is offline
post #18 of 25 Old 10-23-2018, 06:07 AM
EndersShadow's Avatar
Quoted: 1254 Post(s)
Liked: 1525
What direction are the fans blowing? By default the inukes want the fan to blow air back to front. It would be easy to install them like normal PC fans to exhaust air, which is incorrect. Also did you install any of the Noctua low noise extensions as those will further reduce the speed of the fan, which is not something I'd recommend.
As mentioned look at the spec's of the stock fan and look at both the CFM AND the mmH2O specs and try to match as close as you can with whatever replacement you use.
In regards to the EP4000 comment earlier, I modded my EP4000 to use a Noctua fan and its been running fine for the last 3 months or so....
I also know quite a few folks using the Notcua fans in the 3000DSP and 6000DSP.
And are you sure the iNuke is shutting down due to heat and not some other signal related issue?
My Setup | Custom MiniDSP Build | FS: If its For Sale, find it all (here)
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #19 of 25 Old 10-23-2018, 06:52 AM
johnson636's Avatar
Liked: 716
I believe he stated the amp doesn't shut down if the original fans are reinstalled.
post #20 of 25 Old 10-23-2018, 07:42 AM
DaleNixon's Avatar
Quoted: 202 Post(s)
Liked: 115
Actually my inuke 6000 is the same as yours now that I double-checked. It was my single-fanned inuke 3000 with the deflector/duct. That one is from 2014.
_________________________________________________
Denon AVR-X4200W / Crown XLI 2500
7.4.4 Klipsch Ref. ii & In-Ceiling Atmos / Titan-615LX center
NU3000DSP - 2 SI HT18 D4's / NU6000DSP - 2 Ultimax 18"s
BenQ W1070 / 120" AT screen / Volt-10LX Atmos build
post #21 of 25 Old 10-23-2018, 08:53 AM - Thread Starter
Quoted: 44 Post(s)
Liked: 8
I'll try reversing the fan's directions, I'll post the results.
They are blowing air inside, I double checked that when iinstalled.
That's correct, the amp doesn't shutter m shut down with the originals iinstalled.
jabe00 is offline
post #22 of 25 Old 10-23-2018, 09:01 AM - Thread Starter
Quoted: 44 Post(s)
Liked: 8
I have this
https://www.amazon.com/dp/B01LW1Q429..._3q0ZBbZ6693E4
on top of my Marantz receiver, I'll remove the top cover and I'll put this on top of the inuke to try to cooler and also add this can measure the temperature maybe I can see how hot it get before shut down.
jabe00 is offline
post #23 of 25 Old 10-23-2018, 09:37 AM - Thread Starter
Quoted: 44 Post(s)
Liked: 8
I'll try first reversing the air flow from the fans, I'll let you know the results
jabe00 is offline
post #24 of 25 Old 10-23-2018, 09:44 AM - Thread Starter
Quoted: 44 Post(s)
Liked: 8
Hi,
The inuke is in a custom made shelf or something like that, attached is a picture
jabe00 is offline
post #25 of 25 Old 10-24-2018, 09:56 PM
idex's Avatar
Quoted: 21 Post(s)
I reversed the fans and use 120s with adaptors
https://www.avsforum.com/forum/showt...php?p=44724305
idex is online now
