how to use REW to measure available sub headroom? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By michael hurd
post #1 of 7 Old 10-23-2018, 05:33 PM - Thread Starter
sotwell's Avatar
Quoted: 220 Post(s)
Liked: 55
I am just getting comfortable with REW. Is there a simple way to use my mic and REW to measure how loud i can run my subs without clipping or distortion? subs are marty cubes with si18s and a crown 2502 amp
sotwell is offline
post #2 of 7 Old 10-23-2018, 05:45 PM
michael hurd's Avatar
Quoted: 637 Post(s)
Liked: 686
If you have gain structure problems, you could be clipping prematurely, or even have not enough voltage drive to get full output of the amplifier.
Depending on the microphone, you may have enough spl to drive it into non-linear operation. The room can also contribute to measured distortion spectra in REW, if you have rattles and other noises.
So in short, it's a bit hard to figure out what you have if you have any of those other issues.
Ask your doctor if DIY is right for you. Side effects of DIY may include anxiety, elevated blood pressure, lightheadedness, rapid heartbeat, skeletal muscle flaccidity, euphoria, psychological dependence, insomnia, confusion, blurred vision, impulsivity, uncontrolled or repeated movements.
michael hurd is offline
post #3 of 7 Old 10-23-2018, 05:48 PM - Thread Starter
sotwell's Avatar
Quoted: 220 Post(s)
Liked: 55
sorry, maybe i was not clear. I do not believe that i am clipping, but how do i know if i am? after eq, i run my subs about 8db hot, is there a way to tell that i could clip at this level
sotwell is offline
post #4 of 7 Old 10-23-2018, 06:13 PM
johnson636's Avatar
Quoted: 1235 Post(s)
Liked: 716
The clipping LED on your amp will tell you if you're clipping.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #5 of 7 Old 10-23-2018, 06:16 PM
Quoted: 637 Post(s)
Liked: 686
You could be clipping the output of the AVR, or clipping the amplifier. If you have redirected bass, you are asking the subwoofers to reproduce >121 dB of bass, if you drive the system to reference volume level during a movie, and every gain stage is correct. If 8 dB hot, now the subwoofers will need to reproduce close to ~ 130 dB at reference.
Room gain is not factored in, a large lossy main floor room that is open to the rest of the house will behave far differently than a basement room that has two concrete walls and concrete floor.
If you know your maximum spl, then you can calculate back to figure out what you need at your subwoofers.
LTD02 likes this.
post #6 of 7 Old 10-23-2018, 07:06 PM
BassThatHz's Avatar
Quoted: 3777 Post(s)
Liked: 4297
The UMIK-1 maxes out at 130db peak from my experience with it.
It starts distorting around 120db continuous power / sinewave etc.
You have to modify the UMIK-1 to even reach +115db.
How to do that, can be seen in my thread on the topic:
https://www.avsforum.com/forum/155-d...-umik-1-a.html
If you truly want a no-limit SPL meter, then you'll have to buy an SPL Lab or Term Lab, solid-state sensor.
https://shop.termpro.com/products/te...-sensor-system
http://spllabusa.com/us/products/bas...ass-meter.html
Those max-out north of 180db.
True.
For the first one, just disconnect the driver. You should be able to clip the amp, ensuring you have sufficient voltage drive, then just back down the MV a notch and consider that your max-safe loudness.
You can only detect AVR clipping with an oscope (or voltage divider and a soundcard).
BassThatHz is offline
post #7 of 7 Old 10-25-2018, 03:10 AM
LTD02's Avatar
Quoted: 2954 Post(s)
Liked: 3685
Listen. It's All Good.
LTD02 is offline
