Help porting ultra 5400 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By johnson636
post #1 of 8 Old 10-31-2018, 05:09 PM - Thread Starter
Quoted: 130 Post(s)
So I'm going have someone build me a ported box tuned to 15hz for 1 of my lms ultras to see how much difference in output before I do 2 boxes right away. But I dont know how to figure out how to build the box to the subwoofer specs.
I cant find any ultras near me to add to (id love 2 more 5400s) and I'm not sure on what sub to incorporate with the LMS ultras, so going to ported.
Length can be between 19-22", width 22" and whatever height needs to be.
Both ultras are on a fp14k and minidsp. If anyone can help me out I'd appreciate it.
The builder is a professional box builder for car audio and is a judge for midwest car audio competitions. Unless you think if I can tell him i want it tuned to 15hz and the 2 max dimensions I'd get a good box? Eek! I just want to get the box right
MagnumMafia05 is offline
post #2 of 8 Old 10-31-2018, 05:27 PM
johnson636's Avatar
Quoted: 1114 Post(s)
Liked: 651
If you have to figure out port dimensions for the "Professional Box Builder" then I'd hire another box builder
SpinMonster and Trimlock like this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #3 of 8 Old 10-31-2018, 05:40 PM - Thread Starter
Quoted: 130 Post(s)
I'm sure he can do that himself.i havent even asked him about making the box yet just about how much for a sealed box for a SI24. How much power do I say I'm putting to the 5400 using the fp14k?
post #4 of 8 Old 10-31-2018, 05:44 PM
johnson636's Avatar
Liked: 651
Which fp14 do you have? Sanway, Smiths, other?
post #5 of 8 Old 10-31-2018, 05:48 PM - Thread Starter
Quoted: 130 Post(s)
Sanway
post #6 of 8 Old 10-31-2018, 05:55 PM
johnson636's Avatar
Liked: 651
The older ones sustain like 2800 or so, newer ones 3800. The BT enhanced will put out 4800 for a little under 2 seconds then about 3800.
4.4ohms bridged sanway fp14000
Hz Vpp burst Burst Watts
5 504 7214
10 584 9686
20 624 11058
30 632 11344
40 680 13132
80 728 15052
Credit goes to @notnyt
post #7 of 8 Old 10-31-2018, 06:16 PM - Thread Starter
Quoted: 130 Post(s)
I'm just going tell him 2500 watts. Thanks.
post #8 of 8 Old 10-31-2018, 08:02 PM
MKtheater's Avatar
Quoted: 2308 Post(s)
Liked: 2242
Just look up Notnyt’s thread for porting his dual 5400s. Cut your box in half.
Audio Design Associates/Outlaw
Speakerpower SP1-4000
subs-Re audio XXX 18 IB(LT).
DIY speakers-mktheater-S10/S12s
MKtheater is online now
