Fusion-15 Sentinel Build @ ~50Hz Tune - AVS Forum | Home Theater Discussions And Reviews
 24Likes
post #1 of 38 Old 11-08-2018, 09:11 PM - Thread Starter
Witchboard's Avatar
Quoted: 190 Post(s)
Liked: 188
Now that the Sentinels are on close out at DIY Sound Group, this thread may not be as relevant as it used to be, but thought I would document my progress nonetheless.
I was wanting a LCR to produce enough mid-bass where I would hopefully not have to build MBMs. Erich didn't have enough flat packs for 3 kits so I'm going to be building my own boxes.
I'm going to be building boxes ~5.5 cubic feet and tuned to around 50Hz. I'll still be using Erich's sexy CNC cut front baffles, but I'll be building the boxes to 24" deep and have to route out the ports. A big shout out to @mtg90 for all his help with the tune.
ID:	2479856   Click image for larger version
Rumble & Frenzy - My Mini-Marty Build
Strike Eagles - My Fusion-15 Sentinel Build
Witchboard is offline
post #2 of 38 Old 11-08-2018, 09:12 PM - Thread Starter
Witchboard's Avatar
Quoted: 190 Post(s)
Liked: 188
SketchUp of the cabinet.
post #3 of 38 Old 11-09-2018, 12:36 PM
asarose247's Avatar
Quoted: 1247 Post(s)
Liked: 1092
hope this works out . .
OTOH, if you are using BM then in all likelihood you'll end up setting them to "small' https://www.avsforum.com/forum/images/smilies/eek.gif
where audy sets the xo to ? > TBD
Matt was a huge help when I did mine . .
keep us posted and more pics
I really got my attention when the CD weighed more than the 15" driver . .
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is online now
post #4 of 38 Old 11-09-2018, 01:51 PM - Thread Starter
Witchboard's Avatar
Quoted: 190 Post(s)
Liked: 188
I'm with you. When I pulled those little boxes out I could have swore they were filled with lead. Also, those magnets. My tape measure was sticking to the outside of the box.
post #5 of 38 Old 11-09-2018, 02:28 PM
Samps's Avatar
Quoted: 1225 Post(s)
Liked: 904
Are you going to put those on stands? If not the waveguide will be well below ear level. You could build a taller shallower box and attach the baffle on the front.
5.5 cubes is big for a 50hz tune. It will give you a pretty big bump in that range which I'm assuming is your plan. Mine are only 3 cubes with a 50hz tune and they have a decent bump in the bass range.
Samps is offline
post #6 of 38 Old 11-09-2018, 02:38 PM - Thread Starter
Witchboard's Avatar
Quoted: 190 Post(s)
Liked: 188
My stands are going to be my subwoofers. It's likely I may have to have the speakers upside down where the waveguides are on the bottom due to the height of the subs.
post #7 of 38 Old 11-09-2018, 02:46 PM
Samps's Avatar
Liked: 904
That works. I think you'll be surprised how much bass you can get out of those 15s. Shame that design is fading away. It's not full range but plenty of bass for music.
Samps is offline
post #8 of 38 Old 11-09-2018, 07:10 PM - Thread Starter
Witchboard's Avatar
Quoted: 190 Post(s)
Liked: 188
Working on the crossover layout and wiring. I plan on installing a switch to enable/disable the optional HF padding resistor. Any suggestions to better placement or did I get something wrong?
I screwed up on the 4mH coil wiring. Uploaded corrected layout. Anybody else see any other errors?
post #9 of 38 Old 11-09-2018, 10:23 PM
raynist's Avatar
Quoted: 2127 Post(s)
Liked: 2306
I have JTR 215RT’s as my LCR and still use midbass modules. My 215’s have a ton of midbass and can give you the kick in the chest if turned up loud enough. The problem is at lower listening levels -20 to -15 the kick isn’t there because they are too far away from me (16 ft). I can put the midbass modules directly behind me and separately adjust their volume to provide that kick at lower volumes which I can’t do with my 215’s.
You May still need/prefer midbass modules depending on your room SBIR and distance from your speakers and subs.
http://www.mh-audio.nl/CancellationFreq.asp
jamiebosco likes this.
raynist is offline
post #10 of 38 Old 11-10-2018, 12:19 PM
mtg90's Avatar
Quoted: 782 Post(s)
Liked: 1613
Positive HF path from the 5.1uF cap should flow through the 2.2uF and 10 Ohm resistor and out to the HF output / 4.7 and 20 Ohm resistors. Right now you have the 2.2uF and 10Ohm resistor bypassed.
See attached image.
Name:	crossover fixed.jpg
mtg90 is online now
post #11 of 38 Old 11-11-2018, 09:08 AM - Thread Starter
Witchboard's Avatar
Quoted: 190 Post(s)
Liked: 188
Agh. Thanks @mtg90 . I fixed and reuploaded the original.
post #12 of 38 Old 11-12-2018, 08:11 PM - Thread Starter
Witchboard's Avatar
Quoted: 190 Post(s)
Liked: 188
Modeled the bracing. There's no way I can do bracing like Erich's CNC, but I used them as a template to determine where mine should go.
Also ordered the walnut veneer.
post #13 of 38 Old 11-15-2018, 06:36 PM - Thread Starter
Witchboard's Avatar
Quoted: 190 Post(s)
Liked: 188
Walnut veneer has arrived.
post #14 of 38 Old 11-25-2018, 02:48 PM - Thread Starter
Witchboard's Avatar
Quoted: 190 Post(s)
Liked: 188
MDF all cut. Crossovers are done.
I'm going to do some testing on flush mounting the HF padding resistor switch so it doesn't stick out the back.
ID:	2487306   Click image for larger version
post #15 of 38 Old 11-26-2018, 02:49 PM - Thread Starter
Witchboard's Avatar
Quoted: 190 Post(s)
Liked: 188
As far as the switch goes for the HF padding resistor, I had originally been thinking about mounting it to a plate then accessing it through a hole. What are the thoughts on just drilling a hole in the terminal cup and mounting it there? The recessed cup looks to have more room above the terminals than the regular cups but there's not a technical drawing for me to know how much room there is. There is a comment that indicated somebody put a combo Speakon jack in the same cup, so there should be enough room for a microswitch.
https://www.parts-express.com/gold-b...l-cup--260-311
post #16 of 38 Old 11-26-2018, 03:04 PM
smcmillan2's Avatar
Quoted: 905 Post(s)
Liked: 793
At 4-1/8" OD you'll have lots of room for a switch above the posts. I use 2-7/8" OD cups and could fit a small switch in them easily.
If using banana plugs however, those may get in your way. How much so would depend on how often you switch the padding on/off I suppose.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #17 of 38 Old 11-27-2018, 08:25 PM - Thread Starter
Witchboard's Avatar
Quoted: 190 Post(s)
Liked: 188
The toggle for the switch is only 3/8" long so there should be enough room. I went ahead and ordered the recessed cups. We'll see how they work out.
post #18 of 38 Old 12-07-2018, 06:53 PM - Thread Starter
Witchboard's Avatar
Quoted: 190 Post(s)
Liked: 188
Boxes cut and glued.
Working on the double bezel. Marking the center of the circle to cut out with the router for the woofer.
I think the larger cup was definitely overkill for the switch, but there will be more than plenty of room.
It's getting cold so likely work will slow down as my garage is not heated.
ID:	2493558   Click image for larger version
ID:	2493560   Click image for larger version
post #19 of 38 Old 12-08-2018, 04:57 PM - Thread Starter
Witchboard's Avatar
Quoted: 190 Post(s)
Liked: 188
Quick jig for the woofer cut out in the bezel.
Dry fitting both bezels.
First bezel glued in place.
ID:	2493988   Click image for larger version
ID:	2493994   Click image for larger version
notfastenough likes this.
post #20 of 38 Old 06-08-2019, 02:09 PM - Thread Starter
Witchboard's Avatar
Quoted: 190 Post(s)
Liked: 188
Rain is slowing down where I can move the car out of the garage and work on these a little.
Drilled and installed the microswitch in the terminal cup. This cup is way bigger than I needed, but I already bought them, so we'll make them work.
Used gasket tape on the back to seal the microswitch.
Gluing the second bezel in place.
This particular box was 1/16" shy on the bottom, so used PL to fill the gap. Gave it 30 minutes to set to where it turns into a clay consistency then scraped it off clean with the box. Will still have to do some filling.
ID:	2577710   Click image for larger version
ID:	2577712   Click image for larger version
ID:	2577714   Click image for larger version
post #21 of 38 Old 07-08-2019, 07:51 PM - Thread Starter
Witchboard's Avatar
Quoted: 190 Post(s)
Liked: 188
Got some more work done on these. Dang bearing came off my flush trim bit and cut into the side. Glad I wasn't doing something like trimming veneer.
Yay Bondo!
All the prep work for the wood is finished.
Foam installed. They are now ready for veneer. May be able to get that done this weekend. Fingers crossed.
ID:	2588924   Click image for larger version
ID:	2588926   Click image for larger version
ID:	2588928   Click image for larger version
eng-399 likes this.
post #22 of 38 Old 07-09-2019, 12:02 AM
SpinMonster's Avatar
Quoted: 506 Post(s)
Liked: 312
Bisecting chords to find the center. Someone did well in geometry.
Witchboard and notfastenough like this.
SpinMonster is online now
post #23 of 38 Old 07-11-2019, 03:29 PM
Boxozaxu's Avatar
Quoted: 512 Post(s)
Liked: 352
Yay Bondo!
Nice recover from the flush trimming mishap. Looks like you're close to testing them out. They always sound better after they break in a bit. Looking forward to the walnut veneer!
Boxozaxu is offline
post #24 of 38 Old 07-12-2019, 07:51 AM - Thread Starter
Witchboard's Avatar
Quoted: 190 Post(s)
Liked: 188
Me too, but unfortunately it won't be this weekend as I had hoped. The earliest I'll be able to work on these again is the end of the month.
post #25 of 38 Old 08-01-2019, 10:12 AM - Thread Starter
Witchboard's Avatar
Quoted: 190 Post(s)
Liked: 188
Had some time of this week and worked on the veneer.
Measuring and cutting the veneer. After measuring the sides, I took the sum and subtracted it from the total length, then divided the remainder by 4. I ended up 3/4" overhang on each piece, which is cool with me. The less I have to cut, the less of a chance I'll screw something up.
I was concerned about the backing on this particular piece as it looked like the paper was overlapped. I could feel it and it ran the entire length of the veneer. I was afraid it would show up after applying it to the box, so I put it towards the back. Ended up not being an issue.
All veneer cut.
The tools I use to apply veneer. I cut the 9" rollers in half so I have a fresh roller for each side and use disposable liners. I ended up going back to the store for a second can of contact cement. My suggestion would be to buy twice as much as you need and return what you don't use.
I taped off the front for two reasons. One, to keep the contact cement off where I'm going to paint and the second so I can see how to align the veneer through my wax paper.
I use wax paper rather than dowels. I'm not claiming this is the best method, but it's the method I use since I typically don't have much overhang on my veneer. When I did my subs, I had about an 8th of an inch overhang on each side, so I needed it as close to the surface as I could to make sure it was even. It's the method I'm comfortable with, so it's what I do.
The center wax paper is on the bottom. I push down on the veneer on another piece of wax paper to keep it from slipping then slide the center bottom piece of wax paper out then press the veneer onto the box, after that, it's not going anywhere and I can continue pulling the center out while working the veneer from the back to the front, then from the center to the edges after taking out the other two pieces of wax paper.
I use a carpet tucking tool to push my veneer. I don't use a j-roller. The carpet tool provides much more force than a j-roller can. I could use the corner of a board, but the carpet tool is more comfortable and only cost like $5 at harbor freight.
Used a flush trim router bit to cut off the access, then a single sided razor to remove the remaining paper.
Veneer is done. Just have to do some cleanup on some glue here and there.
There's a pretty substantial lip on the front, but I'm not going to tempt fate and try to fill it. I think it will blend in as soon as I shoot the front with some black paint. Hopefully I can get the veneer sprayed before this weekend is over.
ID:	2597126   Click image for larger version
ID:	2597128   Click image for larger version
ID:	2597130   Click image for larger version
ID:	2597132   Click image for larger version
ID:	2597136   Click image for larger version
ID:	2597138   Click image for larger version
ID:	2597140   Click image for larger version
ID:	2597144   Click image for larger version
ID:	2597154   Click image for larger version
post #26 of 38 Old 08-02-2019, 08:14 AM
wasser's Avatar
Quoted: 120 Post(s)
Liked: 83
Looking good! I like the wax paper and carpet tool tips too.
Fusion-15: Asian Night Sentinels
wasser is offline
post #27 of 38 Old 08-03-2019, 11:19 AM - Thread Starter
Witchboard's Avatar
Quoted: 190 Post(s)
Liked: 188
I wouldn't use the carpet tool for laminate, just veneer. It would scratch laminate like crazy I'm sure. I would stick with the j-roller for laminate. Unfortunately, it's on and off raining this weekend, so I'm not going to be able to spray anything. I have to figure out what happened with my circuit in the garage anyway. The GFCI keeps tripping. I've already unplugged everything, flipped the breaker and it's still tripping. I even replaced the GFCI receptacle and it's still tripping. I'm going to have to pull every outlet this thing is attached to and check them. Not how I planned on spending my Saturday...
post #28 of 38 Old 08-26-2019, 06:18 PM - Thread Starter
Witchboard's Avatar
Quoted: 190 Post(s)
Liked: 188
I haven't made much headway. It's either been too windy, hot or raining lately. I did get all the sides sanded and we're ready to shoot some poly, but in the meantime, I'll cover something I do that seems rather divisive on the forum. T-nuts. I use 'em. I'm not saying they are the only way or the best way, but it's the way I do it. I'm not wanting to turn this topic into another debate on the pros and cons of t-nuts. There are several topics that already exits. This is just for documentation purposes.
All the previous F-15 topics I've seen, there are tips on how to cover silver ring around the woofer. I thought instead of trying to cover it up, I'd do something a little different and actually accentuate it a bit. I've got stainless socket head cap bolts and screws to mount the woofers and SEOS waveguides. These should pop against the black paint along with that silver ring around the woofer. Will I like it once I'm done? I dunno. I can always paint them all if it doesn't look as nice as I'm thinking it will. On with the pics.
I aligned the holes the way they are to be symmetric, but I couldn't have them top, bottom and side to side as they would hit bracing. If I was screwing the driver in, this would be the best, but since I'm using t-nuts...
The bolts are 1/4" so I used a 1/4" drill bit.
Drill one and insert the bolt.
Drill another on the other side and insert the bolt. This will keep the woofer from shifting while I drill the remainder of the holes.
Once that's done, I remove the woofer and drill out the holes to the size of the t-nut for a tight fit. I then used a 1/4" bolt and a pair of washers and a ratchet to pull the t-nuts into the holes for a press fit.
So now I'm just waiting for the right time and the right weather to get these done. I may be able to work on a few of the electronics in the meantime, but I'm not so patiently waiting for this weather to be mild enough to spray outside.
ID:	2607610   Click image for larger version
ID:	2607612   Click image for larger version
ID:	2607614   Click image for larger version
ID:	2607616   Click image for larger version
post #29 of 38 Old 08-27-2019, 08:49 AM
lknhomeaudio's Avatar
Quoted: 288 Post(s)
Liked: 151
Very nice!
lknhomeaudio is offline
post #30 of 38 Old 09-04-2019, 08:23 PM - Thread Starter
Witchboard's Avatar
Quoted: 190 Post(s)
Liked: 188
Finished the poly over the weekend and paint today. Mistakes were made, but I think they turned out okay. Should be set and dried by this weekend so I can put everything together.
Here are some of the tools I use. I have two cheap harbor freight HVLP spray guns. I use one for clear and the other for color. Sher-Wood is great for sealing MDF but a bit pricey. It only comes in gallons as far as I know.
Some pics of the polyurethane.
I sprayed everything outside and then moved them into the garage to cure.
One of the many issues with spraying outside. One of the few bugs that got stuck in the paint.
I'm pretty satisfied with the line between the paint and the poly. It was more difficult than on my subs due to the rounded edge of the baffle.
They will stay in the garage and cure for this weekend where hopefully I can get them all assembled and see how glorious these sound.
ID:	2611252   Click image for larger version
ID:	2611254   Click image for larger version
ID:	2611256   Click image for larger version
ID:	2611258   Click image for larger version
ID:	2611262   Click image for larger version
ID:	2611264   Click image for larger version
ID:	2611266   Click image for larger version
