GSG Audio Design - DIY/AIY for the broadest audio community - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 186Likes
post #211 of 252 Old 07-04-2019, 03:02 PM
Red Five's Avatar
Quoted: 663 Post(s)
Liked: 419
https://shop.gsgad.com/collections/horn-subwoofers
Just posted
femi and EndersShadow like this.
Stormbreaker | Wisconsin Home Theater Meet Thread | The Devastator Index
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | Yamaha A3070 | Crown XLS 1502 | iNuke 3000 DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen
Red Five is online now
post #212 of 252 Old 07-04-2019, 04:26 PM
Kpilk's Avatar
Quoted: 85 Post(s)
Liked: 86
Originally Posted by Red Five View Post
Kevin said he was going to put this monster on the site....glad I waited to see what it looked like. Think two of them in 12x19x9 will be 'sufficient'?
Kpilk is offline
post #213 of 252 Old 07-04-2019, 04:37 PM
Jk7.2's Avatar
Quoted: 1526 Post(s)
Liked: 2744
That’s a tough call. I think 4 is the right way to go
Kpilk and corradizo like this.
Jk7.2 is offline
post #214 of 252 Old 07-04-2019, 04:37 PM
Red Five's Avatar
Quoted: 663 Post(s)
Liked: 419
Yes! Just a ported 21DS115 in 6000cuft does a good job. Kevin is building three of these for his own setup. They sound that good. He is loading SAN214.50s in his.
Kpilk and eng-399 like this.
post #215 of 252 Old 07-04-2019, 04:46 PM
Kpilk's Avatar
Quoted: 85 Post(s)
Liked: 86
Ive been going back and forth for a couple months about what direction I wanted to go. I picked up 2 B&C 21's and was going with the 21MBM then Kevin hypnotized me into the HT21's...then I hear about the "taller" HT21 which is hitting the site this weekend as well. Now the Devastator is calling my name.
Problem is it doesn't really fit my speaker wall very well. Too tall to fit under my screen (not enough room depth to go behind the screen). I run out of room for my LCR and 2 Devastators....but I like the idea of a horn.
I'm 75% music and never having heard a horn I wouldn't know what to expect. I building a LCR Maximus 12-lxe set right now to replace my Fusion 12 LR and 8 center.
Funny (pathologically sad really) is that this 'rebuild' was to just get a new center to keep up with my Fusions 12's. Once I peaked down the rabbit hole it was too late.
mcallister likes this.
Kpilk is offline
post #216 of 252 Old 07-04-2019, 04:56 PM
Red Five's Avatar
Quoted: 663 Post(s)
Liked: 419
If you are mostly music the Dev makes a lot of sense. You can set a higher HPF filter on it and then go into full music war mode. The passband on the Dev is great, no resonance somewhere that is less than ideal. Size is manageable relatively speaking
post #217 of 252 Old 07-04-2019, 05:46 PM
Kpilk's Avatar
Quoted: 85 Post(s)
Liked: 86
So do we know what these are 'tuned' to or is that not a thing with horns?
Kpilk is offline
post #218 of 252 Old 07-04-2019, 06:14 PM
Red Five's Avatar
Quoted: 663 Post(s)
Liked: 419
Tuning on that rear chamber for the original design was 18.9 or 18.8Hz. I doubt that changed much at all. I can check with Kevin.
post #219 of 252 Old 07-04-2019, 06:16 PM
Kpilk's Avatar
Quoted: 85 Post(s)
Liked: 86
I'm not one of those guys chasing single digits....just looking for dynamic movie and solid, accurate bass for music. Thanks for checking BTW.
Kpilk is offline
post #220 of 252 Old 07-04-2019, 06:34 PM
Red Five's Avatar
Quoted: 663 Post(s)
Liked: 419
Still about 19Hz.
Kpilk likes this.
post #221 of 252 Old 07-05-2019, 08:26 AM
Rcris's Avatar
Quoted: 110 Post(s)
Liked: 133
Still about 19Hz.
Is it possible to design these in a slim profile , like 20" or 18" depth
Jk7.2 likes this.
Rcris is offline
post #222 of 252 Old 07-05-2019, 08:53 AM
Quoted: 149 Post(s)
Liked: 68
Does anyone have an SPL curve on what this would look like with the LaVoce, however with a HPF set in the mid 30s? Ive been spending alot of time deciding on a way to go for a tremendous amout of MidBass behind the AT, from multiples of 18s to 21s. My convo with Kevin some time ago urged I wait for this, now that its here I’d like to see how it performs in the musical midbass realm for Live PA type kick drum, etc.l from the mid to high 30s up to 100hz or so. Curious to see how much is lost due to the 19hz tune vs ported multiples.
So if someone has access to spl curves with ab HP that would be great!!
Sent from my iPhone using Tapatalk Pro
FOHTech is offline
post #223 of 252 Old 07-05-2019, 12:03 PM
Kpilk's Avatar
Quoted: 85 Post(s)
Liked: 86
Per the previous remarks, looks like Kevin is building a trio of these with the Lavoce so there's that.
Your Exactly where I am. I've waited this long...I guess I'll give it a little more time to see what is revealed about this box.
Kpilk is offline
post #224 of 252 Old 07-05-2019, 03:10 PM
STL D's Avatar
Quoted: 426 Post(s)
Liked: 514
I swear, John and Kevin never sleep. Then again, I imagine it would be hard to with that many subwoofers firing off.
STL D is offline
post #225 of 252 Old 07-05-2019, 05:02 PM
asarose247's Avatar
Quoted: 1248 Post(s)
Liked: 1092
I am willing to believe that!
this is a look at "careful what you ask for" :https://mail.google.com/mail/u/0?ui=...=att&disp=safe
and : https://mail.google.com/mail/u/0?ui=...=att&disp=safe
and TY @Red Five for posting that "this looks way too easy, anymore" vid link.
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #226 of 252 Old 07-06-2019, 02:05 AM
Nexgen76's Avatar
Quoted: 756 Post(s)
Liked: 223
Glad i waited i already have 2 B&C 21DS115 sitting in the box from Ricci.. Looks like I'm going with two 21 MBM & 2 Devastator in back of the room 15X15 i live on the insanity side.
femi likes this.
JVC NX5 Panasonic UB820 PC Madvr
Sliver Ticket 120' Cinema white screen
Aggressive 1299 L/C/R/, Volt 10XL x 2 surround, MKII Atmos Modules x 4(Jav's build)
Pioneer Elite SC-LX801 Acurus A125x5
Ported Primate SI 18" HST subs x 2(DIY) V.B.S.S.x 4(MBM)
Nexgen76 is offline
post #227 of 252 Old 07-06-2019, 05:01 AM
Kpilk's Avatar
Quoted: 85 Post(s)
Liked: 86
Got a few pics of the Devastator and the new taller 21HT. I might have to tear out a wall to fit in a couple Devas.
ID:	2588024   Click image for larger version
ID:	2588026   Click image for larger version
ID:	2588028   Click image for larger version
ID:	2588030   Click image for larger version
Kpilk is offline
post #228 of 252 Old 07-06-2019, 05:03 AM
femi's Avatar
Quoted: 284 Post(s)
Liked: 322
21-inch Full Marty Flat Pack are now available - https://shop.gsgad.com/collections/2...ter-flat-packs
as well as the The Devastator - https://shop.gsgad.com/collections/horn-subwoofers
Oh wow...exciting time for diy
Femi
Jk7.2 likes this.
(2)JTR Cap 4000's---(6) Enclosures Seal SI HT-18's---Behringer iNUKE 6000DSP--- Behringer iNUKE 3000DSP---Denon AVR-4250CI---(3)JBL 4722n---(5)Behringer Eurolive B215XL---(2)Klipsch SS-1 Surround---JVC RS500---Sony HW50es---VApex Fixed frame 135" 16:9---Sony UBP-X800---Oppo BDP-93---Toshiba HD DVD-XA2---Xbox 360---PS4---HDFURY Linker---Darbee Darblet DVP-5000---miniDSP Balanced 2x4---Harmony 1100 remote
femi is online now
post #229 of 252 Old 07-06-2019, 05:59 AM
jfreeman420's Avatar
Quoted: 37 Post(s)
Liked: 54
I just finished these full Marty's two days ago with hst18s . I watched my first movie on this new system last night and I thought wow this is the best theater I've ever had. I don't think i'll need anything else.
Now I see this and I'm wondering if I can fit a horn somewhere.. I gotta stop reading this forum for a while
Sent from my SM-G892A using Tapatalk
kevings, jamiebosco, femi and 1 others like this.
jfreeman420 is offline
post #230 of 252 Old 07-06-2019, 06:55 AM
Red Five's Avatar
Quoted: 663 Post(s)
Liked: 419
It can be tricky depending on how shallow you try to go. The cross section of the front chamber must be close to 225in2, does not matter really what the dimensions are for the most part. The stock Devastator is 22.5in x 10in, so you would change the width to whatever it is you want then figure out what the depth will need to be. Keep multiplying things until you reach 225in2. The length of the front chamber must be close to 110cm or 43.3 inches if you want to maintain the basic response.
The rear has a port that needs to be a specific length to reach a desired tune with a specific displacement, so that is not too complicated.
post #231 of 252 Old 07-07-2019, 10:15 AM
Kpilk's Avatar
Quoted: 85 Post(s)
Liked: 86
Just ordered a 4 pack of Full Marty 21's. The pricing structure makes it hard to just order 2. I'm just installing two and either keeping the other pair back for a future, bigger room or putting them up for sale.
Tried every which way to fit a couple Devastators into my space but without tearing out a wall and rebuilding it wasn't going to happen. Besides, that would have been doubly expensive because in addition to the construction costs I'd have to add in the alimony payments it would generate when my wife would find out.
Will post some pics when they arrive and maybe do a build thread.
Kpilk is offline
post #232 of 252 Old 07-09-2019, 11:26 PM
nexus99's Avatar
Quoted: 171 Post(s)
Liked: 74
I did a time lapse video of the 18” Full Marty box assembly. I will create a new edit of this too with voiceover to match the instruction book in the coming weeks. Hope it helps someone build these monsters! https://youtu.be/MxAI01uvH88
kevings, madpirahna and femi like this.
JDM World: https://www.youtube.com/jdmworld
GSG Full Marty Build: https://youtu.be/-U1deD_0j9c
UM18-22 Sealed Subwoofer Build: https://youtu.be/7ifac8Rh8gk
nexus99 is offline
post #233 of 252 Old 07-12-2019, 04:22 AM
Kpilk's Avatar
Quoted: 85 Post(s)
Liked: 86
Updates on my GSG order The stool is what happens to the scrap. I don't think I get those but a cool idea.
ID:	2589970   Click image for larger version
ID:	2589972   Click image for larger version
Kpilk is offline
post #234 of 252 Old 07-12-2019, 11:54 AM
Augerhandle's Avatar
Quoted: 1254 Post(s)
Liked: 1256
That stool is pretty cool. Waste not, want not.
Kpilk likes this.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #235 of 252 Old 07-14-2019, 12:37 AM
nexus99's Avatar
Quoted: 171 Post(s)
Liked: 74
If 2 Fulls are laid on their sides next to each other.... are the ports in the middle or on the outside? Seems like on the outside would "spread" the love a little?
nexus99 is offline
post #236 of 252 Old 07-14-2019, 05:03 AM
timgrady's Avatar
Quoted: 22 Post(s)
Liked: 35
Hmm. I'd love to see a direct comparison of the response curve of these new 21" Martys vs. the 21" horn. The size of the two isn't terribly different.
Tim
judah517 likes this.
timgrady is offline
post #237 of 252 Old 07-14-2019, 08:30 AM
Kpilk's Avatar
Quoted: 85 Post(s)
Liked: 86
I'm going to lay my on their side>> Left 21Marty Center 21Marty Right. Not sure it will make a difference but I plan to start with the ports outside and then compare.
Kpilk is offline
post #238 of 252 Old 07-14-2019, 11:04 AM
Liked: 1256
It depends on your room and your seating location whether it will accentuate or reduce nulls and peaks at the listening position. Try both ways, and measure the results.
post #239 of 252 Old 07-14-2019, 01:43 PM
Quoted: 21 Post(s)
Liked: 0
Looking for someone in the New Orleans area (Northshore) that is interested in splitting a 4 pack of full marties!
Darthprater is offline
post #240 of 252 Old 08-01-2019, 04:07 PM
Quoted: 45 Post(s)
Liked: 65
Big thanks to the guys at GSG! They are great to deal with and make a quality product! Building these subs was a blast and I love the way they sound and feel! I was on the fence for quite a while about building a Marty sub until GSG came along. So easy to assemble and for the price it is an amazing value. Best investment in my setup to date!
ID:	2597234   Click image for larger version
stitch1 and femi like this.
ksmchristy is offline
