Another LTD02 Sub Design - 18D sub - AVS Forum | Home Theater Discussions And Reviews
 15Likes
  • 3 Post By Rcris
  • 4 Post By Rcris
  • 6 Post By Rcris
  • 1 Post By Randy_J
  • 1 Post By jujuman200
post #1 of 11 Old 11-20-2018, 07:31 PM - Thread Starter
Rcris's Avatar
Quoted: 132 Post(s)
Liked: 154
John came up with this form factor for my space reqs to line up Jbl4722s long back and time has come to execute the build
Driver : UM18-22
18D Sub in LTD02 words:
This cab works out to about 8.1 c.f. before driver and bracing, so about 7.6 c.f. net after everything. Port is 44" long, 2.5" tall, 21" effective width. Effective length is about 46.5" and then there is about a Hz of further adjustment required for this style of cab, so tuning should come in around 18.3Hz +/-.
If you will be standing the cab in the vertical position, you may want to lower the driver a bit for slightly better resistance to vibration.
Bracing is up to you of course, but make sure that it is rock solid.
Port velocity and first port resonance will be fine.
If you had something else in mind, we can modify the cab no problem. Just let me know what you would like.
Cut List (for single Baffle).
sides 18 x 48 (2)
top 18 x 16.5 (2)
Back 16.5 x 46.5 (1)
Port 16.5 x 26 (1) Back
Port 16.5 x 14.75 (1) Bottom
Baffle 16.5 x 43.23 (1)
Port Rail 2.5 x 17.25 (2)
Port Rail 2.5 x 46 (2)
Name:	iclops cutsheet 1.png
ID:	2485602   Click image for larger version
ID:	2485604   Click image for larger version
ID:	2485606   Click image for larger version
Sekosche, LTD02 and LTD02 like this.
Rcris is online now
post #2 of 11 Old 11-20-2018, 07:31 PM - Thread Starter
Rcris's Avatar
Quoted: 132 Post(s)
Liked: 154
Rcris is online now
post #3 of 11 Old 11-20-2018, 07:32 PM - Thread Starter
Rcris's Avatar
Quoted: 132 Post(s)
Liked: 154
Will EP4000 be sufficient to drive these to make some bass?
EP4k has built in high pass filters 5hz, 30hz, and 50 hz and these boxes are tuned to roughly 17hz.
Should I buy a minidsp or can get away with 30hz high pass for the time being. I'm sure a minidsp is a must at this stage to make use of the available amp, but which minidsp. Reading through the each component In/Out sensitivities but sure I can get a direct tested solution here quickly.
Rcris is online now
post #4 of 11 Old 01-07-2019, 11:42 AM - Thread Starter
Rcris's Avatar
Quoted: 132 Post(s)
Liked: 154
some build pics
ID:	2507308   Click image for larger version
ID:	2507310   Click image for larger version
ID:	2507312   Click image for larger version
ID:	2507314   Click image for larger version
ID:	2507318   Click image for larger version
Sekosche, bubbrik, curtisG and 1 others like this.
Rcris is online now
post #5 of 11 Old 01-27-2019, 06:38 PM - Thread Starter
Rcris's Avatar
Quoted: 132 Post(s)
Liked: 154
Its done !! They sound fantastic
ID:	2517294   Click image for larger version
ID:	2517296   Click image for larger version
ID:	2517298   Click image for larger version
ID:	2517300   Click image for larger version
ID:	2517304   Click image for larger version
ID:	2517306   Click image for larger version
ID:	2517308   Click image for larger version
Rcris is online now
post #6 of 11 Old 01-28-2019, 05:45 AM
Quoted: 241 Post(s)
Liked: 206
Looking very nice. I love the stuffed animal as a size reference. I found my 4 year old hiding in my sub box once when i was working on it.
Purenv likes this.
Randy_J is offline
post #7 of 11 Old 01-28-2019, 06:00 AM
Purenv's Avatar
Quoted: 235 Post(s)
Liked: 148
Holy crap!!! That’s a big box!!!
Purenv is offline
post #8 of 11 Old 01-28-2019, 07:23 AM
Quoted: 241 Post(s)
Liked: 206
Lol. That is my box for a Hs-24. My boy is on the smaller side to so that helps but the 24's are monsters. We are moving now through so that box will probably never see use. Now it is time to go ported possibly. I never ordered my amp so once we are in to the new place i will have to do that .
Randy_J is offline
post #9 of 11 Old 01-28-2019, 08:35 PM
LTD02's Avatar
Quoted: 3027 Post(s)
Liked: 3785
well done!!
Listen. It's All Good.
LTD02 is offline
post #10 of 11 Old 05-21-2020, 01:17 PM
lyle2321's Avatar
Liked: 0
Wow - very impressive build. I too am looking to build a sub based on the UM18-22 subwoofer -
How did you determine the proper cabinet size and where to put bracing?
You mentioned that John came up with this design? How to I get in touch with him, would like a design closer to 38 to 40 inches in height.
lyle2321 is online now
post #11 of 11 Old 05-22-2020, 08:16 PM
jujuman200's Avatar
Quoted: 407 Post(s)
Liked: 422
This might help.....https://www.avsforum.com/forum/155-d...tysub-faq.html
The MINI MARTY is is the size range that you are looking for that can use the UM18.....
Juju
Rcris likes this.
Sub List: 1- Red Five Mini V1 Devastator 18" w/PA460, 1- Red Five Devastator LFE 21", 1- Red Five Devastator 21" Finalizer V2 DF , 1- BOSS platform [The Hideaway Theater], 2- 18" "Full Marty" tuned to 17Hz w/RSS460HO
Wish List: Anthology http://www.speakerdesignworks.com/Anthology_1.html
jujuman200 is offline
