Outdoor sub(s) for cheap? - AVS Forum | Home Theater Discussions And Reviews
 39Likes
post #1 of 54 Old 11-23-2018, 04:19 PM - Thread Starter
BurtonSnol3order's Avatar
I'm buying a new place with a pool area and need to set up some tunes. I've got a crown xls 802 amp leftover to run the sub(s) which pushes [email protected], [email protected], [email protected] I plan on running Polk atrium 6s or 8s around the pool deck/patio and I need some low end to go with them. I know horns are usually the best option outdoor. Considering size doesn't matter much, should I look at lilwreckers, picowreckers, f20s, something from Bill F? Ideally, I'd keep costs down, so let me know your thoughts. This will be 99% music use.
BurtonSnol3order is offline
post #2 of 54 Old 11-23-2018, 05:21 PM
Samps's Avatar
Quoted: 1219 Post(s)
Liked: 901
None of those horns. Maybe one of bills other horns T48 possibly.
I'd just get a pair of the Dayton PA460s and place them in 5-6 cube boxes tuned to 35-40hz. Or 4 of them if you need that much bass.
LTD02, Craig S King and bebb like this.
Samps is online now
post #3 of 54 Old 11-23-2018, 05:42 PM - Thread Starter
What is the reason you think the 460s are a better option in a simple ported box? Should I look at some scoops, hogs or a keystone?
post #4 of 54 Old 11-23-2018, 06:02 PM
Samps's Avatar
Liked: 901
Those previous horns are designed for home theater. You do not need 20hz around a pool. 35hz is a good target. You can get a lot louder a lot easier at 35hz than 20hz. In the same size box as a lilwrecker you could build a simple ported cab with four budget 18s that would destroy the wrecker from 35-150hz.
The Keystone is a good option if you really want a horn. Not necessarily a budget option though. I think it needs a decent driver. An Othorn or Skhorn would be a killer option if you can jump that high.
But honestly, a pair of PA460s are so cheap you won't even worry about damaging them, and they will get seriously loud at 40hz. Which is all you need for a good party.
How loud are you trying to get?
LTD02 and bebb like this.
Samps is online now
post #5 of 54 Old 11-23-2018, 06:09 PM - Thread Starter
Makes sense. What box do you recommend for two of the 460s? Just a cube with a simple slot port?
post #6 of 54 Old 11-23-2018, 08:45 PM
Samps's Avatar
Liked: 901
A simple ported cab with either a slot or round plastic port is good. If you're familiar with winisd or hornresp then look for for something around 6 cubic feet tuned to 35hz. A 6" port would be good for each sub or comparable slot.
If you can afford a little more, the BC RBX18 models better but costs twice as much.
Trimlock likes this.
Samps is online now
post #7 of 54 Old 11-24-2018, 06:05 AM
Craig S King's Avatar
Quoted: 351 Post(s)
Liked: 498
@LTD02 Designed a VBSS variant that is tuned to 31hz, for music. I'm running a pair of them with the PA460s entirely for music, off of 1 channel of my NX3000D and am very happy. I believe the sizes and specs are in the VBSS thread.
jujuman200 and bebb like this.
Craig S King is offline
post #8 of 54 Old 11-24-2018, 08:11 AM
Samps's Avatar
Liked: 901
PA460 in 7 cubic feet tuned to 30hz vs 35hz. Either is a good fit for that driver.
Name:	460 30v35.JPG
Samps is online now
post #9 of 54 Old 11-24-2018, 08:42 AM - Thread Starter
I've found several LTD02 designs and one thing that I'd like to look at is some sort of "protected" design like a 6th order bandpass so I could keep the woofers out of the weather as much as possible? Has that (can that) been done with the PA460? What about something like the Kariflex/paraflex type design? something similar was talked about in this thread but I didn't see anything actually built.
post #10 of 54 Old 11-24-2018, 09:44 AM
Samps's Avatar
Liked: 901
If you don't mind building horns then Bill's T48 or T60 would work and not be very expensive. There's a few good tapped horns over at diyaudio that you could research. But tapped horns don't have much protection for the driver.
The skhorn would be a great fit for your needs if you can afford the drivers.
Craig S King likes this.
Samps is online now
post #11 of 54 Old 11-24-2018, 10:10 AM
K9woofer's Avatar
Quoted: 180 Post(s)
Liked: 119
How low does it need to play?
K9woofer is offline
post #12 of 54 Old 11-24-2018, 10:53 AM - Thread Starter
almost totally music, so 32/34 hz tuning would be fine
post #13 of 54 Old 11-24-2018, 11:14 AM - Thread Starter
I initially thought about the t48/t60 but the previous poster recommended the pa460 designs. I looked at the skhorn thread and the first post mentions driver options but I couldn't find where those were. I love the design for skhorn, but it looks like the pa460 and t48/60 would do much better 140hz and up to blend with the smaller outdoor speakers I'll have.
post #14 of 54 Old 11-24-2018, 06:01 PM - Thread Starter
Just a thought.. would it be possible/advisable to create a couch area with down firing pa460s with front firing slot ports? I'm planning on treating the 460s with some PE wet look to help weatherize them. I was reading the drivers would need about 4" feet to have proper airflow which I could do. Just trying to brainstorm ideas.
post #15 of 54 Old 11-24-2018, 08:07 PM
michael hurd's Avatar
Quoted: 631 Post(s)
Liked: 666
While it is certainly possible to utilize down firing drivers, keep in mind this adds a bit of a low pass filtering to the device, though most pro drivers have a rising response which will mitigate this issue compared to low efficiency home drivers.
Ports would be fine down facing, this will also discourage rodents / animals from entering the enclosure without your express consent. Screen applied over the inner port ends will also be a good deterrent.
Ask your doctor if DIY is right for you. Side effects of DIY may include anxiety, elevated blood pressure, lightheadedness, rapid heartbeat, skeletal muscle flaccidity, euphoria, psychological dependence, insomnia, confusion, blurred vision, implusivity, uncontrolled or repeated movements.
michael hurd is offline
post #16 of 54 Old 11-24-2018, 09:32 PM
K9woofer's Avatar
Quoted: 180 Post(s)
Liked: 119
I wouldn't down fire the pa460. I've noticed visible sag from storing used units pointing up. They have very soft suspension.
K9woofer is offline
post #17 of 54 Old 11-24-2018, 09:40 PM
Quoted: 631 Post(s)
Liked: 666
Good point, I had not calculated whether the driver was suitable for down or up firing use.
post #18 of 54 Old 11-25-2018, 02:41 AM - Thread Starter
Thanks. This is what I needed. Looks like it's back to the drawing board. Any ideas to consider?
post #19 of 54 Old 11-25-2018, 04:24 PM
bebb's Avatar
Quoted: 218 Post(s)
Liked: 156
+1 for the PA460's using the @LTD02 design in the V.B.S.S.
If bad sound were Faital, good sound would be almost impossible
Killed two Mach5 21s and three UM-18s (and counting?)
bebb is offline
post #20 of 54 Old 11-25-2018, 06:58 PM - Thread Starter
Do you have a link to his design? I've been through the 40+ pages on vbss and see a ton of posts by LTD02, just can't find the plans.
post #21 of 54 Old 11-27-2018, 12:08 AM
LTD02's Avatar
Quoted: 2909 Post(s)
Liked: 3590
https://www.avsforum.com/forum/155-d...l#post56120796
post 789 in the thread.
this one is tuned slightly higher:
https://www.avsforum.com/forum/155-d...hest-kick.html
unretarded likes this.
Listen. It's All Good.
LTD02 is offline
post #22 of 54 Old 11-27-2018, 07:39 AM - Thread Starter
Thank you!
Quick question: with port dimensions of 1.5" x 22" results 14.6:1. I thought it was recommended to keep that ratio under 9:1 or 8:1. is there a reason to avoid something closer to 2" or 2.5" that would get that ratio closer to recommended? I realize that would necessitate a longer port, but I just wondered if it mattered at all. I realize plenty of people have built and raved about this design, but I guess I'm just curious about the thought behind this.
post #23 of 54 Old 11-27-2018, 10:55 AM
LTD02's Avatar
Liked: 3590
Thank you!
i'm not quite sure what to make of such 'rules of thumb'. if there is a brace running down the middle, does that make it two ports and so reduce the ratio by 50%? i generally try to make ports more in the way that you describe, but oftentimes the narrower ones (as in this case) seem to work fine.
LTD02 is offline
post #24 of 54 Old 11-27-2018, 11:11 AM - Thread Starter
I certainly don't have the answers, just a thought that I had looking at the design. It would make sense that the brace divides the port into essentially 2 identical ports. Thanks for the work you do. I'll be building 2 of these to turn into outdoor endtables out by the pool. I just need to find the best way to "waterproof" the subs the best that I can.
post #25 of 54 Old 11-28-2018, 12:44 AM
LTD02's Avatar
Liked: 3590
if you want to try something adventurous, perhaps something like this?
this is a simple vertical ported bandpass. port cab is tuned to 28hz or so.
front section increases output.
design would be waterproof.
driver mounts from the inside.
bracing (not shown) would be required, but overall, not an overly complex build.
removable rear hatch for driver access
frequency response of this sub (gray) vs. ported design with same tuning (black), 1w1m 2pi space
edit: forgot to mention, design is for PA460 driver.
ID:	2488410   Click image for larger version
ID:	2488412   Click image for larger version
ID:	2488414   Click image for larger version
curtisG, eXa, dtsdig and 4 others like this.
LTD02 is offline
post #26 of 54 Old 11-28-2018, 04:52 AM
ejh2854's Avatar
Quoted: 30 Post(s)
Liked: 43
Cover the openings with screen to keep the critters out, and that design looks killer.
FWIW I built a BFM T39 (LAB12 inside) for my half-acre-ish backyard, and it had nooooo trouble filling that space on a very modest amp.
There is no Honor in Mediocrity
ejh2854 is offline
post #27 of 54 Old 11-28-2018, 05:46 AM
Quoted: 389 Post(s)
Liked: 336
Damn, even for a big box that is a nice design.
Do you have a pile of designs for every situation?
Trimlock is offline
post #28 of 54 Old 11-28-2018, 06:14 AM - Thread Starter
This design looks amazing! Thank you! Looking at the graphs of this vs your V.B.S.S., this appears to be a little lower output? Is that correct? I'm not scared of a harder build (especially with the much more waterproof nature of this design. Is there by chance anyone who has posted a build thread for this design?
post #29 of 54 Old 11-28-2018, 08:30 AM
LTD02's Avatar
Liked: 3590
lol, thanks, and not really. :-)
i just started playing around with some "waterproof" concepts last night and that was the third attempt.
LTD02 is offline
post #30 of 54 Old 11-28-2018, 08:39 AM
LTD02's Avatar
Liked: 3590
i just made it up last night for you.
this would have significantly *more* output than the vbss (for 500 watts power add about 27dB), and the efficiency (not shown) of the upper end gets really high owing to the bandpass feature, so it should have crazy punch.
whether it is officially a bandpass or a horn with no flare, i'm not quite sure what to call it. horn with no flare may be more descriptive. :-)
it is kind of like a full-front loaded horn, but trades off a little upper end output for more low end extension.
curtisG, Samps and unretarded like this.
LTD02 is offline
