Expert help - 21NLW9601 in TH? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 11-25-2018, 02:56 PM - Thread Starter
zora's Avatar
Quoted: 104 Post(s)
Liked: 82
All you hornresp experts, can the 18Sound 21nlw9601 work in a single fold TH like cattskinner made for the 21ds115?
http://www.eighteensound.com/Product...3317/21nlw9601
There is a local guy selling a pair and I thought and I thought a big TH project might be fun, but I am not a TH expert. Thanks in advance for any help.
zora is online now
post #2 of 12 Old 11-25-2018, 05:17 PM
joebuddyguy's Avatar
Quoted: 110 Post(s)
Liked: 153
I'm no expert either, but those drivers model similarly to the 21sw152 and 21ds115... I also believe Ricci says they will work in the skhorn. I was thinking about doing just that after building new mains since I have a few of them. They may work in the submaximus as well. Will need to play with hornresp to be certain... perhaps someone with more experience modeling horns can help?
Sent from my LM-G710 using Tapatalk
joebuddyguy is offline
post #3 of 12 Old 11-25-2018, 11:45 PM
Quoted: 453 Post(s)
Liked: 379
Haven’t modeled yet and I don’t know much about the requested horn but it has some serious motor force. I don’t know how stiff the cone is but I don’t see why it wouldn’t work in a TH?
Trimlock is online now
post #4 of 12 Old 11-25-2018, 11:57 PM - Thread Starter
zora's Avatar
Quoted: 104 Post(s)
Liked: 82
From what little I know about TH's, I think it might work but I wanted experienced members verify that for me.
Jim
zora is online now
post #5 of 12 Old 11-26-2018, 05:45 AM
Quoted: 110 Post(s)
Liked: 153
If it helps, I have compared the cones between the 21sw152 and the 18 sounds 21NLW9601 and they are similar strength wise. They are both slotted just underneath their respective manufacturer's IPAL offerings in their lineups.
post #6 of 12 Old 11-26-2018, 11:34 PM - Thread Starter
zora's Avatar
Quoted: 104 Post(s)
Liked: 82
I wonder if they source the same cones?
zora is online now
post #7 of 12 Old 11-27-2018, 05:38 AM
Quoted: 110 Post(s)
Liked: 153
They are similar but don't think identical. They have measured nicely from my highly scientific push and tap on the cones tests lol. I definitely prefer B&C's ground rubber gasket over the 18 sounds foam gasket...but that is a cosmetic issue that is completely solved in higher order alignments that obscure the cone
post #8 of 12 Old 11-30-2018, 07:47 AM - Thread Starter
zora's Avatar
Quoted: 104 Post(s)
Liked: 82
Any other thoughts on the suitability of this driver in TH's?
zora is online now
post #9 of 12 Old 11-30-2018, 02:06 PM
lilmike's Avatar
Quoted: 113 Post(s)
Liked: 283
Should work fine.
18 Sound in black, B&C in gray.
For clarification - this is the model for cattskinner's "Sue" tapped horn.
lilmike is offline
post #10 of 12 Old 11-30-2018, 09:08 PM - Thread Starter
zora's Avatar
Quoted: 104 Post(s)
Liked: 82
Thanks lilmike, I thought they would work but I wanted a pro to verify for me 👍
zora is online now
post #11 of 12 Old 12-08-2018, 07:42 PM
cattskinner's Avatar
Liked: 30
Glad to see you got some input on that, and I am looking forward to hearing about your experience with the design. It's a whole lotta' lotta', no mistake, or by my humble standards.
cattskinner is offline
post #12 of 12 Old 12-08-2018, 08:06 PM - Thread Starter
zora's Avatar
Quoted: 104 Post(s)
Liked: 82
I am used to a "whoke lotta lotta" (I currently have dual-opposed sealed FTW-21's fed by few kilowatts ), but trying a different flavor is always fun. I have had sealed, bass-reflex, horn, and infinite baffle subs over the years and I thought a big tapped horn would be a great experiment.
Jim
zora is online now
