Dayton DCS450-4 18" Budget Build - AVS Forum | Home Theater Discussions And Reviews
 7Likes
  • 3 Post By Mazza
  • 2 Post By Randy_J
  • 2 Post By LTD02
post #1 of 4 Old 12-04-2018, 06:09 AM - Thread Starter
Mazza's Avatar
Quoted: 12 Post(s)
Liked: 38
Dayton DCS450-4 18" Classic Subwoofer Budget Build
Dear all,
A buddy had some cash left over after a recent HT remodel. He asked that I suggest what next to take his cinema to the next level within his budget?
So naturally, after recent successes with my Alpine based budget builds, I suggested a budget build, and with the DCS450-4 18" sub on sale recently, I pointed him towards this driver.
$250AUD later I landed this very nice looking driver (for the money) in Aus and made preparations for a build.
Enclosure is approximately 190 litre net ported - maximum size for his back of room location with dimensions dictated by available space. I used 30mm ply for this build as its great to work with, light and flex free.
Here are my sketch ups, measurements in centimeters:
Cut sheet also centimeters ....
WinISD model tuned to approx 21hz...
Driver looks great, fixing holes are hard up against the frame edge meaning about 30% of the circumference of the holes has nothing for the fasteners to hold against, but otherwise its great....
Our local Bunnings hardware has a great panel saw, $1 cuts are a bargain!
Build pics.....
I love PVA
Clamps galore
Just one brace, I felt that with the 30mm ply even the one was possibly unnecessary?
Home made circle jig...
Paint
Now I was impressed with the size of the Alpine 15's having come from Alpine 12's but 18" is next level big...
And this thing is way too big for my modest digs...
So no measurements yet. That will come once installed in my friends place. Subjectively it has plenty of extension, is appreciably more efficient than the Alpines and has that big sound I can't quite describe that big speakers make. I haven't been able to crank it with the family about the house this week so I'm excited to see how it fairs in its home with some EQ from his DCX2496.
For about $450 in parts for the sub and box, about $550 for an XLS 1002 (to be bridged and high passed at 20hz with the DCX2496 for driver protection) makes this a very high value proposition. I really don't know of any commercial product available in Aus for HT in an 18" option.
Overall I'm extremely pleased with this project, fun and rewarding! Hope this is of some use for others. Comments and suggestions are always appreciated.
Edit: Now installed and measured.
All of these measurements taken with a LR HPF @ 20hz. I only applied cut filters to get this result, no boosts were applied despite getting a lot more output in the 20-40hz range.
No bad noises to report after a solid session with a bridged XLS1002 running into it..... yet! This is a very nice driver.
Name:	Dayton Audio DCS450-4 18_ Classic Subwoofer 4 Ohm (2).png
ID:	2491208   Click image for larger version
Name:	Dayton Audio DCS450-4 18_ Classic Subwoofer 4 Ohm.png
ID:	2491210   Click image for larger version
ID:	2491212   Click image for larger version
ID:	2491214   Click image for larger version
ID:	2491218   Click image for larger version
ID:	2491226   Click image for larger version
Name:	PVA Blocks.jpg
ID:	2491228   Click image for larger version
Name:	PVA goodness.jpg
ID:	2491230   Click image for larger version
ID:	2491234   Click image for larger version
Name:	Top and Bottom.jpg
ID:	2491236   Click image for larger version
ID:	2491238   Click image for larger version
ID:	2491240   Click image for larger version
ID:	2494410   Click image for larger version
Jedi940, bebb and LTD02 like this.
Mazza is offline
post #2 of 4 Old 12-04-2018, 07:32 AM
Quoted: 234 Post(s)
Liked: 194
Wow nice job. Looks like you did a great job on the box. Its amazing how much bigger the subs seem as you step up in size. Just think when you go from a 18 to a 24 it is the same leap in size again. Then when you take pictures they dont convey the scale and you need some othe frame of reference.
bebb and Mazza like this.
Randy_J is offline
post #3 of 4 Old 12-07-2018, 12:08 AM
LTD02's Avatar
Quoted: 3004 Post(s)
Liked: 3770
Trimlock and Mazza like this.
Listen. It's All Good.
LTD02 is offline
post #4 of 4 Old 06-26-2019, 03:21 PM
Liked: 2
Looks like you did a great job. I wanted to contact you to see how it has worked out after 6 months but the site will not let me until I have more posts because I am new.
I am considering this drived mainly because I live out of the country and freight and duty is significant. (Not only for the driver but a bigger amp matters a lot on cost as well). Basically you double the price to see the landed in Nicaragua price.
Also, the sensitivity seems to be much better than the Ultimax and others. I will use it for 50/50 music/HT. I likely would high pass it at 20 Hz for safety. Probably use the Dayton 250 watt plate amp.
If you have any remarks after these months, I would appreciate it.
WJM Rivas is offline
