Devastator an LTD02 hybrid design - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 354Likes
post #811 of 973 Old 10-16-2019, 08:35 PM
jujuman200's Avatar
Quoted: 140 Post(s)
Liked: 101
Originally Posted by Red Five View Post
Logistics would be interesting since we are spread out. Maybe see how Black Friday goes?
I guess my main question is would it really be that much cheaper than what we have available here once you include shipping from China? If you are buying 4+ then maybe....
Juju
Wish List: 2- Red Five DEVASTATOR MINI, 2- Red Five DEVASTATOR LFE, 1- BOSS platform.
Anthology http://www.speakerdesignworks.com/Anthology_1.html
jujuman200 is online now
post #812 of 973 Old 10-17-2019, 05:24 AM - Thread Starter
Red Five's Avatar
Quoted: 737 Post(s)
Liked: 525
Juju
If the sale price on the SAF is the same as earlier this year, the SAF might be cheaper. It has a warranty, it has a 45 day return policy. It also has trusted specs, it would have a lot more going for it.
Stormbreaker | Wisconsin Home Theater Meet Thread | The Devastator Index | Dev Build
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | Yamaha A3070 | Crown XLS 1502 | iNuke 3000 DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen
Red Five is online now
post #813 of 973 Old 10-17-2019, 10:06 AM
a77cj7's Avatar
Quoted: 191 Post(s)
Liked: 155
I’d rather pay a little more for the known quality from reputable source. Then again, I’m putting 18ds115-4’s in my mini dev’s, so I might just be stupid.
No exciting build pics from me today. Put in a long night last night and got the second box caught up to the first. External roundovers and a final sanding tonight, and I’ll start the duratex.
I like to let it sit for awhile after painting, duratex stays soft without hot sunny days for curing. I’ll crank my shop heat up to low 70’s.
Chris
jujuman200 likes this.
a77cj7 is online now
post #814 of 973 Old 10-17-2019, 12:52 PM
Purenv's Avatar
Quoted: 227 Post(s)
Liked: 140
Sorry if I haven’t chimed in much... I’m still cutting 8 sheets of Baltic birch plywood for my 2 ICU Devastators and LCR 1099 speakers.
@a77cj7
The pictures with my window idea inspire me to get mine done! They look great!!!! Congrats on your quick build. So jealous of how fast you got them done!
Purenv is offline
post #815 of 973 Old 10-17-2019, 01:27 PM
a77cj7's Avatar
Quoted: 191 Post(s)
Liked: 155
@a77cj7
I was originally considering how cool windows would be, but had given up when I was going to use gsg flatpacks. Once I decided to build mini’s, your comments inspired me to give it a shot. I’m really glad I did, its turning out better than I expected. So thanks for that.
Looking at the gsg flatpacks again, it looks simple enough to add a window. Just have to add trim strips around the edge like I did.
The polycarbonate I’m using is awesome to work with. Drills cleanly and easily, cuts super smooth on the table saw. I put a 1/8 roundover on it as well, looks good.
I’ll have finished pics up next Wednesday at the latest. Thats when my fiance gets back from a trip. Not sure I dare move them alone, don’t wanna scuff the duratex.
One other thought at the moment, it might be better to paint the horn chamber gray for contrast. If the black blends too well, I’ll get some white duratex and mix a batch up.
Chris
post #816 of 973 Old 10-17-2019, 06:18 PM
Purenv's Avatar
Quoted: 227 Post(s)
Liked: 140
Chris
Haha... “Great minds think alike!” I was thinking the same thing... Painting the horn port gray for contrast.
How are you planning to “seal” the window edges?
What did you use to make your trim strips?
Purenv is offline
post #817 of 973 Old 10-17-2019, 06:32 PM
a77cj7's Avatar
Quoted: 191 Post(s)
Liked: 155
I’ll seal the window with PE gasket tape, same stuff I’m using for the hatch.
https://www.parts-express.com/parts-...-roll--260-542
Trim strips are just 3/4 mdf. I cut em at 1.5” since the saw was already set up for it. Shoulda gone 2” though, since the screws I’m using are 2.5”.
1/8” roundover on top and a 3/8” roundover on bottom. Radius on bottom corner, 1.25” IIRC.
Chris
post #818 of 973 Old 10-18-2019, 01:36 AM
a77cj7's Avatar
Quoted: 191 Post(s)
Liked: 155
Well, had a pretty good setback tonight. Got the boxes finished and ready for paint without incident.
Tried to paint the inside of the first horn. Fought it for 2 hours to learn that it is physically impossible to get a passable paintjob with rollers or brushes on inside corners.
Looks like I’m learning to spray duratex. Yay more tools.
I hope it isn’t too hard to recover from the mess.
Chris
post #819 of 973 Old 10-18-2019, 06:39 AM - Thread Starter
Red Five's Avatar
Quoted: 737 Post(s)
Liked: 525
Chris
If buying more tools is wrong I do not want to be right Pioneering clear fronts does have the potential for unforeseen setbacks. I am sure @Purenv appreciates the info since he will be attempting the same thing soon.
post #820 of 973 Old 10-18-2019, 11:29 AM
Purenv's Avatar
Quoted: 227 Post(s)
Liked: 140
Exactly!!! I was actually planning on painting certain parts before assembly and for the above reasons why. Thanks @a77cj7 for confirming my concern. You rock man!!!
Purenv is offline
post #821 of 973 Old 10-18-2019, 12:00 PM
a77cj7's Avatar
Quoted: 191 Post(s)
Liked: 155
Well, not the worst finish i’ve ever seen, but still completely unacceptable.
On today’s episode of “I have no idea what the #%&$ I’m doing”:
Chris
Red Five likes this.
post #822 of 973 Old 10-18-2019, 12:09 PM - Thread Starter
Red Five's Avatar
Quoted: 737 Post(s)
Liked: 525
Chris
@eng-399 usually sprays his Duratex and it comes out awesome. Maybe try it on a test piece of material quick and see what happens.
post #823 of 973 Old 10-18-2019, 12:30 PM
Purenv's Avatar
Quoted: 227 Post(s)
Liked: 140
Chris
What about using a rattle can in gray for contrast like you stated earlier...? Is it too late to try?
Purenv is offline
post #824 of 973 Old 10-18-2019, 12:40 PM
hd0823's Avatar
Quoted: 857 Post(s)
Liked: 1615
I believe @eng-399 waters down the duratex when spraying
Sent from my SM-N950U using Tapatalk
hd0823 is online now
post #825 of 973 Old 10-18-2019, 01:01 PM - Thread Starter
Red Five's Avatar
Quoted: 737 Post(s)
Liked: 525
Do you remember how much he dilutes it?
post #826 of 973 Old 10-18-2019, 01:18 PM
a77cj7's Avatar
Quoted: 191 Post(s)
Liked: 155
Well, something happened, lol.
Much rougher finish than I get with 1/4 nap roller, but nice consistency and coverage. Wow is it fast. Uses way more duratex though, blew the whole gallon and wasn’t nearly done.
Just ordered a gallon of spray grade, see if it goes on smoother.
I’m sure @eng-399 uses a way nicer spray setup. This is just a harbor freight texture gun. I sprayed the roller grade undiluted, found a thread where that was recommended.
So I guess they won’t be finished this weekend. O well, I tried.
Chris
eng-399 and Red Five like this.
post #827 of 973 Old 10-18-2019, 01:21 PM
Purenv's Avatar
Quoted: 227 Post(s)
Liked: 140
If it’s the spray grade, several people have stated to dilute it 10%.
I pm’d @Eng 399 about diluting the non-spray grade and to what extent.
If I remember correctly, I thought you could dilute the roll on DuraTex 50% to spray it. But please wait for confirmation... I very well could be wrong about the ability to spray the roll on version.
Edit: I posted this late... oops!
Purenv is offline
post #828 of 973 Old 10-18-2019, 01:21 PM
a77cj7's Avatar
Quoted: 191 Post(s)
Liked: 155
Finish isn’t nearly good enough for rattle can to cover. If I put way more work into finishing the inside ahead of time, and didn’t try rolling on duratex, may have been an option. You can try it for your build .
Chris
Purenv likes this.
post #829 of 973 Old 10-18-2019, 01:24 PM
a77cj7's Avatar
Quoted: 191 Post(s)
Liked: 155
I was spraying 30 seconds after my post of the gun and plastic, lol. Thanks for trying to help though.
I’m not unhappy with my outcome, other than not having enough duratex.
Chris
post #830 of 973 Old 10-18-2019, 01:29 PM
Purenv's Avatar
Quoted: 227 Post(s)
Liked: 140
Chris
I believe you would want to use a HVLP spray gun with something like a 1.8 tip. That way it sprays a more fine mist for a smoother finish.
Search YouTube for life of bliss. He has a video showing how to spray the DuraTex and his end result.
Sorry bro!
Purenv is offline
post #831 of 973 Old 10-18-2019, 01:38 PM
a77cj7's Avatar
Quoted: 191 Post(s)
Liked: 155
Sorry bro!
Again, I’m not at all unhappy about the outcome. Its all a learning process. Duratex makes it an expensive one, but this whole hobby is stupid expensive.
If the spray grade proves to go on much smoother, I can sand down the texture and re-coat on exterior surfaces. I’m actually happy with the interior, its completely done and consistent. At least I think so, will take a closer look once its dry.
Chris
Purenv likes this.
post #832 of 973 Old 10-18-2019, 01:54 PM
Purenv's Avatar
Quoted: 227 Post(s)
Liked: 140
Chris
Yeah this hobby is costing me more than I thought it would... I blame everybody on here!
The only thing that matters is if you are happy with your results. I thought it looks good!
Purenv is offline
post #833 of 973 Old 10-18-2019, 02:02 PM - Thread Starter
Red Five's Avatar
Quoted: 737 Post(s)
Liked: 525
Just remember how much more it would cost for someone else to do all of it for you
Purenv likes this.
post #834 of 973 Old 10-18-2019, 02:17 PM - Thread Starter
Red Five's Avatar
Quoted: 737 Post(s)
Liked: 525
I am thinking of copying Jeremy @hd0823 on my minis. Added some trim to the CAD file to see how it looks.
Name:	Mini Dev with trim.jpg
Purenv likes this.
post #835 of 973 Old 10-18-2019, 02:21 PM
a77cj7's Avatar
Quoted: 191 Post(s)
Liked: 155
Did you find suitably sized mdf at menards?
Chris
post #836 of 973 Old 10-18-2019, 02:24 PM - Thread Starter
Red Five's Avatar
Quoted: 737 Post(s)
Liked: 525
Chris
I still have not made it out there. Wednesday plans changed on me, tonight might be the night.
post #837 of 973 Old 10-18-2019, 02:34 PM
jujuman200's Avatar
Quoted: 140 Post(s)
Liked: 101
This is not so bad..... try rebuilding CARS as a hobby...... now THAT gets crazy quickly. Blink and you just dropped $30K into your baby..... SMH Twin turbos are $5k-$6K easy.....
Juju
post #838 of 973 Old 10-18-2019, 02:38 PM
jujuman200's Avatar
Quoted: 140 Post(s)
Liked: 101
Don't blame EVERYONE..... just LTD02 and RED FIVE..... They are the culprits designing awesome subs and s^%t.....
Juju
kagtha likes this.
post #839 of 973 Old 10-18-2019, 02:39 PM
jujuman200's Avatar
Quoted: 140 Post(s)
Liked: 101
ABSOLUTELY doing this to mine.....
Juju
post #840 of 973 Old 10-18-2019, 02:42 PM - Thread Starter
Red Five's Avatar
Quoted: 737 Post(s)
Liked: 525
Juju
That is using 1"x3"s, I think it gives it a nice looks
