Devastator an LTD02 hybrid design - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 443Likes
post #181 of 1225 Old 05-19-2019, 07:19 PM
hd0823's Avatar
Quoted: 946 Post(s)
Liked: 1798
Originally Posted by Red Five View Post
I should have gotten to this sooner, version 1 vs LFE version.
Lfe version definitely looks better and smoother
Sent from my SM-N950U using Tapatalk
hd0823 is offline
post #182 of 1225 Old 05-19-2019, 07:58 PM - Thread Starter
Red Five's Avatar
Quoted: 1347 Post(s)
Liked: 1278
It does look a lot better. The compromise, displacement and 3mm of excursion over tune. Even with the added excursion it should be able to take 1500 watts and 1500 watts is 125db @ 20Hz. The cut list will hopefully get done soon
This is the way...
Stormbreaker | WI HT Meet Thread | The Devastator Index | Dual Mini Devastator Build
7.2.4 | A3070 | XLS 1502 | CTS 2000 | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is offline
post #183 of 1225 Old 05-20-2019, 01:49 PM - Thread Starter
Red Five's Avatar
Liked: 1278
Devastator LFE
More ridiculous and maybe even excessive bass External Dimensions 48"x25.5"x42". LFE V2, now with acceptable rear port air velocity! One half inch was added to the rear chamber port bringing velocity in check. Response on the front horn was minimally effected. The design is optimized for 1500 watts of power. More power can be applied, but air velocity and excursion might go off the rails! Check out the graphs Tune is calculated at a hair over 19hz. The LFE is pushing excursion max from about 25Hz to 30Hz, so response is down a small amount from the v1. I am adding the 16Hz tune version because massive extension, just add 12.75" to the port!
Spoiler!
ID:	2570620   Click image for larger version
ID:	2570622   Click image for larger version
ID:	2570624   Click image for larger version
ID:	2570626   Click image for larger version
ID:	2571292   Click image for larger version
femi and eng-399 like this.
This is the way...
Red Five is offline
post #184 of 1225 Old 05-20-2019, 03:55 PM - Thread Starter
Red Five's Avatar
Liked: 1278
I do not have the chart handy for your 18Sound 21" in the LFE cabinet, but the response looks really good still.
This is the way...
Red Five is offline
post #185 of 1225 Old 05-20-2019, 05:20 PM
Blue's Avatar
Quoted: 203 Post(s)
Liked: 88
Isn't there an automatic suspension from AVSforum for ever referring to an amount of bass as "excessive?"
This thing is massive. I'm pretty sure my wife would divorce me if I put one in our media room. It looks awesome though.
jujuman200 likes this.
Formerly known as GatorBlues. The Spinal Tap Theater build:
https://www.avsforum.com/forum/19-ded...ter-build.html
Blue is offline
post #186 of 1225 Old 05-20-2019, 05:47 PM - Thread Starter
Red Five's Avatar
Liked: 1278
That is true, subs abound in this section of AVS and that statement could be consider sacrilege
It maybe large, but it is efficient at turning power into bass. I am running an 8 Ohm load, so this makes more sense to me since wood is cheaper than amplifiers that dump 2000 watts into 8 Ohms and I have the space.
This is the way...
Red Five is offline
post #187 of 1225 Old 05-20-2019, 06:20 PM
asarose247's Avatar
Quoted: 1341 Post(s)
Liked: 1177
iirs,
a full Marty is 24 x 24 x 48
Devi is 24 x 30 x 48
only about 25% more volume
and uses a 21"!
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is online now
post #188 of 1225 Old 05-20-2019, 06:33 PM - Thread Starter
Red Five's Avatar
Liked: 1278
Originally Posted by asarose247 View Post
iirs,
and uses a 21"!
The big version comes in much larger 48x25.5x42. In exchange for adding what is almost the size of a mini Marty, you get a higher left corner
jujuman200 and Craig S King like this.
This is the way...
Red Five is offline
post #189 of 1225 Old 05-21-2019, 02:55 AM
Quoted: 571 Post(s)
Liked: 474
Damn, the LFE version is a hair bit larger over the lilwrecker.
Trimlock is offline
post #190 of 1225 Old 05-21-2019, 03:05 AM
Jk7.2's Avatar
Quoted: 1850 Post(s)
Liked: 3395
Man. My rear subs sit in an opening that’s 48 X 26 X 48” deep. Very tempting. I could swap the hst’s out for the larger devastator. It would be hidden under the stairs.
krholmberg and eng-399 like this.
Jk7.2 is offline
post #191 of 1225 Old 05-21-2019, 04:58 AM - Thread Starter
Red Five's Avatar
Liked: 1278
The nice thing about them is they hide the driver, so no accidental kicking in of a cone. If you went with the monster you could put a cushion on it and turn it into the hottest bass seat in the house GSG will be coming out with the Devastator v1 relatively soon. They are expecting good things from it with the response curve. Edit: misread the dimensions, yeah the big guy would fit in there without making it a bass bench
Jk7.2 likes this.
This is the way...
Red Five is offline
post #192 of 1225 Old 05-21-2019, 05:32 AM
Jk7.2's Avatar
Liked: 3395
I’ve used the rear subs as extreme nearfield experience. Lol
If I was to build the lfe version, I’d need to see a spl graph of the one LFE devastator vs. my two hst’s that are there currently.
Red Five likes this.
Jk7.2 is offline
post #193 of 1225 Old 05-21-2019, 05:42 AM - Thread Starter
Red Five's Avatar
Liked: 1278
Which HST 18 are they? Do you have TS specs? They might have enough motor force to work in a Devastator
This is the way...
Red Five is offline
post #194 of 1225 Old 05-21-2019, 05:43 AM
Jk7.2's Avatar
Liked: 3395
I can get them. They’re the version 1 hst’s
If I do the build, it’s gonna be for the B&C 21.
Jk7.2 is offline
post #195 of 1225 Old 05-21-2019, 05:53 AM - Thread Starter
Red Five's Avatar
Liked: 1278
We can sim it anyways for scientific reasons
This is the way...
Red Five is offline
post #196 of 1225 Old 05-21-2019, 05:56 AM
Jk7.2's Avatar
Liked: 3395
Ok! I’ll copy paste the specs.
This should be close enough
Jk7.2 is offline
post #197 of 1225 Old 05-21-2019, 06:47 AM - Thread Starter
Red Five's Avatar
Liked: 1278
Spoiler!
Lord of the Rings: The Two Towers. The peaks are getting very pronounced, it would take a lot of EQ, so a 21" looks a lot better.
This is the way...
Red Five is offline
post #198 of 1225 Old 05-21-2019, 07:01 AM
Jk7.2's Avatar
Liked: 3395
I’d love to see how two of my hst in full Martys compare to 1 devastator lfe with the B&C 21
Jk7.2 is offline
post #199 of 1225 Old 05-21-2019, 07:19 AM - Thread Starter
Red Five's Avatar
Liked: 1278
This is the one watt comparison. Scale things up to figure out where they land. Short story, the Devastator will take the mid bass crown. However, the HSTs will take the low end if fed adequate power. They have an excursion advantage and you have a larger cone area than a single 21". Edit: @Jk7.2 I had to update this graph, since voltage is calculated on Re not nominal it is much closer on the bottom end, but mostly the same story in the mid bass.
This is the way...
Red Five is offline
post #200 of 1225 Old 05-21-2019, 07:30 AM
Quoted: 571 Post(s)
Liked: 474
Looks like the Devestator also cures the issue with port resonance.
Trimlock is offline
post #201 of 1225 Old 05-21-2019, 07:33 AM
Jk7.2's Avatar
Liked: 3395
Thanks for doing this. Yeah, it makes it hard. I love what I have, but always wonder ‘what if’?
asarose247 likes this.
Jk7.2 is offline
post #202 of 1225 Old 05-21-2019, 07:35 AM - Thread Starter
Red Five's Avatar
Liked: 1278
The outputs from each piece of the design complement each other nicely. Which gives a pass band that is pretty great
ID:	2569502   Click image for larger version
This is the way...
Red Five is offline
post #203 of 1225 Old 05-21-2019, 09:47 AM - Thread Starter
Red Five's Avatar
Liked: 1278
Thanks @LTD02 for answering my question on why my excursion sim looks off. Power is calculated on Re, not nominal impedance! Here is a comparison that is pushing each cabinet right to 20mm of excursion based on the simulation. The v1 has more in the mid bass regions once you get over 30Hz. The LFE has more under 30hz and in the upper teens, so deciding on compromises. I think the excursion numbers are higher than actual, especially after going back and fourth with WinISD. There might be more wiggle room for power.
Name:	20mm ex comparison.JPG
This is the way...
Red Five is offline
post #204 of 1225 Old 05-23-2019, 09:26 AM - Thread Starter
Red Five's Avatar
Liked: 1278
The LFE version has been update
See post here.
This is the way...
Red Five is offline
post #205 of 1225 Old 05-24-2019, 05:25 AM - Thread Starter
Red Five's Avatar
Liked: 1278
This is a nice looking curve (it has curve appeal), it is just adding 12.75" to the port on LFE version. I am most likely going this route Tune comes out to calculated 16.2Hz
Jk7.2 likes this.
This is the way...
Red Five is offline
post #206 of 1225 Old 05-24-2019, 07:37 AM
BryceDH's Avatar
Quoted: 176 Post(s)
Liked: 163
That output graph looks amazing... Would I be able to expect something similar if I were to repurpose my um-18 currently in a Full Marty into the devastator v2?
It sounds like building a cabinet for a horn is a lot more difficult than what my Marty was. The detail in the first post for a v1 is great. Will that level of detail be provided for the v2? Trying to determine if I have the capability to build this or not.
Sent from my SM-N960U using Tapatalk
Equipment: Yamaha 3050, Oppo 103d, DIYSG HT12s (L,C,R), PSA mt 110s (SR,SL), 2 VBSS, Submaximus, 4 driver BOSS build, umik-1, Epson 3700
BryceDH is offline
post #207 of 1225 Old 05-24-2019, 08:02 AM
hd0823's Avatar
Quoted: 946 Post(s)
Liked: 1798
If you can build a ported box you can build one of these. That's what's great about these you get some of the benefits of a tapered or front loaded horn with out the complexity of building them. I believe the layout will be the same just bigger panels I know he put a cut list up
hd0823 is offline
post #208 of 1225 Old 05-24-2019, 09:05 AM - Thread Starter
Red Five's Avatar
Liked: 1278
Unfortunately the UM18 is not a workable driver in this cab. Huge peaks, big valley. 21DS115 HD's 18sound 21" is the next best. The Lavoce 21 I would have to model, it might be the cheapest way in if it works.
Purenv likes this.
This is the way...
Red Five is offline
post #209 of 1225 Old 05-24-2019, 09:38 AM
BryceDH's Avatar
Quoted: 176 Post(s)
Liked: 163
Good to know.. thank you!
BryceDH is offline
post #210 of 1225 Old 05-24-2019, 09:44 AM
hd0823's Avatar
Quoted: 946 Post(s)
Liked: 1798
You can use it in the submaximus v3 horn but it's very large 36 deep 80 tall 25.5 wide
BryceDH likes this.
hd0823 is offline
devastator
