Reviving the NOTHORN, a LTD02 design - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 1 Post By mhutchins
  • 1 Post By Samps
  • 1 Post By asarose247
  • 2 Post By LTD02
  • 1 Post By andyc56
post #1 of 25 Old 01-05-2019, 03:30 PM - Thread Starter
mhutchins's Avatar
Quoted: 365 Post(s)
Liked: 347
Late in 2015, @LTD02 designed a lower tuned, front loaded horn as an alternative to the LOWARHORN using a less expensive Stereo Integrity 18HT subwoofer. There was some additional discussion about the new design here. Recently i took a second look at LTD's design and tried my hand at modeling the horn with a few of the midrange B&C 21" subwoofers. It turned out that the 21DS115-4 modeled even better than the original driver in John's design. I have included the original Hornresp parameters as well as the parameters I used for the B&C driver along with their frequency response plots. The third plot is the comparison of the B&C vs. the SI driver (the B&C driver is the very faint grey line in the plot).
The original simulation was done at a time when the importance of inductance compensation was not fully understood. I'm wondering how these drivers would simulate now with appropriate inductance compensation (unfortunately the degree of compensation is beyond my level of understanding). Furthermore, I'm wondering if the DS115-4 is the optimum driver for this design given a max value of $600 and appropriate inductance compensation. I modeled the new LaVoce driver at parts Express, but it's performance was substantially worse.
Mike
Name:	NotHorn FR SI-18.png
ID:	2506360   Click image for larger version
Name:	NotHorn FR BandC 21DS115-4.png
ID:	2506362   Click image for larger version
Name:	NotHorn FR SI-18 vs BandC 21DS115-4.png
ID:	2506364   Click image for larger version
Name:	NotHorn HornResp Parameters.JPG
ID:	2506366   Click image for larger version
Name:	NotHorn HornResp Parameters BandC 21DS115-4.JPG
LTD02 likes this.
mhutchins is offline
post #2 of 25 Old 01-05-2019, 03:37 PM
Quoted: 246 Post(s)
Liked: 208
I know nothing about any of the horns but they definitely interested me. Good luck bringing this back to life. I look forward to seeing your progress.
Randy_J is offline
post #3 of 25 Old 01-05-2019, 03:42 PM
peniku8's Avatar
Quoted: 434 Post(s)
Liked: 433
Finding a 21" driver with better price to performance ratio than the 21ds115 is hard.
Seeing how the graph is flatter and outputs more SPL overall compared to the SI shows how beastly those B&C's are.
Anyways, what's the tuning of that horn?
A Star Is Born - Lady Gaga goes Rock Audio&Video by Ocean Studios (me)
SKHorn Build
Samsung KS7500 - Marantz NR1504 - Klipsch R-26F - Klipsch R-25C - Klipsch R-15M - SKHorn - BOSS
Bass EQ for Filtered Video Games
peniku8 is offline
post #4 of 25 Old 01-05-2019, 03:44 PM
jpmst3's Avatar
Quoted: 200 Post(s)
Liked: 317
I, like you, am missing the understanding of the science of it all. I am looking forward to seeing what all you can glean from this project.
Joe = LFE Addict
Past Builds: 24" LMS-5400 cube, Anarchy 25Hz Tapped Horn, Danley DTS-10 kit, BFM AutoTuba, BFM THT, BFM THT-LP
Joe's LOWARHORN build, Dual LMS-5400 Ultra Endtables build
jpmst3 is offline
post #5 of 25 Old 01-05-2019, 03:47 PM
VegaMan's Avatar
Quoted: 106 Post(s)
Liked: 81
isn't this what eventually became the submaximus? and then through aarose's building and measuring sparked the flurry of inductance adjustment techniques for making simulations more accurate for these modern super beefy drivers......if memory serves
VegaMan is offline
post #6 of 25 Old 01-05-2019, 08:27 PM
Samps's Avatar
Quoted: 1338 Post(s)
Liked: 1009
I think so. Max V3 is the latest version of this horn. Still haven't seen a great measurement of it with the DS21 though. Considering it's massive size it's understandable why nobody wants to drag it outside. Asarose did but I think he used the uxl.
It's so big. Like an actual regular sized refrigerator. We joke about fridge sized subs, but this one really is that big.
LTD02 likes this.
Samps is offline
post #7 of 25 Old 01-05-2019, 09:31 PM
chrapladm's Avatar
Quoted: 1115 Post(s)
Liked: 452
How many of these were ever built??
Horns are great if space is not a concern but budget is. I think this horn was tuned a little bit lower than the Submax horn. But again another great design for some fun.
chrapladm is online now
post #8 of 25 Old 01-05-2019, 11:10 PM - Thread Starter
mhutchins's Avatar
Quoted: 365 Post(s)
Liked: 347
The tune is in the 14-15Hz range. A search of the forum does not reveal any of these were ever built.
Mike
post #9 of 25 Old 01-06-2019, 02:51 AM
chrapladm's Avatar
Liked: 452
Also not sure this will matter but I would not use a cheap driver in 21" size in the horn. 1600/330 is on the high side for compression ratio. 1120/330 is easier and definitely fine with almost any 18 cone out there.
post #10 of 25 Old 01-06-2019, 05:25 AM
VegaMan's Avatar
Quoted: 106 Post(s)
Liked: 81
since 4 were just built and loaded with b&c 21s, if hd0823 is within an hour or so of Chicago I would volunteer to visit and measure them. he just posted a photo with a friend standing next to one, and its taller than the friend.
if it is the pre-submaximus 1. in its current iteration...maybe 7 or 8. submax is tuned to about 17hz, so im pretty sure this was the first iteration of what would become that horn.
VegaMan is offline
post #11 of 25 Old 01-06-2019, 05:34 AM
chrapladm's Avatar
Liked: 452
The Submax design has a 500 S2 so much less compression then the Nothorn sim from the first post. So if the Submax is what came of that first design then no need for this to be built. Well, unless you want to go a little wider and use dual 15's or the 21. LOL
post #12 of 25 Old 01-06-2019, 06:25 AM
jpmst3's Avatar
Quoted: 200 Post(s)
Liked: 317
I can't follow what is what here.
Can we get a rundown on what version we are talking about and the current design plans, tuning, drivers, etc?
Joe = LFE Addict
jpmst3 is offline
post #13 of 25 Old 01-06-2019, 06:43 AM
VegaMan's Avatar
Quoted: 106 Post(s)
Liked: 81
still on the hunt for something fun to do with those alpines?
VegaMan is offline
post #14 of 25 Old 01-06-2019, 03:50 PM
asarose247's Avatar
Quoted: 1340 Post(s)
Liked: 1177
I built Max V3 outside, so all testing was done once I got it onto a re-enforced / resized HF dolly. pics in my thread
that achieved thanks to @kevings
but not without some "whoa there big boy"
who also assisted in turning Max on it's side for driver installation / sealing testing and then back again forthe hatch install / testing . and running the 50 foot 12 ga. from 6k inside the home
at about 350#, moving requires some planning and smooth surfaces, and a bodacious reefer dolly
at 80" tall, while not top heavy, commands respect
As i also built Max V2 (38 ft^3), according to @LTD02 , his opinion was that there wouldn't be much noticeable difference
if he were trying to deter me, perhaps,
after all how many huge boxes can 1 HT survive anyway . .
can't wait for the results from @hd0823 . .
LTD02 likes this.
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #15 of 25 Old 01-07-2019, 09:04 PM
LTD02's Avatar
Quoted: 3035 Post(s)
Liked: 3798
awesome mike!
you'll want to model with the lossy inductance turned on for the ht-18 type driver. the ds21 will probably be somewhere in between turning on lossy inductance and not, but i'm not exactly sure which one would be closer. my guess is a little closer to the lossy inductance results.
lossy inductance can be turned on by double clicking on Le. it will turn red when turned on.
Listen. It's All Good.
LTD02 is offline
post #16 of 25 Old 01-07-2019, 09:07 PM
LTD02's Avatar
Liked: 3798
also, nd and od are different types of horns.
the one in the picture is an offset driver horn. "od"
another thing to keep and eye on is compression ratio. too low and you may tear up your driver cone.
2:1 is super conservative. 3:1 is typical. 4:1 or more may be possible with cones that are rugged. i probably would design for a slightly lower compression ratio (perhaps 3:1) and live with a little more "choppiness" in the frequency response than go too high and damage the driver.
compression ratio is cone area (sd) divided by S1 in a "nd" horn, and it is sd divided by S2 for an offset driver horn.
LTD02 is offline
post #17 of 25 Old 01-07-2019, 09:38 PM
LTD02's Avatar
Liked: 3798
the inductance effect can be seen here.
something like this kind of magnetic braking occurs with voice coils and the pole piece in woofers.
in the video the result is 'weakened gravity'. in a woofer, the result is a 'weakened motor'.
tarponater and Jan3 like this.
LTD02 is offline
post #18 of 25 Old 01-07-2019, 10:08 PM
Quoted: 17 Post(s)
Liked: 841
The inductance "white paper" that came out is not physically or mathematically valid and should never be used, and the model should be removed from hornresp because it's not valid. It suffers from a fundamental flaw. It attempts to improve inductance modeling, an issue solely confined to the electrical portion of the impedance, by modifying the motional impedance. The technique apparently used was to screw around with model parameters until the simulated frequency response became closer to that which was measured. This involved, among other things, altering the BL product, which leads to incorrect simulation of displacement and sensitivity among other parameters. One of the signatories was someone who admitted to not understanding the math at all (making the error understandable), but unfortunately, another was a very well respected member of the community.
The correct way to deal with this problem is to use the new inductance model of hornresp and its associated spreadsheet.
Thorborg gives details about this inductance modeling here.
LTD02 likes this.
andyc56 is online now
post #19 of 25 Old 01-08-2019, 11:25 AM
jpmst3's Avatar
Quoted: 200 Post(s)
Liked: 317
That's some cool science at work there. Thanks for posting that!
Joe = LFE Addict
jpmst3 is offline
post #20 of 25 Old 01-08-2019, 12:36 PM
asarose247's Avatar
Liked: 1177
+1 for the vid.
cool science, indeed . .
now, what about that V4 rumor . .?
Spoiler!
ID:	2507792   Click image for larger version
post #21 of 25 Old 01-08-2019, 11:35 PM
BassThatHz's Avatar
Quoted: 4052 Post(s)
Liked: 4571
Originally Posted by andyc56 View Post
That is a good article, however even that is STILL too oversimplified.
The problem with simulations is that you are trying to simulate a dynamic system with static parameters, and you don't even have all of the parameters that are effecting the system, such as: permeability and conductivity and distance to all materials in the motor.
You also don't know how well the motor can cool itself and how the various materials react with heat when given multiple kW...
Sim's also don't account for loss of motor force due to coil leaving the gap. You'd have to know the coil height and gap height, at a minimum.
If you want a truly accurate model, you have to quantify those, and apply the related math to the model. t/s isn't enough information!
The math that reality uses is fully-complete and all-encompassing, the math humans use is far incomplete.
Reality has no problem calculating the effects of your pet goat ramming your dust cap in the middle of a sweep or the effects of the lightning blast in your backyard, the software didn't account for that at-all...
I love how scientists make generalizations and simplifications in their models, and then wonder why it doesn't match reality.
Throughout grade school you were taught to neglect air resistance. Air resistance is very-real and non-neglectable. Among others... LOL
You can't model the universe if you don't even know where an electron "is" or if it is a "wave or a particle" or both at different times, based on observations or the lack thereof. LOL!
3-body insolvability problem, and the other unsolvable math\universe paradoxes etc etc etc... LOL!
BassThatHz is offline
post #22 of 25 Old 01-12-2019, 11:34 AM
LTD02's Avatar
Liked: 3798
in light of nothing better at the time, screwing around the model parameters is the method that was used to try to match simulated vs measured frequency response. it worked pretty well, as evidenced by hitting the frequency response target on the submaximus v3 pretty close on. the theory and math behind accurate modelling of inductance isn't a domain with which i am familiar, so if there is a better way then we should go with it.
do you happen to know if hornresp has been revised to employ the thorborg approach?
LTD02 is offline
post #23 of 25 Old 01-12-2019, 04:00 PM
LTD02's Avatar
Liked: 3798
@andyc56
thanks for the info. i just spent some time over at diyaudio reading about semi-inductance and the adjustment in hornresp. it seems that i had fallen behind.
LTD02 is offline
post #24 of 25 Old 04-23-2020, 07:36 PM
gil393's Avatar
Quoted: 106 Post(s)
Liked: 81
I am interested in this horn design. I've modeled, some horn not necessarily the one above, in hornresp using a um18-22 and 500w power. I chose this because I have two um18-22 and an amp that does two channels 500w @4ohm . The expansion ratio is 3.68. Assuming the hornresp parameters roughly matches the horn above I'd like to try building this horn. Are there full dimensions anywhere for the horn fold depicted above? I can muck around in hornresp but folding is out of my league.
I was going to add the hornresp image but adding an image is beyond my abilities. My simulation uses the parameters of the hornresp above using a OD horn and a um18-22 driver.
gil393 is offline
post #25 of 25 Old 04-24-2020, 10:28 AM
asarose247's Avatar
Liked: 1177
FTR,
Max V2 and V3 run off a 6K, 1 channel each thru a 2x4HD @ close to full throttle
and @hd0823 has his 4 using 21's and lord know how much oompah -loompah
there are better designs to take advantage of the subs and amp you have,
like the Marty sub line
BONUS : greatly reduced hernia factor
