In-floor subwoofers - 8x8" drivers each, highest WAF factor - AVS Forum | Home Theater Discussions And Reviews
 14Likes
  • 3 Post By Will P
  • 2 Post By Will P
  • 2 Post By Will P
  • 2 Post By gentlemaniac
  • 1 Post By Remy.Alexander
  • 1 Post By Will P
  • 1 Post By Will P
  • 1 Post By Will P
  • 1 Post By lknhomeaudio
post #1 of 24 Old 02-06-2019, 02:10 PM - Thread Starter
Will P's Avatar
Quoted: 20 Post(s)
I built in-floor sealed subwoofers consisting of 8 x 8" drivers each (Dayton Audio DCS 205-4). Those were the only 8" drivers which I found to fit in the subfloor cavity with a box built around them. Each sub has the cone surface area of 2 x 15" subs and 1 x 15" sub displacement. The drivers were not the reference type but I had to compromise since they were the only ones which would fit. The whole build was designed around the subfloor cavity restriction.
Will P is offline
post #2 of 24 Old 02-06-2019, 02:11 PM - Thread Starter
Will P's Avatar
Quoted: 20 Post(s)
The purpose of the subs was to use them below 40Hz. The box size gives each driver Qtc=0.9, Vb=5 Ltr, , Fb=82Hz .
When the house was still renovated and did not have the drywall installed yet I tested them both with 120Hz x-over at full displacement and they played really loud - I would say around 120dB at 120Hz. The garage floor concrete slab was shaking .
Will P is offline
post #3 of 24 Old 02-06-2019, 02:13 PM - Thread Starter
Will P's Avatar
Quoted: 20 Post(s)
Each subwoofer has 2 boxes - the first one is the "drivers head", the second box is the "cavity box". Assembled total length is 10.5ft, height 9.25", width 14".
Will P is offline
post #4 of 24 Old 02-06-2019, 02:13 PM - Thread Starter
Will P's Avatar
Quoted: 20 Post(s)
The subwoofer boxes are bolted together and have a removable cover for bolts access. They were installed in the basement ceiling - between the floor joists. The boxes are separated from the floor structure and don't transfer vibrations to the house. The drivers are mounted opposed to each other to cancel any vibrations too. The boxes are suspended by multiple metal straps (like a swing cradle). For safety there are aircraft cables spun across the bottom too (not tensioned, slightly loose and taped to the boxes to prevent rattling).
Will P is offline
post #5 of 24 Old 02-06-2019, 02:14 PM - Thread Starter
Will P's Avatar
Quoted: 20 Post(s)
The subwoofer ports are covered with the same covers used for the heating ducts in the house and you can't tell that they are there.
When there was no furniture in the house yet you could feel the floor bending from the air pressure whenever the subs played.
Will P is offline
post #6 of 24 Old 02-06-2019, 02:22 PM - Thread Starter
Will P's Avatar
Quoted: 20 Post(s)
Now when I have them set up below 40Hz they are enough for movie playing. For this open floor plan and the music levels I enjoy occasionally though I would need 4x that displacement. That's why there is another project on the go for few years already - but that's another topic altogether https://www.avsforum.com/forum/image..._face_wink.png .
ID:	2521256   Click image for larger version
ID:	2521258   Click image for larger version
ID:	2521260   Click image for larger version
ID:	2521262   Click image for larger version
ID:	2521266   Click image for larger version
ID:	2521268   Click image for larger version
ID:	2521270   Click image for larger version
ID:	2521272   Click image for larger version
neo_2009, OJ Bartley and head_unit like this.
Will P is offline
post #7 of 24 Old 02-06-2019, 02:25 PM - Thread Starter
Will P's Avatar
Quoted: 20 Post(s)
.. more pics ...
ID:	2521276   Click image for larger version
ID:	2521278   Click image for larger version
ID:	2521280   Click image for larger version
ID:	2521282   Click image for larger version
ID:	2521286   Click image for larger version
ID:	2521288   Click image for larger version
ID:	2521290   Click image for larger version
ID:	2521292   Click image for larger version
neo_2009 and lknhomeaudio like this.
Will P is offline
post #8 of 24 Old 02-06-2019, 02:27 PM - Thread Starter
Will P's Avatar
Quoted: 20 Post(s)
... some more pics ...
ID:	2521296   Click image for larger version
ID:	2521298   Click image for larger version
ID:	2521300   Click image for larger version
ID:	2521302   Click image for larger version
neo_2009 and jamiebosco like this.
Will P is offline
post #9 of 24 Old 02-06-2019, 02:53 PM
Quoted: 57 Post(s)
Would love to be a fly on the wall when these are going. That build is dedication for you. Somebody's gonna say put some 18's in there.
gentlemaniac is offline
post #10 of 24 Old 02-06-2019, 03:22 PM - Thread Starter
Will P's Avatar
Quoted: 20 Post(s)
There is a new project going on for the last 3 years: Open Baffle Line Array (L/R) in the same living room.
Speakers: Dayton Audio RSS265HO-4 (x32; infrasubs, L/R Line Array), Dayton Audio RSS265HF-8 (x32; woofer subs, L/R Line Array), Dayton Audio RS100T-8 (x48; mids, L/R Line Array); Dayton Audio AMT PRO-4 (x20; tweeters, L/R Line Array); Dayton Audio DCS205-4 (x16; in-floor subs); PSB CW383 (x4; surrounds);
Amplifiers: Behringer NU4-6000 (x6) - infrasubs and subs amps; Crown XLS 1500 (x4); Crown XLS 2500; Crown XTi4002;
Total power: 36kW
I just have to find the time to put them together.
Will P is offline
post #11 of 24 Old 08-24-2019, 06:49 PM - Thread Starter
Will P's Avatar
Quoted: 20 Post(s)
Infrasubs will be sealed boxes, xover 45Hz - 2 Line arrays
Subs will be OB, xover 45-250Hz - 2 Line arrays
Mids will be OB, xover 250-1.6kHz
Tweeters will be OB, xover 1.6kHz
Mids and Tweeters - 2 Line Arrays
Line Arrays height - 86in
All that stuff is still piled up in the basement for the last 3 years.
Recently I had to rotate the boxes since the bottom ones started collapsing.
Will P is offline
post #12 of 24 Old 08-24-2019, 07:17 PM
Quoted: 172 Post(s)
Liked: 52
Awesome work, That is defiantly one way around that WAF thing.
Will P likes this.
Remy.Alexander is offline
post #13 of 24 Old 08-24-2019, 07:30 PM - Thread Starter
Will P's Avatar
Quoted: 20 Post(s)
One can never be too WAF
Will P is offline
post #14 of 24 Old 08-24-2019, 11:53 PM
Quoted: 202 Post(s)
Liked: 109
Amazing solution. Does all the sound come through those two vents? Do hear any chuffing at high SPL?
bochoss is offline
post #15 of 24 Old 08-25-2019, 07:13 AM
kagtha's Avatar
Quoted: 120 Post(s)
Liked: 131
Simply unbelievable. Does OB mean open baffle?
Sent from my Pixel 3a using Tapatalk
Bedroom: Simple 5.1 setup using MLT-2 LCR & Surrounds, some hidden DIY shallow 12's, a couple BST Bass Shakers, most importantly a PB875 Enso Power Base.
DIY Living Room: One 800 lb. VBSS credenza, 3 horizontal Elusive 1099s, a couple non-traditional HT-8 as wedges for height duty, and some DIY Volt 6 Surrounds.
kagtha is online now
post #16 of 24 Old 08-25-2019, 04:08 PM - Thread Starter
Will P's Avatar
Quoted: 20 Post(s)
Yes, those are the subwoofers vents. The opening is 4inx12in when cover removed. There is some chuffing at high SPL although for casual listening in the living room (at -15 db) they are still fine.
The in-floor subs are my "Plan C" - for whenever "Plan A" (Line arrays in the Living Room) and "Plan B" (reduced Line Arrays in the Living Room) are rejected and I end up hauling all the boxes to the basement . In that case I would still have some subwoofers with the TV on the main floor.
lknhomeaudio likes this.
Will P is offline
post #17 of 24 Old 08-25-2019, 10:00 PM
Quoted: 202 Post(s)
Liked: 109
Do you hear the chuffing with the vent covers removed, or only with them on? Do you always remove them when listening?
bochoss is offline
post #18 of 24 Old 08-25-2019, 10:24 PM - Thread Starter
Will P's Avatar
Quoted: 20 Post(s)
The vent covers stay in place. I placed the tower speakers so they keep the vent covers in place with one corner so vent covers not to rattle (you can see it in the pictures). You can feel the air moving through the vents when playing but no chuffing sound. That might be due to the fact that the actual drivers opening inside is 4in x 8in (the channel you see on the pictures).
Again, that is "casual" listening. The subwoofers are probably -10dB from their Xmax.
If you start playing them at Xmax there is still no chuffing noise but you can start hearing the compression inside (distortion due to compression) which is to be expected.
Extra bonus is the increased low frequency output from the tower speakers (down firing ported 2.5 way; 2x6.5in, 1in). It's due to the subwoofer cavity 4in x 8in x 40in which is right below the tower speakers base.. Everybody in the house noticed that right away. It's a nice LF extension, not boomy at all.
bochoss likes this.
Will P is offline
post #19 of 24 Old 08-26-2019, 01:27 PM
lknhomeaudio's Avatar
Quoted: 287 Post(s)
Liked: 148
Total power: 36kW
Cheese us! haha
lknhomeaudio is offline
post #20 of 24 Old 08-26-2019, 05:08 PM - Thread Starter
Will P's Avatar
Quoted: 20 Post(s)
The in-floor subwoofers got built and installed in 2011.
It took me from 2011 until 2015 for the OB Line Array project design to solidify.
It's now 2019 and the drivers are still in the shipping boxes and unpacked. All my free time went into helping my wife with finishing the house renovation.
I hope I find some time in the next few years to put them together.
... someone said "Music is Art, Sound is Engineering" ...
Will P is offline
post #21 of 24 Old 08-26-2019, 07:36 PM
Quoted: 287 Post(s)
Liked: 148
I hope you do, as well!
Will P likes this.
post #22 of 24 Old 08-27-2019, 06:36 AM
OJ Bartley's Avatar
Quoted: 480 Post(s)
Liked: 574
That's an awesome idea, and it looks like you did a great job with it. I remember seeing an ad for a really high end in-wall subwoofer system that did something similar. I think it might have been a bunch of 6" drivers or something...
Yep, it was the BG Radia BGX-4850 system. Looks like it used twelve 4" woofers and cost $7,000 back in 2009. I'd say you put together a great alternative.
https://www.soundandvision.com/inwal...bwoofer_system
Ah, I see now that the 4840 system actually uses four of the 12-driver modules, for a total of 48 drivers. How many more of these can you fit in the room???
OJ Bartley is offline
post #23 of 24 Old 08-27-2019, 11:24 AM - Thread Starter
Will P's Avatar
Quoted: 20 Post(s)
Yes, the Line Arrays are to be Open Baffle type.
Will P is offline
post #24 of 24 Old 08-27-2019, 05:42 PM - Thread Starter
Will P's Avatar
Quoted: 20 Post(s)
Well, if it was up to me I would have put 8 in-floor subwoofers, spaced 32in on center..
Knowing well that I was facing an uphill battle I entered the negotiations asking for 5 subwoofers. My wife cooperated.. At the end I got permission to have 2 subwoofers installed. Great! 2 is better than none
Will P is offline
