Building my theater audio setup: B52-18s and Cinema-10s - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 220Likes
post #61 of 196 Old 04-06-2019, 10:37 PM - Thread Starter
Craig S King's Avatar
Quoted: 351 Post(s)
Liked: 498
I screwed up the design of the cabinet and had visible ends of the panels showing. I made some changes and used leftover material to make a second "top" panel.
Double top panel!
ID:	2549952   Click image for larger version
Jk7.2 and bubbrik like this.
Craig S King is offline
post #62 of 196 Old 04-06-2019, 10:41 PM - Thread Starter
Quoted: 351 Post(s)
Liked: 498
Finished painting the baffles and did a rough fit of the driver.
ID:	2549956   Click image for larger version
eng-399, Jk7.2 and bubbrik like this.
post #63 of 196 Old 04-06-2019, 10:46 PM - Thread Starter
Quoted: 351 Post(s)
Liked: 498
I started attaching the legs.
ID:	2549960   Click image for larger version
ID:	2549962   Click image for larger version
eng-399, Jk7.2, bubbrik and 1 others like this.
post #64 of 196 Old 04-07-2019, 04:59 AM
Jk7.2's Avatar
Quoted: 1387 Post(s)
Liked: 2536
Nice work! I’m getting excited to see them done. I can imagine you are too. And hey, mistakes happen. My last sub build was the first of a dozen where I didn’t get the cutlist wrong in some way or another. And just last night, I found a glob if duratex right on the top panel of my 893 center channel speaker. I had to sand it off and recoat the veneer. Oh well, as long as you don’t get frustrated you’ll always get the project done! Keep up the good work.
Jk7.2 is online now
post #65 of 196 Old 04-09-2019, 07:07 PM - Thread Starter
Quoted: 351 Post(s)
Liked: 498
I got all of the legs on, and did the trim. Started wood-filling all the holes.
And don't worry - I still plan on making faux-doors for the sides.
ID:	2551064   Click image for larger version
post #66 of 196 Old 04-09-2019, 07:18 PM - Thread Starter
Quoted: 351 Post(s)
Liked: 498
Had two packages arrive in the mail the other day.... wonder what's in this box?
Jk7.2 and kagtha like this.
post #67 of 196 Old 04-10-2019, 03:29 AM
Jk7.2's Avatar
Liked: 2536
I love this project. You’ll love this setup. I’m so happy you’ll be dealing with the packaging flying all around from unwrapping those cinema 10’s!
I still find the foam around my yard from blowing out of the garbage. Lol
Craig S King likes this.
Jk7.2 is online now
post #68 of 196 Old 04-10-2019, 11:38 AM
Quoted: 146 Post(s)
Liked: 66
Erich comes out and picks up the foam chips for you I hear, just ask him or add it to the order notes haha!
@EricH
Sent from my iPhone using Tapatalk Pro
Jk7.2 and Craig S King like this.
FOHTech is offline
post #69 of 196 Old 04-10-2019, 12:15 PM
BP1Fanatic's Avatar
Quoted: 161 Post(s)
Liked: 129
CSK, those end tables came out nice!
FOHT, I hope you post your TH experiment!
Jk7.2, your HT is AWESOME!
Sony XBR65x900e / STR-DN1080 / original PS4 / WOW! Ultra TV / Quantum Access Mini PC Stick w/Windows 10 / 8 x Rockville SPG88 8“ DJ PA Speakers / Dayton Audio SA1000 / Kicker 08S15L74 in a Tapped-Tapered Quarter Wave Tube (negative flare tapped horn).
BP1Fanatic is offline
post #70 of 196 Old 04-25-2019, 05:23 PM - Thread Starter
Quoted: 351 Post(s)
Liked: 498
Ok, so thanks to Jk for reminding me, here's a much overdue update:
1. I got both cabinets sanded down including the wood filler spots and ready for stain.
2. I flush-mounted the speakon terminals and got them wired.
3. I got the Cinema10s completely unpacked and checked them over.
ID:	2558256   Click image for larger version
ID:	2558258   Click image for larger version
ID:	2558260   Click image for larger version
post #71 of 196 Old 04-25-2019, 05:27 PM - Thread Starter
Quoted: 351 Post(s)
Liked: 498
A 15/16" hole and a 1-1/2" recessed hole work great for flush mounting speakon terminals.
It's funny to be building cabinets and paying so much more attention to detail, such as painting the recessed hole for the terminals. The attention to detail pays off when you see the finished product.
ID:	2558266   Click image for larger version
Jk7.2, bubbrik and notfastenough like this.
post #72 of 196 Old 04-25-2019, 06:41 PM
Stereodude's Avatar
Quoted: 4139 Post(s)
Liked: 2941
Why didn't you use a router with an appropriate bit to get a recess with the proper matching shape matching the connector instead of that ?
kagtha likes this.
Stereodude is online now
post #73 of 196 Old 04-25-2019, 06:46 PM
smcmillan2's Avatar
Quoted: 776 Post(s)
Liked: 678
Nice!
For future builds you may want to look into the NL4MPR. They seal up nicely without using caulk/weather stripping, and look a bit more finished IMHO: https://www.parts-express.com/neutri...mount--092-054
smcmillan2 is online now
post #74 of 196 Old 04-25-2019, 10:14 PM
Liked: 0
[quote=Craig S King;57761986Got the ports finished:
[/quote]
Would you mind sharing your port dimensions? I'm building a similar ported setup with B-52's
grantpab is offline
post #75 of 196 Old 04-26-2019, 03:46 PM - Thread Starter
Quoted: 351 Post(s)
Liked: 498
I was going for more of an abstract, post-modern hypotenuse coefficient look on the terminals. Consequently, the round recessed holes seemed to meet my requirements.
Plus, it's on the baffle surface which faces the floor and will never be seen.
Originally Posted by smcmillan2 View Post
Nice!
I looked at those terminals, but went with the ones that didn't require spade terminal connections. I got the terminals that have the set-screw that holds the wires in place.
I recall the cabinets being roughly 5.5cu/ft with a 25.5hz tune. The internal dimensions of the port are 1.75" x 20" with two port rails both .75" thick. The port is 21" long.
Are you friends with Tarpenator? He was telling me about someone building a similar setup.
Thank you - I'm excited for them to be done. I'm hopeful I can finish them this weekend actually.
post #76 of 196 Old 04-26-2019, 09:06 PM - Thread Starter
Quoted: 351 Post(s)
Liked: 498
Cinema10 porn:
Pretty impressed with the precision of the CNC baffles.
Some of the components laid out:
I showed Diesel the woofer for the Cinema10 and his response was, "Where's the rest of it?"
ID:	2558664   Click image for larger version
ID:	2558666   Click image for larger version
ID:	2558668   Click image for larger version
post #77 of 196 Old 04-27-2019, 10:18 AM
BP1Fanatic's Avatar
Quoted: 161 Post(s)
Liked: 129
Not enough WOOFer!
post #78 of 196 Old 04-30-2019, 06:54 PM - Thread Starter
Quoted: 351 Post(s)
Liked: 498
Got some more work done over the weekend. And actually, the subwoofer cabinets are pretty much done now. I'm gearing up to get the Cinema10s started soon.
I tried something new and went with the Minwax Polyshades, which is stain and polyurethane in one. Still needs at least two coats.
One coat:
Second coat really darkened it up and started to bring glossier finish:
One coat vs. second coat:
Looking back at it, I'm not sure I would do the polyshades again. I'm not sure if I like the appearance of the stain portion of it. It was very difficult to apply it evenly and not leave crazy amounts of brush marks. The second coat definitely was the savior, but obviously darkened it up a lot. I did like NOT having to go back and apply polyurethane one side at a time. For anyone who has applied poly, if you do it to a vertical surface, it'll end up running before it dries. Consequently you have to apply it horizontally, and in my case that would've meant doing one side at a time and allowing drying time in between.
And yes, to the keen observer, you'll notice I did not add the faux-doors onto the cabinets. I still think they would've looked nice and added to the overall appearance, but truthfully, I was getting tired of working on these things and just wanted to be done with them and get them home to start using.
ID:	2560806   Click image for larger version
ID:	2560808   Click image for larger version
eng-399, bear123, Jk7.2 and 2 others like this.
post #79 of 196 Old 04-30-2019, 07:34 PM
smcmillan2's Avatar
Quoted: 776 Post(s)
Liked: 678
Looks good Craig!
As you noted, I don't think the Polyshades line is the way to go. I used it once when it came out years ago, didn't care for it. You can't get the color profile you want like you can with careful applications of stain, and going over it the second time did not give me the results I was looking for.
I use a foam brush and make sure I apply very thin coats, and it won't run on you. Next builds I will be going with Waterlox after seeing the finish on Jared's 893s, if I can get the hang of it I will probably never go back to poly (and I've relied on Minwax poly for at least the past 3 decades, Jared's finish looked that good).
Jk7.2 likes this.
post #80 of 196 Old 05-01-2019, 03:53 AM - Thread Starter
Quoted: 351 Post(s)
Liked: 498
Looks good Craig!
Thanks, yeah, the first coat of the polyshades was actually closer to the actual color that I wanted. But as mentioned, a second coat is required. And once you apply a second coat, the appearance almost looks like paint. Very little wood grain could be seen. And I used a light colored wood to begin with. I can't imagine using a darker color polyshade.
As for the foam roller, I guess I never thought about trying that for applying polyurethane. I might try that when staining and polyurethaning the Cinema10s. I wanted to try the Waterlox as well, after seeing Jk's results with it, but couldn't find it at my local Lowes. So for now, the cabinets will obviously stay Polyshaded, and I'll go back to regular Minwax stain for the Cinema10s with a polyurethane finish.
Jk7.2 likes this.
post #81 of 196 Old 05-01-2019, 04:19 AM
Jk7.2's Avatar
Liked: 2536
Look for waterlox at you local professional woodworking shop. I got mine from WoodCraft. It’s 50 bucks for a quart, but I just love this stuff. I did a test panel with ebony stain, covered with waterlox and I really like the look. It shows less grain for sure, but same satin finish, and its almost black in the shadows. In direct lighting, it shows up deep brown. I’m thinking about using that finish process on my htm build. We’ll see.
Great progress on these! I like the look. Even without doors, they just look like furniture. What a great way hide subs.
Jk7.2 is online now
post #82 of 196 Old 05-01-2019, 04:51 AM
smcmillan2's Avatar
Quoted: 776 Post(s)
Liked: 678
Just to clarify, I use foam brushes, not rollers. Rollers will produces (many more) bubbles.
ETA: Rockler carries Waterlox: https://www.rockler.com/waterlox-ori...n-finish-quart. I happen to have one local to me.
post #83 of 196 Old 05-01-2019, 07:33 PM - Thread Starter
Quoted: 351 Post(s)
Liked: 498
Thank you - Overall I'm pretty happy with how they turned out. They are done now and definitely have the "furniture" look I was hoping for.
I see now, I misread. I'll have to look into using foam brushes. I think I have some of those around here. Thanks for the tip.
Jk7.2 likes this.
post #84 of 196 Old 05-01-2019, 07:44 PM - Thread Starter
Quoted: 351 Post(s)
Liked: 498
After wet sanding with some 800grit, another coat of polyshade, then wetsanding again, and then a final coat of polyurethane on the top surface, they are finally done. I was pretty happy with the final finish.
I've definitely never put this much time into the finish of something I've built, whether it was an actual wooden project or a subwoofer cabinet. I was very happy with the smoothness of the top surface. The multiple coats of finish with 800grit wetsanding in between definitely paid off. I'm now in the mindset of "I hope nobody scratches the surface of my cabinets."
ID:	2561282   Click image for larger version
post #85 of 196 Old 05-02-2019, 10:11 PM
BP1Fanatic's Avatar
Quoted: 161 Post(s)
Liked: 129
VERY nice!
post #86 of 196 Old 05-04-2019, 08:43 AM - Thread Starter
Quoted: 351 Post(s)
Liked: 498
VERY nice!
Thank you. Overall, I'm happy with how they turned out. Definitely different than I had originally imagined, but I think I like them more now.
In other news, I got one of them in place today.
sealmaniac and bubbrik like this.
post #87 of 196 Old 05-04-2019, 08:56 AM - Thread Starter
Quoted: 351 Post(s)
Liked: 498
I wired up and installed the B52s and got them into place. I'm happy with how they turned out as end tables.
And it's funny, being that they are actual wood tops and knowing all the time and effort I put into them, I'm much more cautious with them. Like... make sure you use a coaster under your drink!
ID:	2562320   Click image for larger version
ID:	2562322   Click image for larger version
bear123 and bubbrik like this.
post #88 of 196 Old 05-04-2019, 12:16 PM
Quoted: 146 Post(s)
Liked: 66
Great job!!! How do they perform?
They look fantastic.
FOHTech is offline
post #89 of 196 Old 05-04-2019, 01:37 PM
Jk7.2's Avatar
Liked: 2536
Dang lookin good! Have you had a listen yet?
Jk7.2 is online now
post #90 of 196 Old 05-05-2019, 08:12 PM - Thread Starter
Quoted: 351 Post(s)
Liked: 498
Thank you. Now that they are both home and in place, I'm growing more happy with how they turned out appearance wise. I'm looking forward to having some friends over and see if they notice them and/or what they think of them. And then the more obvious thing, I'm curious if they'll figure out where the bass is coming from.
EDIT: Quick performance review: very happy. A better review coming in the next few days hopefully.
As far as listening and performance, I hooked both of them up to my NX3000DSP and started playing with them. I was majorly impressed with the tactile feel between feeling the floor shake and my sofa shaking. When sitting on my sofa, the bass is pretty impressive. Even with both volume knobs at only 11 o'clock, they sound like I need to worry about pictures falling off the walls and my neighbors calling the police. Interestingly though, they don't have the mid-bass punch I thought they would have.... at least yet. I'm sure I need to adjust the DSP before making any judgements. However for some classic bass music on youtube, they sound group. The club scene from John Wick 2, not much bass.
However, my NX3000 is still set for a pair of 31hz VBSSs on one channel, and a mini-marty on the other channel. So I need to tweak the DSP for these B52s at 25hz. The other part of is, since I only have one NX3000DSP so far, I can't power my subs upstairs for my audio setup. Once I'm closer to finishing the Cinema10s, I'll get an AVR and another NX3000DSP.
Jk7.2 and grantpab like this.
