Building my theater audio setup: B52-18s and Cinema-10s - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 221Likes
post #151 of 197 Old 05-19-2019, 07:05 PM
imrf's Avatar
Quoted: 213 Post(s)
Liked: 144
Originally Posted by Craig S King View Post
That makes sense. Just trying to find an option so you can buy something now and start building!
I appreciate it. It’s the whole, you snooze you lose game, and I lost. Lol
imrf is offline
post #152 of 197 Old 05-20-2019, 07:12 PM - Thread Starter
Craig S King's Avatar
Quoted: 407 Post(s)
Liked: 522
Looking forward since hopefully I'll finish my Cinema Towers in the next week or two, I need to order a AVR.
How does this unit look?
https://www.accessories4less.com/mak...-w/heos/1.html
It'll do 4k pass-through, Atmos and is a 7.2 even though I'll only be doing a 2.1 setup for the time being.
Craig S King is offline
post #153 of 197 Old 05-20-2019, 07:42 PM
imrf's Avatar
Quoted: 213 Post(s)
Liked: 144
Personally, wouldn’t get one without audessy xt32, especially if you plan on doing a full system. I picked up the denon 3500 from them not too long ago.
On a good note. Erich said he thinks he has more HT10s in the back and will look. Just waiting for an definitive answer then hopefully I can order em up
Craig S King likes this.
imrf is offline
post #154 of 197 Old 05-20-2019, 08:01 PM - Thread Starter
Quoted: 407 Post(s)
Liked: 522
Is Audyssey MultEQ something different than the xt32? I'll be honest, I'm not very familiar with Audyssey and what it does.
And that would be great if he finds a couple HT10s in the back for you!
post #155 of 197 Old 05-20-2019, 08:52 PM
imrf's Avatar
Quoted: 213 Post(s)
Liked: 144
MultiEQ doesn’t do 2 subs separately. It’s for room correction. XT32 is the better one.
Yeah it would be awesome.
imrf is offline
post #156 of 197 Old 05-21-2019, 04:30 AM - Thread Starter
Quoted: 407 Post(s)
Liked: 522
Are the Audyssey options only really something to consider if I plan on actually running Audyssey? Or is it built into the AVR already?
post #157 of 197 Old 05-21-2019, 05:03 AM
Jk7.2's Avatar
Quoted: 1523 Post(s)
Liked: 2738
It’s the receivers built in auto room calibration. I’d want it. Even for resale value. I think most receivers come with some form of auto cal.
imrf and Craig S King like this.
Jk7.2 is offline
post #158 of 197 Old 05-22-2019, 07:08 PM - Thread Starter
Quoted: 407 Post(s)
Liked: 522
Thanks for the feedback guys. Figuring out Audyssey will be a whole new challenge for me. As for having the XT32, unfortunately getting an AVR with that feature almost doubles the price and bumps it out of my price range.
post #159 of 197 Old 06-03-2019, 03:25 PM - Thread Starter
Quoted: 407 Post(s)
Liked: 522
Another update:
The Cinema Towers are coming together nicely and should be done very soon.
Drilled and recessed the holes for the terminal plates.
Also put the compression driver and waveguides together.
Painted the baffles and pre-drilled the driver mounting holes.
- I also ordered a Denon AVR and digital optical cable to connect to my TV
ID:	2575490   Click image for larger version
ID:	2575492   Click image for larger version
ID:	2575494   Click image for larger version
ID:	2575496   Click image for larger version
eng-399 likes this.
post #160 of 197 Old 06-03-2019, 03:26 PM
Jk7.2's Avatar
Liked: 2738
Great update! Looking real good! Keep it going your getting closer...
Jk7.2 is offline
post #161 of 197 Old 06-03-2019, 04:01 PM
johnson636's Avatar
Quoted: 1231 Post(s)
Liked: 709
I'm jealous. Great job!
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #162 of 197 Old 06-03-2019, 08:15 PM - Thread Starter
Quoted: 407 Post(s)
Liked: 522
Thanks Jk. Your current and previous projects have definitely been a major inspiration and motivation for me.
Thank you. I've been jealous of so many other guys' theater and speaker setups, that I finally decided to build one of my own. I'm flattered someone would say that about mine.
post #163 of 197 Old 06-04-2019, 06:37 AM - Thread Starter
Quoted: 407 Post(s)
Liked: 522
2 Questions for the near future:
1. I currently have a 4K smartTV. For watching netflix, it plays through my TV. For watching DVDs, I use my PlayStation which is connected to my TV through HDMI. However, as best as I can tell, my TV only has HDMI inputs. No outputs. So would I run my PlayStation to the Denon AVR through HDMI, then into my TV? For hi-def audio out from my TV, should I use the digital optical output? And connect that to the AVR? Is that the optimum setup? Or use the 3.5mm audio output?
2. The gasket tape that came with my cinema10s, that’s for the wave guide, correct? And I apply the tape to the baffle, then install the wave guide?
post #164 of 197 Old 06-04-2019, 06:54 AM
johnson636's Avatar
Liked: 709
Yes. That is all you need to do
post #165 of 197 Old 06-04-2019, 06:57 AM
Adam Clark's Avatar
Liked: 8
1) In general if you have a receiver all of your source devices should plug into it and run one hdmi from the receiver to the TV (or projector) for video. If you have sources where that is not possible to plug into the receiver first (antenna for over the air tv that requires the tv tuner for example), and both your TV and Receiver support ARC, you can send the audio to the receiver along that same HDMI cable. So you no longer need a separate cord for running audio back from the TV to the receiver. Otherwise, optical audio is another good option, and is a better than the 3.5mm output.
2) I havent built any DIYSG speakers so I am not sure on number 2, but for what its worth that sounds right, assuming the speakers come with gasket pre-installed on the back of them. Both the speakers and the waveguide should have some sort of gasket between them and the wood.
UPDATE: I updated my response to 1) thanks to user "imrf" pointing out that ARC exists, not sure how that slipped my mind
Adam Clark is offline
post #166 of 197 Old 06-04-2019, 07:56 AM
Jk7.2's Avatar
Liked: 2738
Here is a pic of my gasket I put behind my waveguide.
As I recall, my cinema 10’s didn’t require a gasket on the woofers. They had something on them already.
Jk7.2 is offline
post #167 of 197 Old 06-04-2019, 08:12 AM - Thread Starter
Quoted: 407 Post(s)
Liked: 522
Johnson636 - Thanks for the feedback.
Adam Clark - Ok, thanks for clarification. I’ll use the digital optical cord to get sound from my TV to the AVR.
Jk - Thank you, yes that is the correct. The woofers already have a gasket on them. I’ll apply the gasket tape to the baffle.
post #168 of 197 Old 06-04-2019, 08:55 AM
imrf's Avatar
Quoted: 213 Post(s)
Liked: 144
You don’t need to use an optical cable for that. Use the ARC input on your tv from your receiver and the tv will pass audio to the receiver. Read the manual of the tv to find out which one supports arc and you should be good to go. Less fuss.
imrf is offline
post #169 of 197 Old 06-04-2019, 08:56 AM
imrf's Avatar
Quoted: 213 Post(s)
Liked: 144
Is that tape from PE or somewhere else?
imrf is offline
post #170 of 197 Old 06-04-2019, 09:30 AM
Jk7.2's Avatar
Liked: 2738
Comes with the kits. From DIYSG
imrf likes this.
Jk7.2 is offline
post #171 of 197 Old 06-04-2019, 09:46 AM - Thread Starter
Quoted: 407 Post(s)
Liked: 522
I’ll check when I get home, but I don’t recall seeing an ARC plug. Are you saying that an ARC plug can be both input and output? Even if it’s listed as an input? IIRC, my tv didn’t have any HDMI outputs.
post #172 of 197 Old 06-04-2019, 10:14 AM
Adam Clark's Avatar
Liked: 8
It totally slipped my mind that ARC exists, thanks imrf, yes he is saying that a single HDMI port can both send video from the receiver to the TV, and audio from the TV to the receiver. If your TV supports it, it will usually be labeled next to the input, and should be mentioned in the manual. All HDMI ports do not support it. Pic below for example.
Jk7.2 and Craig S King like this.
post #173 of 197 Old 06-04-2019, 10:51 AM - Thread Starter
Quoted: 407 Post(s)
Liked: 522
Adam & imrf - thanks for the info. I’ll check when I get home. I think I remember seeing an ARC plug, but I thought it was labeled as an input. So I’ll run an HDMI from the ARC plug to my AVR, but only for the sound signal basically? And the digital optical cord I already got, I don’t need?
post #174 of 197 Old 06-04-2019, 11:01 AM
imrf's Avatar
Quoted: 213 Post(s)
Liked: 144
Correct. ARC is a two way port. It sends audio and video between the two.
imrf is offline
post #175 of 197 Old 06-04-2019, 11:05 AM - Thread Starter
Quoted: 407 Post(s)
Liked: 522
Does ARC support a 5.1 or 7.2 Atmos setup?
post #176 of 197 Old 06-04-2019, 11:28 AM
Red Five's Avatar
Quoted: 633 Post(s)
Liked: 391
http://community.cedia.net/blogs/dav...-over-hdmi-arc Maybe.
Stormbreaker | Wisconsin Home Theater Meet Thread | The Devastator Index
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | Yamaha A3070 | Crown XLS 1502 | iNuke 3000 DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Sub 21" Stormbreaker | Epson 5010e | 120" DIY AT Screen
Red Five is offline
post #177 of 197 Old 06-04-2019, 11:51 AM
Quoted: 44 Post(s)
Liked: 34
Originally Posted by Red Five View Post
Good info, thanks for sharing
scottvalentin is offline
post #178 of 197 Old 06-04-2019, 12:04 PM
Quoted: 159 Post(s)
Liked: 163
In review....
Plug your playstation into one of your HDMI ports on your receiver.
Plug your receiver's HDMI output to your TV's ARC input.
Drink a beer.
As long as your receiver and TV support ARC, you won't need to do anything else. The HDMI cable between your TV and receiver becomes a two-way street.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Volt-10 - Micca M-8C for ATMOS
2 @ VBSS End Tables - 2 More VBSS on the Way
DIY 110" AT Screen
jevchance is offline
post #179 of 197 Old 06-04-2019, 01:44 PM
imrf's Avatar
Quoted: 213 Post(s)
Liked: 144
eARC does. Most TVs don’t output Atmos anyways and optical won’t either.
imrf is offline
post #180 of 197 Old 06-04-2019, 06:12 PM - Thread Starter
Quoted: 407 Post(s)
Liked: 522
Ok, checked my TV and I do have a "4K ARC HDMI" port. I'll plan on using that to the AVR. Now I just need to get the Cinema Towers finished and wait for my AVR to arrive!
