Any contraindications to placing a handle on a Stonehenge Sub Box? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-13-2019, 01:00 AM - Thread Starter
video1's Avatar
Quoted: 153 Post(s)
Liked: 27
The box and driver are quite hefty. I'd like to have some sort of handle on either side to help move these things (the few times I need to).
Silly question, but is it ok to cut out an indent in the MDF to install these handles?
Are they strong enough? Will the screws hold?
Any affect on the sound?
https://www.parts-express.com/penn-e...black--260-701
video1 is offline
post #2 of 6 Old 02-13-2019, 03:05 AM
Quoted: 143 Post(s)
Liked: 122
I'd put some kind of gasket between the handles and the MDF to prevent air leaks. The minor amount of volume they take up won't affect anything.
If you pre-drill the holes, coarse drywall screws will likely hold just fine.
dorri732 is offline
post #3 of 6 Old 02-13-2019, 03:51 AM
VegaMan's Avatar
Quoted: 103 Post(s)
Liked: 79
pretty much this. if you are worried about the hold of the screws in just 3/4" mdf, you can glue small strips of plywood or similar to the sides of the cut out inside the box.
VegaMan is offline
post #4 of 6 Old 02-13-2019, 04:44 AM
Quoted: 182 Post(s)
Liked: 142
Only thing i can think of is just don't put in the slot port area. I know it is obvious but just wanted to make sure to point it out .
Randy_J is online now
post #5 of 6 Old 02-13-2019, 08:43 AM
Quoted: 348 Post(s)
Liked: 486
eng-399 built me a 15+cft monster cyclops and i asked him to install handles. After it was done he said he would add handles to all his larger builds going forward. We added one to each side much like a pro cabinet would have, al though most pro cabinets are not 8 feet wide 😏
#eng-399 did you need to add a gasket or other item to the handles?
All i can say is that monster cabinet is an eng399 build, which means its perfect and built like a tank. He estimated 300lbs and we carried it up outside stairs as well as 2 dudes could! Worked great and cant imagine not having handles!
RoboAVS is offline
post #6 of 6 Old 02-13-2019, 12:07 PM - Thread Starter
video1's Avatar
Quoted: 153 Post(s)
Liked: 27
Thanks for the replies. I feel better now!
My old back can't deal with the weight of the box and the driver. At least the handle will allow me to move the thing around a bit.
video1 is offline
