AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   DIY Speakers and Subs (https://www.avsforum.com/forum/155-diy-speakers-subs/)
-   -   Beyma TPL-150H Long shot ! (https://www.avsforum.com/forum/155-diy-speakers-subs/3050332-beyma-tpl-150h-long-shot.html)
dashpuppy 02-13-2019 06:14 PM
I know this might be a long shot but I do see that lots of people on here have used these Beyma TPL-150's. Does anyone have any measurement files to share with ? I'm "thinking" about buying a pair and building a pair of speakers with them. Id be using the Satori WO24P-8 9.5" woofer in a 2 way..
Thanks In Advance.
LTD02 02-13-2019 06:22 PM
@Javs
dashpuppy 02-13-2019 06:24 PM
Originally Posted by LTD02 (Post 57600002)
@Javs
Thanks sir ! Crossing fingers :)
Just building a test xover to see if it will work, don't want to spend 1200$ on tweeters and they not work good.
Javs 02-13-2019 07:44 PM
Are you going to use two of those woofers in each box?
Because the sensitivity is only 88db, you are going to need to pad the **** out of the TPL to get them down to the level you need, bit of a wasted opportunity IMO... Might want to look into a much more high quality high efficiency woofer. You can cross the TPL as low as 1200 hz pretty comfortably.
Check out some of my builds in my sig to see how they measure...
dashpuppy 02-13-2019 07:50 PM
Id probably use the 4ohm version of that Sb acoustics. It's a 91db driver.. I was only planning on using 1 woofer and 1 tweeter..
Javs 02-13-2019 08:24 PM
The TPL is a 102db/w driver. You will need to pad it down a ton, im guessing that SB Driver is only going to be still about 89db where its actually useful.... But I guess it will also allow you to flatten the response a lot. Its just going to mega raise the impedance at the tweeter.
Here is a zip file with measurements from 2 different boxes... there is a few here, I've built 4 different designs with these tweeters so, they can behave a little differently depending how the chamber is damped, and IMO you really want to look in to taking off the back cover and gibing them their own space to breathe. Anyway, you should be able to play around with these.
https://www.dropbox.com/s/nliymttkop...L150H.zip?dl=0
https://i.imgur.com/fgmUMdP.png
https://i.imgur.com/CqoG5j5.png
https://i.imgur.com/pJgnwBk.png
michael hurd 02-13-2019 08:33 PM
Only 91 dB @ 2.83V, which is more than a watt into the 3.3 ohm DC Re. Bandwidth and efficiency are inversely related. 0.3588% no with a 28 hz fs. 90 watt rated power handling.
Spl @ 1W remains at 88 dB. In a ~ 2.5 cubic foot box tuned at 28 hz, your maximum spl based on the Sd and Xmax is about 105 dB at 40 hz, but this is before room gain.
A 0.707 sealed box is -3dB at 51 hz, in comparison the ported box is -3dB at 27 hz.
michael hurd 02-13-2019 08:37 PM
What are your goals with this speaker build? If you plan to use a subwoofer and cross over higher, I would suggest a higher efficiency woofer, to better match the tweeter.
dashpuppy 02-13-2019 08:49 PM
I'm building a pair of "bookshelf" stand mounted speakers..
Atm, I'm just playing with drivers and ideas.
I simulated the 4ohm sbacoustics into a 1.75cuf box at 34hz..
I did see that vapouraudio made something similar to what im looking to build, but he uses the a&e 10"...
I have a subwoofer i could use. But my ideal goal is to build stereo pair large bookshelf-standmounted speakers..
A9X-308 02-13-2019 10:06 PM
Don't worry, they're great, one of the very best tweets I've ever owned. Just waiting to finish a couple of other things before I start my large AE/ATC/TPL build.
Another cheaper AMT worth considering is the Dayton AMT Pro4. It got a good write up in Voicecoil mag. No WG for it though, but you'll only need to pad it about 5dB.
A9X-308 02-13-2019 10:10 PM
PS: some good independent measurements of the Satori here. You need to register to get them all.
blazar 02-14-2019 05:53 AM
I have heard really great things about the beyma ribbon tweeters and it is on my bucket list to create a speaker using them. I don't know the fist thing about properly designing a crossover however...
If someone had a kit with these (diysg), I would love to put a set together. They tend to focus on the most affordable designs as opposed to the highest quality components necessarily.
Ericglo 02-14-2019 06:16 AM
Talk to Mike Garrett. Every year at Cedia, he tells me that he hasn't heard a demo that exceeds the performance of his system. Mike is running the Beymas along with Acoustic Elegance woofers in a baffle wall.
dashpuppy 02-14-2019 06:51 AM
I have a huge collection of sbacoustics measurements. Thats why I was after the beyma tweeter.. now to see if this two way combo will work and they turn out good :)
A9X-308 02-14-2019 07:06 AM
Do you have a link to that design?
dashpuppy 02-14-2019 07:10 AM
I think I've seen that on here too. I sold my a&e 15" to ryan.. maybe the 10" would be a good fit.. only thing that really sucks is they are 150$ more than the 9.5" satori's i have fallen in love with.
biliam1982 02-14-2019 07:51 AM
lol... I was just about to tag Mike. Was literally just talking to him last week about them. He said they're very close to the ALCONS. More so than ALCONS would like to admit.
@Javs
@Mike Garrett
@A9X-308
Are you guys using just the raw Beyma TPL-150?
http://www.usspeaker.com/beyma%20tpl150-1.htm
Or the one with the 80Hx30V waveguide, the TPL-150H?
http://www.usspeaker.com/beyma%20tpl150h-1.htm
If the waveguide version, have you heard a SEOS waveguide and can comment on the differences and similarities?
I'm a big fan of the SEOS waveguide. I love the soundstage it gives. Wonder if a larger version like the SEOS24 would have a throat big enough to fit the Beyman TPL-150.
dashpuppy 02-14-2019 07:58 AM
1 Attachment(s)
Thanks for the measurement Files Jav.
This is my first try.
A9X-308 02-14-2019 08:19 AM
This one. The WG unbolts.
It depends far too much on the actual WG, the CD and the implementation.
Not a chance in the world. The SEOS throat is round and the Beyma opening is much larger and rectangular.
Javs 02-14-2019 12:02 PM
Imo that would sound harsh. You might want to think about a very slight decline from 100hz to 5khz or so rather than pretty big hump in the middle especially at crossover point
Ericglo 02-14-2019 12:35 PM
@Javs
@Mike Garrett
@A9X-308
https://www.avsforum.com/forum/155-d...-tpl-150h.html
I will let Mike fill in the rest.
To the OP, are you planning on designing a crossover based on measurements you received from someone else?
dashpuppy 02-14-2019 12:41 PM
No way ! That would be a wrong way to build a speaker :) I'm only using these files to see if the speaker would actually work together that's all. I didn't want to spend 1800$ on a pair of DIY speakers with an envision they are going to be good for 2 channel hifi.. Id rather waste my time & learn something than buy the drivers build boxes and it goes to pooh & not work.. make sense ?
notnyt 02-14-2019 01:18 PM
I was considering building a 12" 2-way with one of these but the vertical directivity is a little crazy.
https://i.imgur.com/VJ0W9pW.png
Javs 02-14-2019 03:22 PM
http://www.usspeaker.com/images/beym...vb-size291.gif
Design it for the listening axis? pretty simple no.
All AMT's will have directivity like that because they are tall. I have to get up out of my chair to hear a change in the top end. In all my TPL designs I put it right at ear height in the speaker.
Javs 02-14-2019 03:25 PM
@Javs
@Mike Garrett
@A9X-308
Wave-guide. SEOS wont fit anyway. No issues with soundstage here.
This is my most recent project with them. I seriously dont think I can do better than these towers now. Freaking incredible.
notnyt 02-14-2019 03:25 PM
Off axis response is important beyond that. Still, that's what's kept me away from those :(
I remember seeing one at some point that had better response, but can't remember which.
Javs 02-14-2019 03:28 PM
You are surely missing out.
The vertical directivity at those frequencies becomes kind irrelevant man. Its already going to be getting into laser beam territory The AMT ribbon is about 10cm high. From a distance you are going to be sitting WELL inside its directivity window anyway, I've not had any issues with this on my builds using it.
https://i.imgur.com/G7PVm8i.png
notnyt 02-14-2019 03:38 PM
https://i.imgur.com/G7PVm8il.png
The issue isn't with the listening window, it's with having consistent off axis response. Toole and Olive cover this extensively. It is not irrelevant.
And no, not missing out. I prefer the large format beryllium compression drivers on big waveguides I'm using which hold pattern nicely an octave below the tpl150h... I was just tossing around the build idea for fun/friends. Still kicking it around, but not sure what hf driver would get used. I saw a ribbon that measured fairly well I meant to look into closer, but can't remember which at the moment :( The TPL150 ticks all the awesome boxes for me except vertical DI.
https://i.imgur.com/tDHrMe6.png
l/r xover with the big waveguides @ 650hz
https://i.imgur.com/ZKwBkJcl.png
center xover with smaller waveguide @ 800hz
https://i.imgur.com/N8tdcyal.png
notnyt 02-14-2019 03:56 PM
@Javs , your towers look great btw. That's a lot of firepower in that room.
Javs 02-14-2019 04:00 PM
Thanks a lot, I am actually super psyched to be able to put them in a nice deep room behind a screen hopefull in the next year or two. That, and build the 3rd one for my Center to be identical.
Going fully active was definitely the best thing I did.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
