Parts express box size recommendations - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By LTD02
post #1 of 9 Old 02-15-2019, 05:44 PM - Thread Starter
tjcinnamon's Avatar
Quoted: 1798 Post(s)
Liked: 483
The box size PE has never lines up with what I come up with for WinISD. Are their (Bassbox) recommendations generally incongruent with WinISD?
NAD 758 v3 with Dirac 7.4.4 + Rotel 976 + Panamax M5300-PM
Paradigm Prestige 75F's + 55C; 8x Paradigm CI Pro P65-R's
DIY MBMs: VRK Build thread + 2x Rotel 981 (bridged)
Sub: 2x Rythmik LVX12 + MiniDSP
DIY Room Treatments: Dutch Floral Prints
tjcinnamon is online now
post #2 of 9 Old 02-16-2019, 01:53 AM
Quoted: 398 Post(s)
Liked: 342
The box sizes is mostly just a check box item for them. If you want to get their help on figuring box sizes you can message them.
Trimlock is online now
post #3 of 9 Old 02-16-2019, 03:17 AM
LTD02's Avatar
Quoted: 2920 Post(s)
Liked: 3626
box size can vary depending on a variety of things. there isn't really a 'right' answer. if you like the response that you are modelling and it fits within your space (and everything else looks good in the model, excursion, port velocity, etc.), then go with your model.
bebb likes this.
Listen. It's All Good.
LTD02 is offline
post #4 of 9 Old 02-16-2019, 07:38 AM
Quoted: 125 Post(s)
Liked: 35
I agree- Bassbox pro sucks for box size. Take the RSS390HF- They have it listed as 8.96FT^ for 21 HZ tune....Mine are 3.8FT^ and have a 17/18HZ Tune... Massive difference. And believe me 3.8 or even 4FT^ is plenty for one these drivers. Things are scary good
Remy.Alexander is online now
post #5 of 9 Old 02-16-2019, 08:10 AM - Thread Starter
tjcinnamon's Avatar
Liked: 483
This is what I was referring too. Mine are generally way different through WinISD
Although many of the BB pro PE sizes are more favorable for me. I’m looking at swapping the drivers in my existing 1.35 cuft box.
post #6 of 9 Old 02-16-2019, 08:12 AM - Thread Starter
tjcinnamon's Avatar
Liked: 483
I’ll trust mine over PE default. I’m looking at some drivers from Madisound. Scanspeaks and SB acoustics
I’ll see what’s they say too
post #7 of 9 Old 02-16-2019, 06:04 PM - Thread Starter
tjcinnamon's Avatar
Liked: 483
I haven’t modeled sealed in a while but holy cats do they look similar from an SPL perspective.
Transfer functions differentiate themselves but I’m not 100% sure what they mean
Should I be aiming for a QTc?
post #8 of 9 Old 02-17-2019, 02:00 AM
LTD02's Avatar
Liked: 3626
it isn't super important. if the qtc gets too high then it might not sound quite right. otherwise, it is mostly about how much power the driver can take and how much amp you have. larger boxes are more efficient on the low end, but some folks like small boxes for their aesthetics. :-)
LTD02 is offline
post #9 of 9 Old 02-17-2019, 12:56 PM
bebb's Avatar
Quoted: 223 Post(s)
Liked: 156
In order,
Same.
Yes.
If bad sound were Faital, good sound would be almost impossible
Killed two Mach5 21s and three UM-18s (and counting?)
bebb is online now
