What do you think about this 15" sub vs VBSS/Marty etc - AVS Forum | Home Theater Discussions And Reviews
 19Likes
  • 6 Post By aron7awol
  • 2 Post By bluenova
  • 3 Post By notfastenough
  • 3 Post By mtg90
  • 1 Post By bebb
  • 1 Post By Zarkoff500
  • 1 Post By LTD02
  • 1 Post By simcole
  • 1 Post By A9X-308
post #1 of 12 Old 02-19-2019, 08:26 AM - Thread Starter
Liked: 1
Question What do you think about this 15" sub vs VBSS/Marty etc
I'm looking into building my first DIY sub. I like the VBSS for the price point, and the Marty for the geek factor, but I think it's too much money. I have a new home theatre room that's Dedicated to 50% movies and 50% Xbox not really any TV. I'm looking to "Feel the boom" in movies and increase that immersion experience. I'm purchasing my 120" screen and projector here soon. I have a friend who is a home theatre guru and he suggested this speaker.
Dayton Audio 15" Classic Subwoofer for $90
He mentioned that unlike the VBSS this doesn't need DSP to tune correctly and is a true sub with flat response curves. He thinks I can build 2 of them (1 ported and 1 sealed) to get both sides of the spectrum if I want. I think I'd want to go with ported first to hit the 20htz movie range.
Is he on the right track here? He mentioned this also affords a more normal amp and levels and crossover can be set on my X1400H receiver just fine. I'm pairing this sub with my 5 piece Elac debut 2.0 B6.2 and C6.2 setup (LRC&Surrounds). No sub yet hence the build.
Thoughts and comments?
Bonus question is an amp suggestion that I can expand later to add bass shakers.
simcole is offline
post #2 of 12 Old 02-19-2019, 08:57 AM
Quoted: 2272 Post(s)
Liked: 9522
No offense, but your friend seems to know just enough to be dangerous. I would not follow his advice.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Custom Tapered Ported Volt-6 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is online now
post #3 of 12 Old 02-19-2019, 09:06 AM
bluenova's Avatar
Quoted: 47 Post(s)
Liked: 99
It’ll work ok but the vbss driver is about the same money and you’d likely want dsp to tune your response to your room anyway. I’d go vbss over this all day long. Plus you’ll want dsp in the future for integrating shakers too.
bebb and LTD02 like this.
bluenova is offline
post #4 of 12 Old 02-19-2019, 09:23 AM
notfastenough's Avatar
Quoted: 164 Post(s)
Liked: 191
I'm sure your friend has good intentions, but the tried and tested advice on a thread like the VBSS thread is too good to stray from. Someone suggesting to not use DSP and then mix sealed and ported with the same driver in the same room just does not bode well. If you were to mix the two types of sub enclosures, DSP would be the only way to get them to even come close to working. Even then, it would work better if you simply didn't mix the two types of boxes.
kennyandersen, dunnkm2 and LTD02 like this.
notfastenough is online now
post #5 of 12 Old 02-19-2019, 10:07 AM - Thread Starter
Liked: 1
Well can the INuke do a vbss and bass shakers at the same time?
simcole is offline
post #6 of 12 Old 02-19-2019, 10:12 AM
mtg90's Avatar
Quoted: 760 Post(s)
Liked: 1575
The inuke 3000 can, could put up to 4 VBSS subs on one channel then the bass shakers on the other.
LTD02, talon95tsi and Heide264 like this.
mtg90 is offline
post #7 of 12 Old 02-19-2019, 07:14 PM
bebb's Avatar
Quoted: 218 Post(s)
Liked: 156
^+1
LTD02 likes this.
If bad sound were Faital, good sound would be almost impossible
Killed two Mach5 21s and three UM-18s (and counting?)
bebb is offline
post #8 of 12 Old 02-19-2019, 07:27 PM
Zarkoff500's Avatar
Quoted: 173 Post(s)
Liked: 132
The VBSS is a very capable system as designed. Four in a moderately sized room would be pretty potent.
LTD02 likes this.
Zarkoff500 is online now
post #9 of 12 Old 02-19-2019, 07:29 PM
LTD02's Avatar
Quoted: 2909 Post(s)
Liked: 3590
something that you may like is a pa460 in a 6-7 cubic foot cab tuned to the mid 20's.
the yung plate amp with 500w and 6db of boost will provide a pretty flat response to the mid twenties and extension to the low 20's.
one plate amp could run two subs because the drivers are nominal 8 ohm.
the plate amp is on sale right now too.
https://www.parts-express.com/yung-s...25-hz--301-514
Listen. It's All Good.
LTD02 is offline
post #10 of 12 Old 02-19-2019, 07:34 PM
LTD02's Avatar
Liked: 3590
frequency response no eq. pa460 is red. classic 15" is black. 1w1m.
frequency response including eq in the plate amp.
the pa460 driver will have more max output across its entire operating range as well.
ID:	2528322   Click image for larger version
notfastenough likes this.
LTD02 is offline
post #11 of 12 Old 02-20-2019, 06:27 AM - Thread Starter
Liked: 1
This was extremely helpful to see. Thank you for that. That makes a lot more sense to SEE it.
LTD02 likes this.
simcole is offline
post #12 of 12 Old 02-20-2019, 09:38 AM
A9X-308's Avatar
Quoted: 1792 Post(s)
Liked: 1483
I agree. Listen to LTD.
LTD02 likes this.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
