JK’s 893 build with subs - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 341Likes
post #121 of 276 Old 03-24-2019, 04:40 AM
hd0823's Avatar
Quoted: 679 Post(s)
Liked: 1251
Looking great like usual. While I'm still hear waiting to veneer mine lol. I like the idea of the horns or the 21b&c ds115. The system sounds awesome now but you know I have a love for horn designs lol
Sent from my SM-N950U using Tapatalk
Jk7.2 likes this.
hd0823 is online now
post #122 of 276 Old 03-24-2019, 05:15 AM
Craig S King's Avatar
Quoted: 351 Post(s)
Liked: 498
Originally Posted by Jk7.2 View Post
Behind the screen just to play with them? Not sure if the 4 hst’s are as loud as two lil wreckers would be. The upper bass and overall impact would probably be better with the horns.
Am I reading this correctly - two lil wreckers would be louder than 4 HSTs?
Also, great progress Jk. The veneer is a good look. I plan to veneer my cinema-10s when I start building them.
Jk7.2 likes this.
Craig S King is offline
post #123 of 276 Old 03-24-2019, 05:36 AM - Thread Starter
Jk7.2's Avatar
Quoted: 1382 Post(s)
Liked: 2527
I’m sure the hst’s win in that battle. But I have been curious about horn loaded subs.
They also have areas they each shine for sure too.
imrf and Craig S King like this.
Jk7.2 is online now
post #124 of 276 Old 03-24-2019, 05:59 AM
Quoted: 351 Post(s)
Liked: 498
I know what you mean - I'm still curious and fascinated with building a horn loaded sub, as well as obviously hearing/feeling it.
Jk7.2 likes this.
post #125 of 276 Old 03-24-2019, 08:14 AM
OJ Bartley's Avatar
Quoted: 456 Post(s)
Liked: 547
What about replacing 1 of the HST stacks with a horn? You'd get the best of both worlds, especially if you kept the rear subs in play too.
Sent from my SM-A520W using Tapatalk
Jk7.2 likes this.
OJ Bartley is offline
post #126 of 276 Old 03-25-2019, 07:26 AM - Thread Starter
Jk7.2's Avatar
Liked: 2527
I wouldn’t say ‘replace’. I’ll find somewhere else for those two hst’s to go
Jk7.2 is online now
post #127 of 276 Old 03-25-2019, 08:01 AM
OJ Bartley's Avatar
Quoted: 456 Post(s)
Liked: 547
Lol, even better. Turn that side room into a chamber for IB!
post #128 of 276 Old 03-25-2019, 08:04 AM - Thread Starter
Jk7.2's Avatar
Liked: 2527
Yeah right back to where I started.
Jk7.2 is online now
post #129 of 276 Old 03-25-2019, 10:20 AM
imrf's Avatar
Quoted: 197 Post(s)
Liked: 117
Nearfield! Kick those DS4s to the curb! Lol
imrf is offline
post #130 of 276 Old 03-25-2019, 10:42 AM - Thread Starter
Jk7.2's Avatar
Liked: 2527
Never! I love the ds4’s.
imrf likes this.
Jk7.2 is online now
post #131 of 276 Old 03-25-2019, 10:43 AM
imrf's Avatar
Quoted: 197 Post(s)
Liked: 117
Yeah, they’re pretty awesome where they’re at.
imrf is offline
post #132 of 276 Old 03-25-2019, 03:38 PM - Thread Starter
Jk7.2's Avatar
Liked: 2527
Got a good 1st coat on these. Getting excited.
Jk7.2 is online now
post #133 of 276 Old 03-26-2019, 07:04 AM
LNEWoLF's Avatar
Quoted: 453 Post(s)
Liked: 271
Nice work............those are [email protected]@king SWEET..............
Twin Pioneer AVR Locomotives-Elite SC 97, SC 1222 7.2.4, DOLBY Atmos and DTS X, (Front Pre Out,) JBL Pro Synthesis LS Series Speakers, F L R-LS80, Cen-LS, S L R-LS60, SB L R-LS60, 4 Dolby Atmos Enabled Klipsch R41SA, Twin Klipsch R120SW. Mitz 73740 DLP, Sony UBP-X800, ATV G4, Yamaha ATS 1060 Sound Bar, True Depth Firestorm 2.0 3D Glasses, Harmony Hub with Utlimate 1 Remote, Broadlink RM Pro2, EYE Pad Air, Winegard FL6550A
LNEWoLF is offline
post #134 of 276 Old 03-26-2019, 07:10 AM - Thread Starter
Jk7.2's Avatar
Liked: 2527
Thanks. These are my 1st sub project where I care a lot how they look. And they will be speaker stands as well. I hope the speaker feet don’t hurt the veneer or the finish over the years.
imrf likes this.
Jk7.2 is online now
post #135 of 276 Old 03-26-2019, 07:15 AM
jedi1982's Avatar
Quoted: 242 Post(s)
Liked: 515
Mad respect @Jk7.2 for your "handiman-ness"! lol
Jk7.2 likes this.
jedi1982 is offline
post #136 of 276 Old 03-26-2019, 07:17 AM - Thread Starter
Jk7.2's Avatar
Liked: 2527
Thanks! Most of it I learned right here in this forum. The diy speakers and subs section is where I use my battery life every day.
spotts29 and Black adder like this.
Jk7.2 is online now
post #137 of 276 Old 03-26-2019, 07:50 AM
markg35's Avatar
Quoted: 342 Post(s)
Liked: 263
Your sub look Gorgeous!
One thing I found....I'm using one Ultimax 18 in a sealed box as a speaker stand for my 893's and one for a surround....I needed to use Earthquake putty to keep the from rotating and or falling off(Ready Player One)
markg35 is offline
post #138 of 276 Old 03-26-2019, 07:52 AM - Thread Starter
Jk7.2's Avatar
Liked: 2527
Ok thanks that’s good to know. I’m not sure these closeout 15” woofers will be that strong..... but now that I’m thinking about it, this setup will most likely dance like mad all over with my theater full of hst’s is going full blast! It’s directly above the theater.
Jk7.2 is online now
post #139 of 276 Old 03-26-2019, 09:23 AM
imrf's Avatar
Quoted: 197 Post(s)
Liked: 117
I went the cheap and easy route, I grabbed a roll of automotive carpet from work and cut a pair of pads out for each speaker to put them on my subs. Just enough friction to stop them from moving around.
imrf is offline
post #140 of 276 Old 03-26-2019, 10:43 AM
Steve Kuester's Avatar
Quoted: 181 Post(s)
Liked: 323
I have my 893s sitting on a couple sealed UM18s. My 893s would walk if I turned it up too loud when I was using some foam pads I had lying around. Then I bought these and the 893s have not moved since... https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
But I do remember reading these could discolor wood, so maybe not for you if that is a concern. I did a dark laminate finish, so I'm not so concerned about any discoloration.
I turn the sharpness on my TV all the way up, because that's how I like my picture... real sharp.
Jumping into DIY - My 893, Volt 6, and UM18(x4) build
Steve Kuester is offline
post #141 of 276 Old 03-26-2019, 10:45 AM - Thread Starter
Jk7.2's Avatar
Liked: 2527
Ok thanks. I will see what happens. I have rubber feet delivering today for the bottoms of the speakers. I’m thinking that will keep things reasonably tame.
Rjloper9 likes this.
Jk7.2 is online now
post #142 of 276 Old 03-26-2019, 11:14 AM
imrf's Avatar
Quoted: 197 Post(s)
Liked: 117
Yeah, rubber feet should work just fine. If not, let me know and I could hook you up with some of this carpet if you want.
Jk7.2 likes this.
imrf is offline
post #143 of 276 Old 03-26-2019, 01:32 PM - Thread Starter
Jk7.2's Avatar
Liked: 2527
1st coat sanded and second coat applied. I wish this veneer came out just a little darker.
Jk7.2 is online now
post #144 of 276 Old 03-26-2019, 02:53 PM
Kpilk's Avatar
Quoted: 48 Post(s)
Liked: 53
No...that's perfect. I'm going to follow this exact recipe for my Maximus-12s.
mtbdudex and Jk7.2 like this.
Kpilk is online now
post #145 of 276 Old 03-26-2019, 02:55 PM - Thread Starter
Jk7.2's Avatar
Liked: 2527
It does highlight grain in a sexy manner. The cell pic makes it appear just a tad lighter too. And with the lights off, they look super dark. But switch a light on and they glow. I love it. With black baffles these will pop.
imrf, Kpilk and bear123 like this.
Jk7.2 is online now
post #146 of 276 Old 03-26-2019, 06:42 PM
Quoted: 351 Post(s)
Liked: 498
Nice progress so far. I like the darker color you chose. I think I'll stain my subwoofer cabinets a similar color as well as the Cinema-10s when I get going on them.
This Waterlox stuff you mention, do you put a coat of polyurethane over it too? Or is it a stain and polyurethane in one?
post #147 of 276 Old 03-27-2019, 03:36 AM - Thread Starter
Jk7.2's Avatar
Liked: 2527
It’s a tung oil product. It waterproofs and brings out the natural color of the wood. It’s not a polyurethane, and it doesn’t require a top coat. I hope I described it right. Look it up, they have a nice website.
Jk7.2 is online now
post #148 of 276 Old 03-27-2019, 09:39 AM
mtbdudex's Avatar
Quoted: 83 Post(s)
Liked: 1479
Dude you and I have DIY fever!
Nice build you have got going.
Jk7.2 likes this.
mtbdudex is online now
post #149 of 276 Old 03-27-2019, 09:50 AM - Thread Starter
Jk7.2's Avatar
Liked: 2527
Thanks I’ve been watching yours as well. I’m seriously considering doing a flat black paint instead of duratex on the baffles like you used on your boxes. I just have trouble with the minor inconsistencies that you get unless you spray the duratex. Anything that I can pick up locally for this purpose to roll on?
Jk7.2 is online now
post #150 of 276 Old 03-27-2019, 10:04 AM
asarose247's Avatar
Quoted: 1178 Post(s)
Liked: 1041
a small Devilbiss cup gun, D'tex let down close to 50%, pressure lowered to about 50 psi and then you of course have a valve on the gun too
over 2 coats of well prepped , sanded , etc. black primer,
a cool surface and in the shade,
can be good for smaller boxes, panels,
said the guy who also sprayed his 88Specials
no banding as a roller might
for rolling i have a burned out 1/4" weenie roller but the prep is key . .
mtbdudex, OJ Bartley and Jk7.2 like this.
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is online now
