4x 18 inch Ultimax Sub Behind Screen Build - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 79Likes
post #31 of 76 Old 03-18-2019, 03:15 PM
Archaea's Avatar
Quoted: 4315 Post(s)
Liked: 4144
That’d be fun. @desertdome I might need help though I have 4-full Marty flatpacks from GSG sitting in garage. They customed those to fit my UXL-18s. Anyone want my eD sealed boxes?
@Archaea just because
I’ll be ready by fall if we set a date lol
I’m in.
Archaea is online now
post #32 of 76 Old 03-18-2019, 03:18 PM - Thread Starter
sassuki's Avatar
Quoted: 89 Post(s)
Liked: 196
Originally Posted by desertdome View Post
Those are looking great. We should have a dual subwoofer shootout in Omaha sometime. There is some serious firepower in the area! The problem is all the subs are too big to want to move.
I love the idea. We would need a bunch of us to move them around in and out if everyone’s spaces and an even bigger space to put them all in for the shoot out. I think we are over due for another Omaha tour though. I should be able to wrap mine up once these subs are in place. Then I’ll be able to focus on finishing details of the space.
sassuki is offline
post #33 of 76 Old 03-18-2019, 03:22 PM - Thread Starter
sassuki's Avatar
Quoted: 89 Post(s)
Liked: 196
I’m in.
Oh good! I’ve seen your moving skills first hand with that ULF4000 for the KC tour a couple years back.
sassuki is offline
post #34 of 76 Old 03-18-2019, 03:29 PM - Thread Starter
sassuki's Avatar
Quoted: 89 Post(s)
Liked: 196
Here’s what I’m working on now that the boxes are mostly built. I think I’ll screw the oak pieces to the MDF so I don’t have to clamp and wait. I’m making the holes slightly larger than the bolts to hopefully avoid any alignment issues once I try to actually mount the drivers. Does anyone use workable locktite on the bolts so they don’t loosen over time?
sassuki is offline
post #35 of 76 Old 03-18-2019, 04:05 PM
brettus's Avatar
Quoted: 51 Post(s)
Liked: 30
Didn't you say that you had a nail gun? That's how I'd be fixing those added braces for the glue to dry. Clamp the middle then shoot a nail either side and move clamp onto the next one.
I wouldn't recommend using Loctite either, even the blue loctite as the nuts may strip the wood before the bolts loosen. I doubt they'd undo once nipped up.
Looking good
brettus is offline
post #36 of 76 Old 03-18-2019, 04:40 PM
Oledurt's Avatar
Quoted: 445 Post(s)
Liked: 586
@sassuki : quad UM18-22 ported
@nebrunner : quad UM18-22 sealed and Danley DTS-10
@W00lly : quad dual-opposed MFW-15 woofers sealed
@jbrazda : dual SVS PB16-Ultra ported
desertdome: dual JTR Speakers Captivator S2 sealed
@HuskerOmaha : quad Mach 5 Audio UXL-18 sealed
@andersa : dual Mach 5 Audio UXL-18 ported
@trans mitr: quad SI HT 18D4 drivers in 16cuft sonotubes ported
@rkinmoval : six SI HT 18D4 drivers sealed
@sthompson : dual Seaton Submersive sealed and dual JTR Speakers Captivator 4000ULFs ported
@Oledurt : dual Powersound Audio V3600i and dual Powersound Audio V1510 (not sure if still in Omaha area)
I moved to TX. Rebuilt a new theater in a dedicated room. It’s better than what I had. Focused more on room treatments, and have some new speakers. Still have my quad subs with a mini dsp. My theater room is pretty awesome. I’ll throw some pics up.
Oledurt is offline
post #37 of 76 Old 03-18-2019, 04:56 PM
4fit?'s Avatar
Quoted: 127 Post(s)
Liked: 91
^^^ this. That's exactly what I did. Had all driver mount braces done in 5 minutes.
Sent from my SM-G935V using Tapatalk
| 135" SilverTicket AT screen | BenQ HT2050 | (3) DIY 18" Subs - 1 HT18 & 2 PN470 | iNuke DSP6000 amp |
4fit? is offline
post #38 of 76 Old 03-18-2019, 06:41 PM
HuskerOmaha's Avatar
Quoted: 77 Post(s)
Liked: 71
Wait you are running these ~2ohms with a FP14k? I should have shipped you mine free for parts after it died but I "donated" it during city cleanup day. Probably cost more to ship than the parts.
I guess it lasted a few years.
Excited to see how it fares. I know some people still have their originals thumping.
Johnson sent me an excited email the other day telling me, you no wait, 2ohm stable certified for USA buyer. Whatever that means.
Excited to have an Omaha GTG, my basement will only be sticks and wiring phase by then. Doesn't @desertdome have a new pad now?
HuskerOmaha is offline
post #39 of 76 Old 03-18-2019, 06:46 PM - Thread Starter
sassuki's Avatar
Quoted: 89 Post(s)
Liked: 196
Yeah, but the nails are too long, so I’ll pick up some shorter ones.
sassuki is offline
post #40 of 76 Old 03-19-2019, 07:59 AM - Thread Starter
sassuki's Avatar
Quoted: 89 Post(s)
Liked: 196
Yeah... it’s a Sanway clone. Is that what you had? I take it from your comment that I may be making smoke soon. Should I run them 8ohm instead? What kind of amp did you replace yours with?
That means you buy now!
Do you have a build thread? And yeah, @desertdome is building a new theater. It looks like it will be pretty awesome.
sassuki is offline
post #41 of 76 Old 03-21-2019, 10:30 AM - Thread Starter
sassuki's Avatar
Quoted: 89 Post(s)
Liked: 196
Here are some detail views of the various panels and steps I took to assemble them.
4fit?, Jk7.2, Oklahomie and 1 others like this.
sassuki is offline
post #42 of 76 Old 03-24-2019, 06:02 PM - Thread Starter
sassuki's Avatar
Quoted: 89 Post(s)
Liked: 196
I went camping this weekend, so little progress was made on the subs. I did get a chance to put some bracing in the one box that I had the speaker mounting holes and backers done on. I wanted to integrate the bracing into the mounting holes, and I think this will work out nicely and allow me to use the scrap strips of mdf I already have.
Oklahomie likes this.
sassuki is offline
post #43 of 76 Old 03-25-2019, 06:37 PM
blazar's Avatar
Quoted: 1197 Post(s)
Liked: 887
question for you: did you happen to model the frequency response of the subs in that particular in reference to MLP or other positions? have you tested the frequency response and how does it look? what crossover frequency are you using?
Blazar!
blazar is offline
post #44 of 76 Old 03-26-2019, 05:25 AM - Thread Starter
sassuki's Avatar
Quoted: 89 Post(s)
Liked: 196
No, I have not modeled anything in my room yet. @Eng -999 modeled the enclosures for @Oklahomie and the dimensions worked well for my space, so I decided to build them too. Hopefully I’m not sitting in a null or anything. I love your MBM bar. That has to be an awesome experience. Someday I hope to achieve that chest slamming bass.
sassuki is offline
post #45 of 76 Old 03-26-2019, 05:15 PM
blazar's Avatar
Liked: 887
I was just wondering since my brother is working on a design for his house and it would be MUCH simpler to put the subs in the front wall instead of widening the side walls or the rear wall. our models actually result in a much more clean MLP with quad subs in the corners of the back wall (two on the ground and two near the ceiling) but it really messes with his design for the rear wall.
MikeLA's place we visited in Cali has a single bass array with a rear absorption wall (this also is not ideal for our decor issue since there is a sizable window on the back wall).
I'm wondering about perhaps doing something like you are doing there but every time we try to model a typical listening position, we keep getting various nulls that we don't like. I'm pretty sure we have to put at least one more sub somewhere that we can adjust (maybe hanging from the ceiling) and we can run an mso calculation to neutralize nulls.
Generally, for a front set of subs, what is the "ideal" position of the drivers to cancel as many nulls as possible? I am thinking about 4 drivers.
Blazar!
blazar is offline
post #46 of 76 Old 03-27-2019, 07:03 AM - Thread Starter
sassuki's Avatar
Quoted: 89 Post(s)
Liked: 196
I believe 1/4 room width is the ideal placement for subs along the front wall. If 1/4 width is ideal for two subs, I’m guessing 1/4 height would be good for two more. Ideally 1/4 the room depth also, but that would not put them on the front wall.
sassuki is offline
post #47 of 76 Old 03-27-2019, 07:23 AM - Thread Starter
sassuki's Avatar
Quoted: 89 Post(s)
Liked: 196
I made a little more progress last night after work. I got the holes cut in all the second baffles and mounted the second baffle to the one box that I’ve put the bracing in. My jasper circle jig was not big enough to cut the holes for these beastly 18inch ultimaxes, so I had to add a couple pin locations to it.
Lotsa glue for the second baffle layer:
Sweet lookin countersink. Too bad these will be hidden behind the screen.
I also got a free table saw! I wish I would have had this before I started building all these speakers.
4fit?, OJ Bartley and bubbrik like this.
sassuki is offline
post #48 of 76 Old 04-03-2019, 08:43 AM - Thread Starter
sassuki's Avatar
Quoted: 89 Post(s)
Liked: 196
I put the new table saw to work last night and ripped a bunch of strips so I could continue bracing all the boxes. Three out of the four boxes are now braced, so hopefully o can finish up the fourth tonight and slap a coat of paint on them. I’m hoping to have them moved into the theater before this weekend so I can start setting them up and dive into the REW/minidsp rabbit hole. What plugin will I need?
bubbrik and kagtha like this.
sassuki is offline
post #49 of 76 Old 04-05-2019, 09:56 AM - Thread Starter
sassuki's Avatar
Quoted: 89 Post(s)
Liked: 196
Almost done!
I should be able to mount the drivers and start playing with them in the room this weekend. All four are finally lined with mattress pad, painted and binding posts ready to be wired. It will be nice to get some room back in my garage.
The dog had to help me with the mattress pads:
sassuki is offline
post #50 of 76 Old 04-07-2019, 12:18 PM - Thread Starter
sassuki's Avatar
Quoted: 89 Post(s)
Liked: 196
The subs are in place and hooked up. Now I have to get the mini DSP set up so I can crank it. I also have to build some stands to get the 1099 tweeters at ear level. I’ve only turned the amp up to about 9:00 and played it softly until i get the proper filters in place, but damn, they sound awesome. I wired each sub’s DVCs in series and then paired up each of them in parallel to the two channel 14k clone. Now I get to dive into the DSP REW rabbit hole.
I moved as much as I could out of the way so I could get the subs in the room.
Three down, one in the works:
They are bigger than a small child:
Finally, all four in place. Thanks to my buddies @hellerbrewing and Jason. My wife and I were unable to lift the loaded subs onto the bottom ones.
sassuki is offline
post #51 of 76 Old 04-07-2019, 12:44 PM
Oklahomie's Avatar
Quoted: 228 Post(s)
Liked: 882
The struggle is real when trying to lift those suckers up! They are stinking heavy! Beautiful, though. I’ve been keeping my amps dialed at 12:00 they still beat friggin hard.
How do you like those 1099’s?
Aaron H.
Aaron H.
Oklahomie is offline
post #52 of 76 Old 04-07-2019, 04:51 PM
jtwrace's Avatar
Quoted: 66 Post(s)
Liked: 65
What is the amp clone that you speak about?
Motorola Modem sb6141> Emo Systems EN-70HD > (5) eero > Synology 1813+ (DSM 6.2), 4TB Seagate NAS Drives, 4GB RAM & Zero Surge & APC XS BX1000G/backup to Synology DX513) > Emo Systems EN-60KDS  > Roon > Mola Mola Tambaqui > BSS BLU 50 > (2) Hypex NCore NC502MP > JBL M2 Master Reference
jtwrace is offline
post #53 of 76 Old 04-07-2019, 09:41 PM - Thread Starter
sassuki's Avatar
Quoted: 89 Post(s)
Liked: 196
Aaron H.
You know it!
I’m loving the 1099s. I’m pushing them with an emotiva 5 channel amp and they are just effortless. I love the headroom on tap that they offer. Nothing beats when you’re watching a scene with some normal talking-level dialog and then a gunshot rings out or all hell breaks loose. I’m not ever having to reach for the remote or adjust the volume back and forth like I’ve had to do with less adequate systems. The super 8 train crash scene is actually kinda scary how loud it can get, and I’m still about -6... It’s fun. I just built some stands for them so I can get the waveguide at ear level. It should be better than having them pointed right into the back of the screen frame like they had been until now.
OJ Bartley, blister64 and Jk7.2 like this.
sassuki is offline
post #54 of 76 Old 04-07-2019, 09:49 PM - Thread Starter
sassuki's Avatar
Quoted: 89 Post(s)
Liked: 196
The clone amp is a Chinese Sanway brand clone of a lab grupen 14000 watt 2 channel professional amp. It should provide way more power than these UM18s will ever need. https://www.avsforum.com/forum/155-d...34237?page=663
sassuki is offline
post #55 of 76 Old 04-07-2019, 11:49 PM
Nexgen76's Avatar
Quoted: 821 Post(s)
Liked: 235
Love your setup but how do you keep the subs from moving with all the vibration they making ?
JVC NX5 | Panasonic UB420| PC Madvr
Elite Screens Aeon Series 135 inch CineWhite
Aggressive 1299 L/C/R/ |JBL 8350 surrounds x 4 |JBL SCS8 Atmos x 4
Anthem AVM 60| Crown XLS 1502 X 2| Crown XLS 1002 x 4
GSG Devastator x 3 | Sinbosen FP20000q
Nexgen76 is offline
post #56 of 76 Old 04-08-2019, 05:18 AM - Thread Starter
sassuki's Avatar
Quoted: 89 Post(s)
Liked: 196
Each sub weighs about 235lbs. I am only guessing that the weight will keep them steady, but I haven’t pushed them yet to know.
sassuki is offline
post #57 of 76 Old 04-08-2019, 07:49 AM
OJ Bartley's Avatar
Quoted: 595 Post(s)
Liked: 708
Nice job on those subs, and awesome looking front stage!! That setup must sound amazing.
sassuki likes this.
"You can never have too many clamps."
My DIYSG HTM-12 build
My dual sealed UXL-18 build
OJ Bartley is offline
post #58 of 76 Old 04-08-2019, 01:14 PM
mtbdudex's Avatar
Quoted: 85 Post(s)
Liked: 1595
Upon first glance I thought to myself ... he's building a SBA behind his AT screen, how cool is that!
reference this classic build
https://www.avsforum.com/forum/19-de...ter-build.html
I've had four UM18-22 Ultimax subs sitting on my shelf just waiting for the day to come when I would build them proper enclosures for my dedicated theater. Well, that time has finally come. I was originally thinking of just going with a full marty design, but didn't want the port firing into the back of my screen, so I decided to reach out to @eng-999 for a customized design. He had just designed some um18-22 boxes for @Oklahomie that seemed well-suited for my application as well, so after talking with him about what I was wanting, it seemed like reusing that design would work. I'll be running them off an LG FP14k clone amp and wiring each pair of them to present a ~2ohm load to each of the two channels of the amp. My receiver is a Denon 4520 but I also have a mini DSP 2x4. Since the Denon has dual sub outputs, do I even need to use the miniDSP? I am not sure if I can set the proper filters needed for a ported enclosure without the minidsp. Is there a way to do it in Audyssey? My mains are DIYSG 1099s powered by an Emotiva XPA5 and surrounds are volt 10s. The room is roughly 12x26x8ft and is a room within a room construction with sealed doors (link to room build thread in my sig).
Now the fun stuff.
This is how they will be stacked behind my screen:
With the 1099s:
Then as I read the thread ... yep, at 1/4 from walls it is a SBA
mtbdudex is online now
post #59 of 76 Old 04-08-2019, 05:13 PM - Thread Starter
sassuki's Avatar
Quoted: 89 Post(s)
Liked: 196
Hopefully it helps smooth out some possible room nulls I might have.
sassuki is offline
post #60 of 76 Old 04-08-2019, 07:18 PM
blazar's Avatar
Liked: 887
assuming you could do 1/4 from the walls, should we do 1/4 height from the ceiling and floor (above and below the center channel) perhaps? I'm curious what the maximum benefit that could be achieved with subs behind an AT screen without doing any subs anywhere else and not having exotic amounts of absorption.
Blazar!
blazar is offline
ported subwoofer , ultimax 18" subwoofer
