Talk me out of going sealed to ported 18" x 4. - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 17Likes
post #31 of 34 Old 03-13-2019, 10:40 AM
Quoted: 2480 Post(s)
Liked: 10761
Originally Posted by Kpilk View Post
All the switches were just in the original position meaning I had the Filter on and set to 50hz. Just a quick listen with the filter set to 30 is night and day. Later will try without the filter on but I think I found what I was missing...namely a brain.
Yeah turn that filter off. You shouldn't need a filter at 30Hz either.
LydMekk likes this.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Custom Tapered Ported Volt-6 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is online now
post #32 of 34 Old 03-13-2019, 10:42 AM - Thread Starter
Kpilk's Avatar
Quoted: 70 Post(s)
Liked: 73
Good to know...might read the manual ahead of time next go around.
Kpilk is offline
post #33 of 34 Old 03-13-2019, 12:14 PM
Liked: 10761
The difference must be night and day. Putting a HPF at 50Hz (or even 30Hz) would make me think my subs were turned off. Dude, where's my subs?
Kpilk likes this.
post #34 of 34 Old 03-13-2019, 05:17 PM
BassThatHz's Avatar
Quoted: 3702 Post(s)
Liked: 4213
In general, ported trades 1-10hz, for more 12-25hz. (and the inverse for sealed.)
IB is a slightly more efficient version of sealed, IB's tend to lack mid-bass and can be devastating if you locate it at a room-null (can't move or re-cut an IB easily...)
Horned is basically like 1.5-2x louder than ported (at all frequencies, not just tuning...)
It is one of the more efficient designs, if not the-most, but they tend to be 25-100% larger/heavier than ported and are 3x more difficult to design and build.
Dual-Opposed sealed is a simple way to double your surface area and power handling without messing up the phase, group-delay or tonality of the subwoofer-system. It will net you 3db if you can maintain the power, and 6db if double the power into half the ohms or if you can double up on the amplification channels at the same ohm...
It is possible to build dual-opposed ported, but you have to watch the port velocity and tuning frequency.
So the answer is "it depends": space/money/time/complexity/WAF etc etc...
If you value 1-5hz then sealed or IB is really the only decent option left regardless of the other constraints, simple because: ported and horned will be down FAR too many db by that frequency, given the HPF and other restrictions (unless of course the horn is the size of the whole room or is the room... hehe! )
The HT-18's and EP4k are both value items, there ARE better *if* you can afford it.
For example: 4 SI-24's and 1 FP20k, that will have about 8x the power and 3x the wooferage... and a price tag that goes with it!!!
Better is certainly possible, but there is no free lunch...
I can 100% guarantee you my system is better than 4 15hz ported 18's.
Especially so, once I finish both HzHorn's in their proper boxes this summer...
32 woofers and 100kW in literally ANY type of box will simply melt your skin
Kpilk likes this.
BassThatHz is offline
