Ricci's Skram - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 72Likes
post #31 of 87 Old 03-29-2019, 12:11 PM
Quoted: 569 Post(s)
Liked: 474
Originally Posted by Jsin_N View Post
No idea, I'll have to leave that to you professionals, but I'd gladly take 2 18s that way if you're bored
At 24" wide its pretty narrow for a 21" driver as that only gives you 1.5" on each side and the mounting piece will only have .75" from each side of the driver
a large part of the reason is the horn loading on the front of the driver. I don't think its actually a horn, just a tapered front end to a 6th order sub much like the Skhorn is. You could get it narrowed down to 21" wide in that case but you aren't really saving a ton of floor space still and you'd have to make it taller.
Did you have an 18" in mind?
Trimlock is online now
post #32 of 87 Old 03-29-2019, 03:16 PM
dsl1's Avatar
Quoted: 206 Post(s)
Liked: 419
JESAL, Ricci, michael hurd and 7 others like this.
________________________________________
DIY Mid Hi Speakers Build - SKHorn Build - Gjallarhorn Build SOLD - Othorn Build SOLD - SEOS 12 Build - Other Gear: JVC NX5 - Seymour Matinee Black - QSC CX4.5Q amps x 5 - QSC Q-sys 110f - Speakerpower 6000 x2
dsl1 is offline
post #33 of 87 Old 03-29-2019, 04:14 PM
Jsin_N's Avatar
Quoted: 711 Post(s)
Liked: 406
The Skhorns are already 24" wide, but I get it. There's other things to worry about other than just fit when it comes to design.
I have 4 LMS ultras I could use lol
I imagine they're not right for these applications?
I'll stop hijacking this thread tho
Jsin_N is online now
post #34 of 87 Old 03-30-2019, 12:36 AM
Quoted: 569 Post(s)
Liked: 474
Off the top of my head I don't know, but they are pretty amazing drivers. I'm not sure them being in a higher order configuration will give you much in the SPL department. At 16 cu/f (the size of this box) your LMS Ultras would have a pretty bitchin time a normal ported, really low tuned box.
post #35 of 87 Old 03-31-2019, 06:02 PM
dsl1's Avatar
Quoted: 206 Post(s)
Liked: 419
Had to order some parts for the CNC, so no subs this weekend
dsl1 is offline
post #36 of 87 Old 03-31-2019, 06:20 PM
Vince_B's Avatar
Quoted: 348 Post(s)
Liked: 246
What cnc are you using?
Vince_B is online now
post #37 of 87 Old 03-31-2019, 06:30 PM
dsl1's Avatar
Quoted: 206 Post(s)
Liked: 419
Started off as a Kronos KRMx02. Quite a few things were added from CNCrouterparts kits. It's been quite a good machine. I'm sure there are better options now.
dsl1 is offline
post #38 of 87 Old 03-31-2019, 06:49 PM
peniku8's Avatar
Quoted: 434 Post(s)
Liked: 433
Originally Posted by stegen View Post
But no one is making a Skorn in their garage without a CNC machine. This you could.
CNC is for beginners
dsl1 likes this.
A Star Is Born - Lady Gaga goes Rock Audio&Video by Ocean Studios (me)
SKHorn Build
Samsung KS7500 - Marantz NR1504 - Klipsch R-26F - Klipsch R-25C - Klipsch R-15M - SKHorn - BOSS
Bass EQ for Filtered Video Games
peniku8 is online now
post #39 of 87 Old 04-01-2019, 09:20 PM
Vince_B's Avatar
Quoted: 348 Post(s)
Liked: 246
I don’t know anything about cnc but that looks pretty legit. I see a lot of 80/20 parts I think.
post #40 of 87 Old 04-02-2019, 08:34 AM
dsl1's Avatar
Quoted: 206 Post(s)
Liked: 419
Yeah, all the parts that need to be rigid are 80/20. The motors, rails, etc are all industrial level. Don't have a spindle currently and just a normal router which limits cut speed to ~120 inches per minute and end up cutting 3/4" material in two passes. Little $120 Hitachi router has been insane, has kept running for 5 years with hundreds and hundreds of hours of cutting.
dsl1 is offline
post #41 of 87 Old 04-02-2019, 12:02 PM
Ricci's Avatar
Quoted: 423 Post(s)
Liked: 974
I see what you did there.
I was thinking about suggesting that for the ports to make the vent blocks work better this time. You extended out the mouth braces to the edge too. I was trying to keep that a straight right angle cut on that edge for simplicity, but you just had to get fancy with it! That intersection with the port panel and the mouth braces looks a little odd with that cut back for the vent blocks.
EDIT: I forgot about the single piece horn bracing. More CNC peacockery!
Ricci is offline
post #42 of 87 Old 04-02-2019, 12:50 PM
Ricci's Avatar
Quoted: 423 Post(s)
Liked: 974
Here is the response simulation with a couple of drivers. There will be a few minor differences due to the limitations of the sims but this should be close.
The 4 possible vent tunings should be about 29.5, 25.5, 21 and 15Hz. This design is optimized for the 29.5 and 25.5Hz tunings for pro style output levels with live music, DJing and sound reinforcement but with an emphasis on neutrality as per the Skhorn and Othorn. It will work in the lower tunings, with multiple cabs, EQ and some room gain, but the vent area is compromised and the overall output drops too. These should have a lot of headroom though. Vent area is greater than 4 6" pipes with all vents open. Even with only one vent open the area is about that of a 6" pipe.
21DS115-4 with all vents open and 1 vent blocked.
Lavoce SAN214.50 (These are using measured specs with complex inductance from a driver I have. It is a close match to factory.)
Name:	Skram 21DS115-4 Sim 4v and 3v.jpg
ID:	2547926   Click image for larger version
Name:	Skram SAN214.50 Sim 4v and 3v.jpg
LTD02 and JESAL like this.
Ricci is offline
post #43 of 87 Old 04-02-2019, 07:20 PM
JESAL's Avatar
Quoted: 41 Post(s)
Liked: 36
I'm jealous of you CNC guys, if I have one I'll probably have a Skhorn in every room. A slab of granite on top of a Skhorn will make a nice dining table. Hmmnn... great idea lol Skram half brothers will join big brother Skhorn soon...
Sent from my SM-G955W using Tapatalk
JESAL is offline
post #44 of 87 Old 04-02-2019, 08:28 PM
Samps's Avatar
Quoted: 1338 Post(s)
Liked: 1009
That looks slightly smoother than the B&C. Do you think max output will match the B&C? Could be a good driver choice for this group.
Samps is offline
post #45 of 87 Old 04-03-2019, 05:56 AM
Jedi940's Avatar
Quoted: 335 Post(s)
Liked: 262
Forgive my ignorance as I am not familiar with Hornresp. Is that graph equivalent to a 1 watt SPL gragh in WinISD? As I stated earlier, I'm trying to compare this design vs. a standard large ported enclosure @20hz and the submaximus v3. I'm thinking about redesigning my boxes and I like the size of these since it will give me the ability to add more.
I found THIS link from the designer explaining the acoustical power graph and what it represents but I'm having difficulty fully understanding it. It sounds like its similar but I could be missing something. I am also researching excursion in horns to see what differences there are in that as well versus a standard ported box.
Any insight anyone can provide would be helpful.
Jedi940 is offline
post #46 of 87 Old 04-03-2019, 07:30 AM
Samps's Avatar
Liked: 1009
I don't think this type of bandpass/horn offers any advantage over a ported box on the bottom end. The mid/top end is boosted by the horn section in front of the driver. Submaximus boosts the entire range thus reducing excursion for the same spl. V3 is a louder sub, but WAY bigger. 2.5 times the size!
Samps is offline
post #47 of 87 Old 04-03-2019, 09:57 AM
noah katz's Avatar
Quoted: 2624 Post(s)
Liked: 992
What's the purpose of the chamfer on the bottom edge of the leftmost panel?
Noah
noah katz is online now
post #48 of 87 Old 04-03-2019, 11:53 AM
JESAL's Avatar
Quoted: 41 Post(s)
Liked: 36
The chamfer on the port exit?
For blocking ports to lower tune
Vent Tuning: All vents open = 29.5Hz / 3 vents open = 25.5Hz / 2 vents open = 20.5Hz / 1 vent open = 14.5Hz
JESAL is offline
post #49 of 87 Old 04-03-2019, 12:46 PM
Samps's Avatar
Liked: 1009
He's talking about the 45 on the bottom of the square panel. I think it's to chop fingers off anyone who tries to steal it. Or decapitate cats heads when they climb in.
dsl1, JESAL and notfastenough like this.
Samps is offline
post #50 of 87 Old 04-03-2019, 01:45 PM
JESAL's Avatar
Quoted: 41 Post(s)
Liked: 36
Ah I see, the guillotine
JESAL is offline
post #51 of 87 Old 04-03-2019, 01:55 PM
Ricci's Avatar
Quoted: 423 Post(s)
Liked: 974
Basically correct. Right around port tune a vented box of the same size (That's outside cab dimensions) will have a bit more output at vent tuning from more air volume and larger vent area. This is due to deleting the volume taken up by the short expanding slot. This type of cab leverages a bit more output over the middle of the bandwidth and possibly more up top but that's subject to design choices made. In this case it trades a bit at vent tune for more from about 33-75Hz. Having the driver buried also reduces operational noises vs a direct radiator.
Not too familiar with a SMv3 other than reading the name a few times. At 2.5x the size of this (2x the size of a Skhorn?) it'd better be loud!
Jedi940 likes this.
Ricci is offline
post #52 of 87 Old 04-03-2019, 01:58 PM
Ricci's Avatar
Quoted: 423 Post(s)
Liked: 974
The edge is called an acoustic knife.
It's placement is carefully calculated to interrupt the waveform pulses emitted from the front radiation ducts at certain frequencies, causing a sudden dissipation of energy, resulting in the fastest, tightest, most airy bass ever achieved. It literally cuts the bass into individual packets of energy which are perfectly sized to better couple with your: Face, chest, neck, ears, spleen and liver. The only way to get tighter bass is to unplug the subs completely. I recommend a good set of cable lifters for the cables from the amps to the subs in order to further increase coherency. Our subs jump out of the dark, roundhouse kick you in the chest and melt into the shadows so fast we supply a 5 point safety harness and neck brace with each unit (after signing the liability waiver of course). A 7 week break in is done with real ninjas in a dojo. Accept no substitutions.
Or it could be to continue the expansion to the outside air and smooth airflow a minute infinitesimal amount, plus reduce weight by a few grams cause...Why not...
gpmbc, grek13, jujuman200 and 3 others like this.
Ricci is offline
post #53 of 87 Old 04-03-2019, 02:06 PM
noah katz's Avatar
Liked: 992
You're 2 days too late
peniku8 likes this.
Noah
post #54 of 87 Old 04-04-2019, 12:59 AM
Quoted: 569 Post(s)
Liked: 474
Would this sub be able to slice a ninja in half if tried anything stupid?
post #55 of 87 Old 04-04-2019, 09:45 AM
Ricci's Avatar
Quoted: 423 Post(s)
Liked: 974
I know. Missed my window.
Turns out that it explodes their heads
Trimlock likes this.
Ricci is offline
post #56 of 87 Old 04-04-2019, 10:45 AM
Quoted: 569 Post(s)
Liked: 474
in for 4!
post #57 of 87 Old 04-11-2019, 05:39 PM
dsl1's Avatar
Quoted: 206 Post(s)
Liked: 419
Look, a subwoofer! Kind of.
gpmbc, JESAL, filtor1 and 8 others like this.
dsl1 is offline
post #58 of 87 Old 04-12-2019, 11:04 AM
Ricci's Avatar
Quoted: 423 Post(s)
Liked: 974
Nice work as usual. What do you have going on with the back panel? No hatch?
Ricci is offline
post #59 of 87 Old 04-12-2019, 11:34 AM
dsl1's Avatar
Quoted: 206 Post(s)
Liked: 419
Just hadn't cut it yet. Those panels are cut from the reverse side.
dsl1 is offline
post #60 of 87 Old 04-12-2019, 04:20 PM
Gorilla Killa's Avatar
Quoted: 1627 Post(s)
Liked: 2438
Looks like it will be heading to the Dojo shortly for break in. Very nice!
8hz ULF TR for the masses and the Cashless. Like a BOSS
If you can't stand behind our troops stand in front of them
Gorilla Killa is online now
