Ricci's Skram - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 72Likes
post #61 of 87 Old 04-16-2019, 01:25 PM
dsl1's Avatar
Quoted: 202 Post(s)
Liked: 418
Progress. Hopefully the driver fits.
JESAL, filtor1, Jsin_N and 4 others like this.
________________________________________
DIY Mid Hi Speakers Build - SKHorn Build - Gjallarhorn Build SOLD - Othorn Build SOLD - SEOS 12 Build - Other Gear: JVC NX5 - Seymour Matinee Black - QSC CX4.5Q amps x 5 - QSC Q-sys 110f - Speakerpower 6000 x2
dsl1 is offline
post #62 of 87 Old 04-24-2019, 05:59 PM
Jedi940's Avatar
Quoted: 287 Post(s)
Liked: 203
How are these coming along?
Jedi940 is offline
post #63 of 87 Old 04-28-2019, 04:19 PM
JESAL's Avatar
Quoted: 40 Post(s)
Liked: 36
Couldn't paint today coz of a snow storm
Worked on my 2nd Skram instead
Should be able to give the Skrams a workout next weekend...
ID:	2559536   Click image for larger version
notfastenough likes this.
JESAL is offline
post #64 of 87 Old 04-29-2019, 08:03 AM
notfastenough's Avatar
Quoted: 190 Post(s)
Liked: 223
Kregs, copious PL, and bracing for days. Gotta love these bombproof enclosures Looking awesome!
notfastenough is offline
post #65 of 87 Old 04-29-2019, 08:54 AM
peniku8's Avatar
Quoted: 298 Post(s)
Liked: 278
I still never read a reasoning for PL. I used regular wood glue on my SKHorn. The bond is stronger than the wood anyways and I found it pretty easy to work with. In addition to that, you won't have to worry about the drying/hardening time when using screws additionally.
Why are most of you using PL?
Stereodude likes this.
A Star Is Born - Lady Gaga goes Rock Audio&Video by Ocean Studios (me)
SKHorn Build
Samsung KS7500 - Marantz NR1504 - Klipsch R-26F - Klipsch R-25C - Klipsch R-15M - SKHorn (on FP-13000 clone)
Bass EQ for Filtered Video Games
peniku8 is offline
post #66 of 87 Old 04-29-2019, 09:06 AM
Jk7.2's Avatar
Quoted: 1558 Post(s)
Liked: 2773
I think for one thing it adds peace of mind that you know there’s no air leaks. It’s nice that it doesn’t run down the panel when you have to glue a piece in on the vertical. Idk I’ve always used regular wood glue but if I was building a horn or something similar I’d use PL.
asarose247 and notfastenough like this.
Jk7.2 is offline
post #67 of 87 Old 04-29-2019, 09:30 AM
Quoted: 190 Post(s)
Liked: 223
It does have an expanding property to fill gaps. Also, as JK mentioned, squeeze out usually forms a bead rather than a "run" of glue all the way down the panel or on the floor. Because it turns to a bead, it can be trimmed off flush with a utility knife.
With the exception of needing gloves and considering rags disposable, it is pretty good stuff for building cabs. Smear-ability is at an 11 out of 10 too haha!
asarose247 and Jk7.2 like this.
post #68 of 87 Old 04-29-2019, 09:32 AM
Stereodude's Avatar
Quoted: 4343 Post(s)
Liked: 3082
What sort of gaps do you have in your typical enclosure between panels that you need to fill them with an expanding adhesive? If the edges are straight there aren't gaps with the sorts of enclosures I've built, but admittedly I don't use the same sort of bracing methods that seem to be popular here. The only time I've felt PL was necessary was on a pair of sonotubes where partially due to the flexible nature of the cardboard and slight size variances I had doubts as to how tight the joint was consistently between the endcap and the cardboard.
Stereodude is offline
post #69 of 87 Old 04-29-2019, 09:36 AM
Stereodude's Avatar
Liked: 3082
I bet you really just love the smell and the fact that it self dispenses (aka: the ooze factor).
post #70 of 87 Old 04-29-2019, 09:44 AM
Quoted: 190 Post(s)
Liked: 223
Actually, I don't really notice a smell. But tip oozing is a real thing
There are several instances where the expanding factor helps when building horns out of 1/2" plywood. Putting the side panel on is the one that can most easily get leaks and benefits from the PL.
EVERY plywood edge here is a potential loss with a small air leak and most of it can't be accessed once assembled. I'll take all the advantages I can get there!
lknhomeaudio and Jk7.2 like this.
post #71 of 87 Old 04-29-2019, 10:01 AM
peniku8's Avatar
Quoted: 298 Post(s)
Liked: 278
Well if you've read through my SKHorn build thread and seen my table saw you know why I usually don't worry about possible air leaks caused by imperfections
The only time I was annoyed by the wood glue was after painting the cab. The places where are tried to wipe the squeeze will look more shiny due to the smoother surface texture.
No air leaks here (I would've noticed the vinyl wrap bulging if there were any )
JESAL and Jk7.2 like this.
SKHorn Build
peniku8 is offline
post #72 of 87 Old 04-29-2019, 01:59 PM
noah katz's Avatar
Quoted: 2103 Post(s)
Liked: 758
Besides the reasons already mentioned for preferring PL, I find the quick set time of wood glue to be problematic.
Especially when you've already glued panels that may have some twist in them until a panel is added later that will force them into alignment.
Noah
noah katz is online now
post #73 of 87 Old 04-29-2019, 02:48 PM
asarose247's Avatar
Quoted: 1257 Post(s)
Liked: 1101
+1
getting that last side "right' after everything else
you only get 1 shot . . .
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is online now
post #74 of 87 Old 04-29-2019, 04:18 PM
N8DOGG's Avatar
Quoted: 1330 Post(s)
Liked: 1563
PL is lightyears faster to build with.
Can build the box in 1/2 the time easily... add some brad nail and you can start to finish in one shot.
No ones saying wood glue doesnt work, just PL is faster and holds just as well.
N8DOGG is online now
post #75 of 87 Old 04-29-2019, 04:19 PM
CrusherW9's Avatar
Quoted: 213 Post(s)
Liked: 127
Wanted to point out this point as being no joke. The last time I used PL without gloves I was like "meh, I'll just get it off my finger afterwards". My finger was numb/tingly for a day or two after that.
"Becoming educated is more than just acquiring knowledge. It involves the ability to see the world in ways never before conceived."
CrusherW9 is offline
post #76 of 87 Old 05-14-2019, 08:22 AM
Jedi940's Avatar
Quoted: 287 Post(s)
Liked: 203
This thread needs more updates and measurements of the finished product.
Jedi940 is offline
post #77 of 87 Old 08-28-2019, 09:19 PM
Quoted: 25 Post(s)
Liked: 1
Can anyone send me the CNC file for the skram? I have finally found someone that will cut them after searching for several months.
rotgg is online now
post #78 of 87 Old 08-29-2019, 06:55 AM
peniku8's Avatar
Quoted: 298 Post(s)
Liked: 278
And someone needs to build Ricci two of those
SKHorn Build
peniku8 is offline
post #79 of 87 Old 08-29-2019, 10:41 AM
Ricci's Avatar
Quoted: 391 Post(s)
Liked: 923
I'll get there eventually I swear! I haven't even asked around. I've got a bunch of higher priorities at the moment. Once things calm down I'll get to it.
A lot of other people seem to be cranking these out though.
Ricci is offline
post #80 of 87 Old 09-15-2019, 10:28 AM
JESAL's Avatar
Quoted: 40 Post(s)
Liked: 36
Here is a pic of my simple 2.1 system.
Very happy with this combo, gotta say thanks to the generosity of the creator, publicly sharing this killer sub, thank you Josh!
Sent from my SM-G955W using Tapatalk
femi likes this.
JESAL is offline
post #81 of 87 Old 09-15-2019, 10:44 AM
EndersShadow's Avatar
Quoted: 1268 Post(s)
Liked: 1538
More info on those mains... very interesting looking
My Setup | Custom MiniDSP Build | FS: If its For Sale, find it all (here)
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is offline
post #82 of 87 Old 09-15-2019, 10:49 AM
JESAL's Avatar
Quoted: 40 Post(s)
Liked: 36
Tops are Danley SH50s, bottoms are Skrams, sub in the middle is a Skhorn, all with B&C 21DS115s
JESAL is offline
post #83 of 87 Old 09-15-2019, 11:23 AM
gpmbc's Avatar
Quoted: 391 Post(s)
Liked: 277
@JESAL Nice set up! Concert Blu rays are probably better than live. What is your take on the sound signature between the SKhorn vs SKram?
JESAL likes this.
gpmbc is offline
post #84 of 87 Old 09-15-2019, 11:38 AM
Liked: 1538
OMG! The dynamic must be off the chain!
JESAL likes this.
post #85 of 87 Old 09-15-2019, 12:46 PM
JESAL's Avatar
Quoted: 40 Post(s)
Liked: 36
@gpmbc yes concerts at home, my favorite. Can't beat having the best seat in the house and sound adjusted just the way I like it.
Skhorn/Skrams pretty much have the same sound signatures. If I only have two drivers I prerer two Skrams than one Skhorn for placement/FR reasons.
Although I like how much air the Skhorn pushes out of its vents. When cranked I can feel it 10ft away
@EnderShadow yes dynamics is a bit insane with the FP20K amp, the neighbours are feeling it as much as I do... LOL
JESAL is offline
post #86 of 87 Old 09-15-2019, 06:20 PM
Ricci's Avatar
Quoted: 391 Post(s)
Liked: 923
If I ever make it out your way I have to get a listen to this combo. Headroom for days.
JESAL likes this.
Ricci is offline
post #87 of 87 Old 09-15-2019, 09:47 PM
JESAL's Avatar
Quoted: 40 Post(s)
Liked: 36
You're most welcome man, anytime
JESAL is offline
