The Magic Square Subwoofer Array - AVS Forum | Home Theater Discussions And Reviews
 30Likes
post #1 of 68 Old 04-01-2019, 08:30 AM - Thread Starter
LastButNotLeast's Avatar
Quoted: 2706 Post(s)
Liked: 2353
Inspired by this:
and unable to resist this:
https://www.avsforum.com/forum/155-d...y-bestbuy.html
and not having the skill, time, patience, or tools for a real DIY project, I came up with this:
For less than $600 and part of a weekend, in room response with eq from one channel of an iNuke 3000 DSP:
The key is to jump on the JBL drivers when they're on sale at Best Buy for $30. The sales appear to be random and short-lived, and won't last long since these drivers have become VERY popular.
As an alternative, Walmart usually has them for $43:
https://www.walmart.com/ip/CS1214-10...6-6de0c2a0f541
and Sonic has them for $50:
https://www.sonicelectronix.com/cat_...ubwoofers.html
Note that the CS1214 and CX1200 are the same except for the dustcaps.
shivaji, LTD02, fill35U and 2 others like this.
LastButNotLeast is offline
post #2 of 68 Old 04-01-2019, 08:30 AM - Thread Starter
Liked: 2353
3 Q Power HD12 triples:
Poly foam for stuffing, one pillow per speaker:
https://www.walmart.com/ip/Mainstays...-Each/20450258
Foam weatherstrip tape for a gasket, one per speaker:
https://www.ebay.com/itm/FROST-KING-...72.m2749.l2649
#8 3/4" black pan head screws:
https://www.ebay.com/itm/100-Pack-8-...72.m2749.l2649
If, like me, you don't like soldering, female spade terminals:
https://www.ebay.com/itm/100-Pcs-6-3...72.m2749.l2649
6.3mm is perfect for the large terminal of the driver. 4.8mm fits the terminals on the cabinet; large for the small terminal of the driver, but snug enough that I don't expect to have a problem. IIRC, someone found the smaller ones at an auto parts store.
Speaker wire:
https://www.amazon.com/AmazonBasics-...-1-spons&psc=1
Tools:
drill, screwdriver, wire cutter/crimper.
notfastenough likes this.
post #3 of 68 Old 04-01-2019, 08:48 AM - Thread Starter
Liked: 2353
Prepare wire from driver to box terminals. Be consistent about polarity! I put the large spade on the striped wire, and plugged that side into the terminal on the right in the box. Every single time. I hope.
Stuff each compartment with a pillow (I added more after this) and mark pilot holes. I found red worked best. Black, not so good.
Connect speaker (note additional stuffing):
At this point, you realize that you forgot to put the foam tape gasket on the driver:
A nail is very helpful for finding the pilot hole through the foam and carpet:
Wire it up:
As neat as that looks, give yourself more wire between the boxes so you can move them around without disconnecting them.
WAF version:
camouflage:
Where it really ended up, which is actually pretty inconspicuous:
I have the side boxes facing out. Measurements show it makes no difference:
Total cost less than $600, no skill and minimal tools required, great results.
Michael
post #4 of 68 Old 04-01-2019, 08:48 AM
bimmaguy's Avatar
Quoted: 142 Post(s)
Liked: 165
It also works with 16, 25, 36... etc.
I can't wait to see the first 144 sub array (12 x 12 12" subs). I'm counting on you guys.
Subs are like pizzas: you get way more good stuff with the big ones.
https://www.avsforum.com/forum/155-di...uxl-build.html
https://www.avsforum.com/forum/155-di...-overture.html
bimmaguy is offline
post #5 of 68 Old 04-01-2019, 09:22 AM - Thread Starter
Liked: 2353
I expect BassThatHz and others can do that with 18s.
I hope they do!
Michael
stegen likes this.
post #6 of 68 Old 04-01-2019, 09:32 AM
Stereodude's Avatar
Quoted: 4353 Post(s)
Liked: 3092
What is "it"?
I can't quite tell if this is some sort of April Fools joke or not. There are no outlandish claims, nor does it seem particularly out of character in terms of scale and scope of the DIY forum at AVS...
Stereodude is offline
post #7 of 68 Old 04-01-2019, 09:39 AM - Thread Starter
Liked: 2353
"It" refers to the magic square wiring; a way of getting a large number of speakers wired at a reasonable load for an amp.
No joke.
Michael
post #8 of 68 Old 04-01-2019, 09:42 AM
Quoted: 332 Post(s)
Liked: 332
Nice. How 'bout a magic cube next 3x3x3? You would have to get creative with how the center one fires but I have faith!
aschen is offline
post #9 of 68 Old 04-01-2019, 10:06 AM - Thread Starter
Liked: 2353
THAT would be an April Fool's joke.
Michael
post #10 of 68 Old 04-01-2019, 10:15 AM - Thread Starter
Liked: 2353
I failed to give credit where credit is due.
@rr14 for starting the ball rolling with a good driver at an amazing price:
https://www.avsforum.com/forum/155-d...l#post55108280
@bimmaguy for the "magic square:"
https://www.avsforum.com/forum/155-d...l#post57518464
@DavidK442 for the reminder of the gasket tape:
https://www.avsforum.com/forum/155-d...l#post57685152
@Chris Popovich for advising LOTS of stuffing:
https://www.avsforum.com/forum/155-d...l#post57770538
My sincere thanks to each of you, and to everyone in this community who encourages expanding horizons.
Michael
post #11 of 68 Old 04-01-2019, 10:32 AM
Nalleh's Avatar
Quoted: 2832 Post(s)
Liked: 3903
Awsome, nice job
About your placement, with them firing to the sides: you may not notice any difference in FR, but you SHOULD notice a difference in TR ! Did you try them all firing into your back? Your couch is not a reclining one, is it? If not, you should be able to put them RIGHT up to the back of your couch, within a inch or so. It should be noticable better for TR
Ask @SBuger
Dual AVR 13.1.8 SWAtmos - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 6xSI18" - 12xJBL 12" w/6xSLAPS M12 downfiring VNF - 3x2 stacked Crowson MA - 4xBK-LFE Dual TR Sleds- 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XB1X - ATV4K - Vertex2 - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873.
>>>>Nalleh’s HT<<<<
Nalleh is offline
post #12 of 68 Old 04-01-2019, 11:33 AM
dTorC4's Avatar
Quoted: 87 Post(s)
Liked: 147
Looks good, Last! Great job.
dTorC4 is offline
post #13 of 68 Old 04-01-2019, 11:48 AM - Thread Starter
Liked: 2353
They're just to the side of my mlp, leaving enough room for the back end of a mini-boss. Tonight's project. Stay tuned.
Michael
post #14 of 68 Old 04-01-2019, 12:35 PM
trilkb's Avatar
Quoted: 704 Post(s)
Liked: 370
Whats your DSP settings on the 3000dsp? Very good to 15hz. I think thats about where my 8 fall off but I have 4 in each corner 13' away from MLP.
Now throw in aquaman and piss everyone off while also having a huge smile on your face for the first 30 minutes, which will then turn into a groan of "will it ever stop?!?!?!".
- 6 x Boston Acoustic CR6 Frankencenter, Boston Acoustic CR8 L/R, 4 jbl 8330a surr , 8 x jbl 12" subs w/Inuke 6000. JVC rs420, Denon x4000, Sony x800 -
trilkb is offline
post #15 of 68 Old 04-01-2019, 12:59 PM
Zarkoff500's Avatar
Quoted: 238 Post(s)
Liked: 183
Off topic but I sure agree. Aquaman had 8/10 sound & visuals and <5/10 story. I felt like it was the 90's again with silly one liners, stereotypical characters and cliche everywhere.
Zarkoff500 is offline
post #16 of 68 Old 04-01-2019, 01:54 PM - Thread Starter
Liked: 2353
Is it possible (or worth it to you) to put the four you have into a 2x2 configuration?
Two of these magic square wired. Theoretically, some benefit.
Michael
post #17 of 68 Old 04-01-2019, 02:00 PM
jcmccorm's Avatar
Quoted: 632 Post(s)
Liked: 479
Still off-topic, but I watched this one over the weekend. I enjoyed it. But jeez the dialog left a little to be desired and some of the costuming was funny. Who thought it was ok to put Nicole Kidman in a fish suit with a huge fin down her back? And Black Manta looked a little silly. I still enjoyed it.
That being said, wow. The bass was here, there, and everywhere on that one. I know I'll be watching it again soon
Back on topic; let us know how that mini-boss works out Michael.
jcmccorm is offline
post #18 of 68 Old 04-01-2019, 02:55 PM - Thread Starter
Liked: 2353
Michael
Maybe this pic will show up.
EDIT: I give up. Both pics show up in my edit box, though neither shows up in the post.
Just imagine a box like mine, with two cutouts instead of three.
post #19 of 68 Old 04-01-2019, 03:06 PM
trhought's Avatar
Quoted: 975 Post(s)
Liked: 1524
WAF version:
Michael
Looks awesome Michael! Love the WAF version...lol. And the box of Kleenex to wipe the tears of joy....lol.
trhought is offline
post #20 of 68 Old 04-01-2019, 05:25 PM
asarose247's Avatar
Quoted: 1284 Post(s)
Liked: 1124
almost too suggestive of an overly idle mind . . devilishly clever
highly reminiscent of the "ruptured spleen" build, 16 x 12"'s ,former member moreisbetter, iirc,
tho there was not as diligent testing posted
He, seen here:
testing my Max V3 build, watch your volume
a speculation: 9 x PA-460's in a 60 x 60 x 12 sealed box?
finally 60 x 60 BB for a no hassle baffle.
Looks great.
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #21 of 68 Old 04-01-2019, 05:28 PM
Stereodude's Avatar
Liked: 3092
post #22 of 68 Old 04-01-2019, 06:03 PM - Thread Starter
Liked: 2353
I remember that! I was there.
Don't know how that was wired, though.
And had LOTS more amp (IIRC).
post #23 of 68 Old 04-01-2019, 06:03 PM
asarose247's Avatar
Liked: 1124
in depth driver comparison discussion
by @bluewizard
seems to be a glitch with use of capital letters
sorry
https://www.avforums.com/members/bluewizard.201342/
post #24 of 68 Old 04-01-2019, 09:28 PM
Marc Alexander's Avatar
Quoted: 5913 Post(s)
Liked: 5476
I have the side boxes facing out. Measurements show it makes no difference.
Sweet Michael! How is the TR nearfield and throughout the room?
Marc Alexander is online now
post #25 of 68 Old 04-01-2019, 09:48 PM - Thread Starter
Liked: 2353
I replaced my old ButtKicker with a mini-BOSS:
https://www.avsforum.com/forum/19-de...y-theater.html
Still a work in progress, but I'm very happy with the results in both TR and FR.
Highly recommended for anyone in the market for either/both.
Michael
post #26 of 68 Old 04-01-2019, 11:57 PM
Augerhandle's Avatar
Quoted: 1387 Post(s)
Liked: 1349
Poodle pillow. Say it three times fast.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #27 of 68 Old 04-02-2019, 04:31 AM
Falonious's Avatar
Quoted: 107 Post(s)
Liked: 103
Amazon has them for $37 w/free shipping.
https://www.amazon.com/JBL-Single-Vo.../dp/B07PNKVTDQ
All men dream: but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
T. E. Lawrence
Falonious is offline
post #28 of 68 Old 04-02-2019, 08:04 AM
trilkb's Avatar
Quoted: 704 Post(s)
Liked: 370
Michael
They are in a 2x2 configuration. 2 on bottom 2 on top, in each front corner (8 total) under my Left and Right mains.
trilkb is offline
post #29 of 68 Old 04-02-2019, 08:19 AM
trilkb's Avatar
Quoted: 704 Post(s)
Liked: 370
hmmm, maybe I need to buy 10 more and run 3x3 in each front corner off a nu6000dsp LOL.
Hardly think I need to but I certainly want to! the beating from aquaman told me I think Ive reached the end.
trilkb is offline
post #30 of 68 Old 04-02-2019, 01:53 PM - Thread Starter
Liked: 2353
Already sold out.
That didn't even last as long as Best Buy's sales.
Michael
