Simplest, smallest subsonic filter? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-06-2019, 01:40 PM - Thread Starter
rr14's Avatar
Quoted: 110 Post(s)
Liked: 31
Hi all,
I have a 270 watt amp pushing a 10" sub for theater/tv use. I don't have enough space to nearly port the woofer low enough as i'd like, so I'm considering a subsonic filter. Something to plug in between my receiver and amp. Any simple suggestions? I'm thinking about 30 or 35hz.
rr14 is offline
post #2 of 7 Old 04-06-2019, 01:57 PM
Quoted: 121 Post(s)
Liked: 121
Originally Posted by rr14 View Post
Hi all,
you can do a fmod but they are only 12db per octave.
https://www.parts-express.com/harris...s-rca--266-248
stngray72 is offline
post #3 of 7 Old 04-06-2019, 02:03 PM - Thread Starter
rr14's Avatar
Quoted: 110 Post(s)
Liked: 31
thanks. quick, easy and small. Probably not 100% ideal, but definitely should offer some protection.
rr14 is offline
post #4 of 7 Old 04-06-2019, 02:06 PM
holl_ands's Avatar
Quoted: 931 Post(s)
Liked: 505
I read you post to mean that you are looking for a BASS BOOST Filter...rather than a Filter to suppress Bass Freqs....
Rather than JUST Boost (say) 35-Hz, I would highly recommend that you consider a 1/3-Octave Band Filter Equalizer so that you can adjust ALL of the Frequency Bands going to your Sub-Woofer(s). Many AVR's do NOT have a sufficient number of Room Equalization Filters in this region to get the job done [you didn't say if you had this capability...which may be a good start]. Depending on room dimensions, there WILL be a Primary Room Mode (BOOST) at about 40-60 Hz and a Secondary Room Mode at twice that Frequency...which requires two BASS CUT Filters. The Null in-between those Freqs as well as Freqs below the Primary Freq require BASS BOOST Filters....plus one above the Secondary Frequency. That's a total of two BASS CUT and three BASS BOOST Filters (minimum). The fol. 1/3-Octave Band Filter Equalizer provides at least SEVEN Filters for the Frequencies going to the Sub-Woofer. It provides two channels so that you could independently equalize TWO Sub-Woofers when you decide you want to upgrade:
https://www.amazon.com/Rockville-REQ.../dp/B01LZL8LGT [$99 on Amazon]
FYI: A LOT more about Room Equalization:
https://www.avsforum.com/forum/113-s...l#post54537820
holl_ands is offline
post #5 of 7 Old 04-06-2019, 02:08 PM - Thread Starter
rr14's Avatar
Quoted: 110 Post(s)
Liked: 31
I'm looking to cut frequencies below 30hz to protect my woofer in a ported box.
rr14 is offline
post #6 of 7 Old 04-07-2019, 09:07 AM
keeper's Avatar
Quoted: 601 Post(s)
Liked: 247
This is also a question that I have. The cheapest option seems to be the old minidsp the non hd for around $100. I believe you can set the subsonic filter on that but I’m not sure how easy it is to learn/do.
keeper is online now
post #7 of 7 Old 04-07-2019, 11:09 AM
CrusherW9's Avatar
Quoted: 206 Post(s)
Liked: 116
A subsonic filter is just a high pass filter. Very easy to do on a MiniDSP. Regarding those FMODs, if you want a 24db/octave high pass you could just use two of those in a row.
"Becoming educated is more than just acquiring knowledge. It involves the ability to see the world in ways never before conceived."
CrusherW9 is offline
