Jk’s htm-8, mbm-12 towers - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 364Likes
post #31 of 282 Old 04-18-2019, 06:06 PM
johnson636's Avatar
Quoted: 1134 Post(s)
Liked: 654
Originally Posted by BP1Fanatic View Post
Geez jk7.2, you have a very high liked to post ratio! Excellent work!
Dude is a beast! And I mean that in a good way
Jk7.2 likes this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #32 of 282 Old 04-18-2019, 07:22 PM
Vital's Avatar
Quoted: 12 Post(s)
Liked: 34
Originally Posted by Jk7.2 View Post
A very good friend came over the other day and very nicely asked me to sell him my entire 893 setup I just built with subs. So I sold the setup. That leaves me a hole to fill in the living room. Hence this new build. Towers with htm-8’s on top of 12” mbm’s. This will be all one box, separate section sealed between the woofer and the htm. I got the idea when seeing all the builds lately where the baffles are being chopped up and used as needed. So I’ll be cutting off the roundovers and using the baffles I now have. Upper section will be ported as designed, and the lower will be ported via slot port 2” tall, 13” wide, and 24” long. Netting a 28hz tune. Should be fantastic for 2 channel music. Much more to come.
Overall dimensions are 16x15x42
Sub'd for this one, looking forward to it!
Vital is offline
post #33 of 282 Old 04-19-2019, 03:46 AM
Stereodude's Avatar
Quoted: 4179 Post(s)
Liked: 2959
You don't have this build finished yet? You're slipping!
Stereodude is online now
post #34 of 282 Old 04-19-2019, 07:41 AM
Quoted: 147 Post(s)
Liked: 67
Recommendation after doing a good amount of work with tbe MBM12s in a full range design, with that lower tune and the total output capability of them limited by excursion, to get the most out of your HTM8, consider going with two 12s. The 12 solo is going to run out gas long before the HTM, however having said that if your happy with less than max spl, just put a limiter on your 12 at max excursion (300-400w IIRL) to protect it and level match the HTM. I also agree that crossing the 12 higher at 120-150Hz or so and sealing or raising the tune of the HTM might be a bit more efficient, using the best of all deivers in their wheelhouse.
In any case i really like the design and plan man!!! Ill be following!
Sent from my iPhone using Tapatalk Pro
Jk7.2 likes this.
FOHTech is offline
post #35 of 282 Old 04-19-2019, 07:55 AM - Thread Starter
Jk7.2's Avatar
Quoted: 1397 Post(s)
Liked: 2550
Yeah I’m no speaker designer! I was gonna try and keep this build simple. I had 1099’s that I played 2 channel ontop of the mbm12’s before, and I thought that sounded good. Even with movie content. Those 12’s were getting an inuke 3000dsp bridged. So close to 1000 watts each woofer. Highpassed accordingly. With this speaker, it’s in one cab, but I’m treating it as htm-8 with a sub. So audyssey will see it as htm-8 mains and mbm-12’s as the lfe output. I’ll definitely play with crossover and raise it, measure results and so on. We’re not going for max spl here, but if bottom end is lacking, I also picked up 4 more of the limited availability 15’s, so I’ll use one or two!
Thanks for your interest in my project and your advice.
Jk7.2 is online now
post #36 of 282 Old 04-19-2019, 10:25 AM
Quoted: 147 Post(s)
Liked: 67
Hey no worries. Youre project is gonna kick some tail. I spent waaaaaay too many hours tweaking and learning from my full range build so I can lend a hand if needed. You’ve certainly helped me with some great ideas.
I was thinking and you know, if you put the 12s in the same cab as the 8s and of course sealed the HTM secrion from the MBM, you can run the AVR as small crossed at 70-80hz (whichever looks flatter in room) and then let it send the sub 80 content to the MBMs below 80 to the LFE. Youre not directional below 80 or even better 70 so I think for simplicity, youd have a hell of an LCR doing it that way. Even music will sound pretty awesome.
You gave me an idea for fulk range floor standing surrounds. My side and back needs to be sonewhat narrow and moreso shallow for my room and I really wanted a full range side and back so Im not sending any surround to the LFE, soooo Im thinking of designing a tower that takes the HTM-8 and adds additional 8s (maybe 2-3) like a UM-8 (or something less expensive) ported to a 42 Hz tune (same as my LCR).
Cant wait to see how it goes. Regardless if what you do it will be awesome!!
Jk7.2 likes this.
FOHTech is offline
post #37 of 282 Old 04-19-2019, 10:31 AM - Thread Starter
Jk7.2's Avatar
Liked: 2550
I think this is what I’m planning. Separate box area for the htm and mbm, mbm signal from lfe output, htm’s as mains.
I’ll be sure to keep this thread updated to keep hearing everyone’s ideas.
Jk7.2 is online now
post #38 of 282 Old 04-19-2019, 12:43 PM
imrf's Avatar
Quoted: 197 Post(s)
Liked: 119
Are you going to do a center at all since the setup you sold was a LCR build?
imrf is offline
post #39 of 282 Old 04-19-2019, 12:54 PM - Thread Starter
Jk7.2's Avatar
Liked: 2550
No not in the current plan.
imrf likes this.
Jk7.2 is online now
post #40 of 282 Old 04-19-2019, 04:01 PM
smcmillan2's Avatar
Quoted: 779 Post(s)
Liked: 684
I don't recall a center in your 893/MBM build, but my "remembery" isn't what it used to be.
Regardless, is this build done yet?? You don't usually pussyfoot around on these!
smcmillan2 is online now
post #41 of 282 Old 04-19-2019, 04:05 PM
johnson636's Avatar
Liked: 654
Hmm, I don't remember a center either.
post #42 of 282 Old 04-19-2019, 04:49 PM
imrf's Avatar
Quoted: 197 Post(s)
Liked: 119
You’d have to go through his other thread but yeah, he made one. Here’s a pic of the 3 boxes.
Jk7.2 likes this.
imrf is offline
post #43 of 282 Old 04-19-2019, 05:10 PM
johnson636's Avatar
Liked: 654
Attachment 2555618
Yup, you're exactly correct
post #44 of 282 Old 04-20-2019, 06:02 AM - Thread Starter
Jk7.2's Avatar
Liked: 2550
The center channel hadn’t made it into the system yet. But here it is.
bubbrik likes this.
Jk7.2 is online now
post #45 of 282 Old 04-20-2019, 06:13 AM
BP1Fanatic's Avatar
Quoted: 195 Post(s)
Liked: 158
Excellent build quality!
Sony XBR65x900e / STR-DN1080 / original PS4 / WOW! Ultra TV / Quantum Access Mini PC Stick w/Windows 10 / 8 x Rockville SPG88 8“ DJ PA Speakers / Dayton Audio SA1000 / Kicker 08S15L74 in a Tapped-Tapered Quarter Wave Tube (negative flare tapped horn).
BP1Fanatic is offline
post #46 of 282 Old 04-20-2019, 06:14 AM - Thread Starter
Jk7.2's Avatar
Liked: 2550
Thanks. I love veneer. It covers the seams and finishes easy.
Jk7.2 is online now
post #47 of 282 Old 04-20-2019, 06:50 AM
dasa2131's Avatar
Quoted: 53 Post(s)
Liked: 57
Beautiful work, sir! I'd like to ask about the veneer:
What species did you use?
Paper backed? If so, did you use the old school contact cement method?
Dave
dasa2131 is offline
post #48 of 282 Old 04-20-2019, 07:46 AM - Thread Starter
Jk7.2's Avatar
Liked: 2550
Dave
Yes. Band-it paperbacked Walnut. Contact cement for me. It’s easy. Though toxic.
Rjloper9 and kagtha like this.
Jk7.2 is online now
post #49 of 282 Old 04-20-2019, 08:14 AM
smcmillan2's Avatar
Quoted: 779 Post(s)
Liked: 684
And highly flammable (unless you go with the water-based, which I don't care for). Best used outdoors, definitely away from ignition sources!
post #50 of 282 Old 04-20-2019, 10:39 AM - Thread Starter
Jk7.2's Avatar
Liked: 2550
Lol I won’t be. But my cutlist of mdf won’t be ready for pickup until Tuesday or Wednesday. Just waiting until then.
Jk7.2 is online now
post #51 of 282 Old 04-22-2019, 01:20 PM - Thread Starter
Jk7.2's Avatar
Liked: 2550
Got all my mdf, a day early!
Still I can’t start my boxes. I get to install a closet organizer and new closet doors
Jk7.2 is online now
post #52 of 282 Old 04-22-2019, 05:34 PM - Thread Starter
Jk7.2's Avatar
Liked: 2550
I carved out an hour to play. I call this my ‘proof of concept’ mock-up. These are gonna be sweet. The baffle will be flush when done and the whole front veneered. I’m excited about this project.
Jk7.2 is online now
post #53 of 282 Old 04-22-2019, 06:03 PM
smcmillan2's Avatar
Quoted: 779 Post(s)
Liked: 684
What, no pictures of the closet organizer and new closet doors??
Jk7.2 likes this.
post #54 of 282 Old 04-22-2019, 07:48 PM
Stereodude's Avatar
Liked: 2959
Where did you get your MDF from? It doesn't seem like you're cutting it yourself, but it doesn't look like it was shipped to you either.
post #55 of 282 Old 04-22-2019, 08:08 PM
imrf's Avatar
Quoted: 197 Post(s)
Liked: 119
Mann’s lumber in Canton.
imrf is offline
post #56 of 282 Old 04-23-2019, 07:03 AM
BP1Fanatic's Avatar
Quoted: 195 Post(s)
Liked: 158
Oh, so you fellas came to Ohio for the wood?
That mock up looks AWESOME!
post #57 of 282 Old 04-23-2019, 07:07 AM
BP1Fanatic's Avatar
Quoted: 195 Post(s)
Liked: 158
I think I would plug the round ports and try to make those 2 slots work as ports???
post #58 of 282 Old 04-23-2019, 07:10 AM - Thread Starter
Jk7.2's Avatar
Liked: 2550
My plan is to run the baffles through a table saw and take off the roundovers. So the tower baffles will be 4 pieces of wood all glued up into one. My bottom panel, the htm baffle, and I have two mdf strips for the sides of the htm baffle. I plan on keeping the round ports.
kagtha likes this.
Jk7.2 is online now
post #59 of 282 Old 04-23-2019, 08:07 AM
imrf's Avatar
Quoted: 197 Post(s)
Liked: 119
No, Canton, Michigan.
imrf is offline
post #60 of 282 Old 04-23-2019, 11:11 AM
BP1Fanatic's Avatar
Quoted: 195 Post(s)
Liked: 158
For those of you who don't know, American football was created in Canton, Ohio where the Pro Football Hall Of Fame is located. Go Buckeyes!
