Soldering wires together - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By b curry
  • 1 Post By Wayne A. Pflughaupt
post #1 of 9 Old 04-18-2019, 08:58 PM - Thread Starter
stegen's Avatar
Quoted: 179 Post(s)
Liked: 117
I need to run a few 12 awg wires to relocated speakers. I bought a new roll but it will run short. Can I solder 2 lines together for 2 of the runs without any loss in sound quality or issues? I know I'm being cheap but I'll end up throwing away a good deal of 12awg that's too short. If not I'll just order another and wait to wire everything. Non-inwall if that makes a difference
stegen is offline
post #2 of 9 Old 04-18-2019, 10:37 PM
kennyandersen's Avatar
Quoted: 139 Post(s)
Liked: 103
Sure. You could slide on some heat shrink tubing, twist then together in-line and then shrink the tubing on. Look good, sound fine.
Sent from my Moto G (5) Plus using Tapatalk
kennyandersen is offline
post #3 of 9 Old 04-19-2019, 01:33 AM
markmon1's Avatar
Quoted: 4265 Post(s)
Liked: 2671
Yep, this method works great and no solder is required. The wire is folded down and the heat shrink holds it.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #4 of 9 Old 04-19-2019, 05:08 AM
Quoted: 139 Post(s)
Liked: 103
I solder it also. Mo strong.
post #5 of 9 Old 04-19-2019, 06:23 AM - Thread Starter
stegen's Avatar
Quoted: 179 Post(s)
Liked: 117
Great! Thanks guys.
stegen is offline
post #6 of 9 Old 04-19-2019, 06:55 AM
jcr159's Avatar
Quoted: 163 Post(s)
Liked: 87
or use some crimping butt splice connectors
like these:
https://www.amazon.com/Gardner-Bende...012774ESC?th=1
or these:
https://www.amazon.com/3M-Scotchlok-.../dp/B0081JXFLI
Have a question and want it answered in podcast format?
[email protected]
http://www.avrant.com/
https://www.youtube.com/c/avrant
jcr159 is offline
post #7 of 9 Old 04-19-2019, 07:11 AM
b curry's Avatar
Quoted: 948 Post(s)
Liked: 613
Absolutely. It's no different than the wire inside the speaker box soldered to the exterior attachment terminals on to the crossover and on to the speaker itself. Or the components soldered to the circuit board of the crossover or the circuit boards of the electronics attached at the other end of the speaker wire.
As mentioned above, twist the wires together and solder. Use some heat shrink tubing for a nice clean job or some electrical tape at a minimum.
Another possible way to join the wires is to use crimp connectors that you can easily find at a hardware store, Home Depot, etc.
stegen likes this.
b curry is offline
post #8 of 9 Old 04-19-2019, 07:14 AM - Thread Starter
stegen's Avatar
Quoted: 179 Post(s)
Liked: 117
Kinda what I originally thought, theres lots of soldered joints throughout anyway.
stegen is offline
post #9 of 9 Old 04-19-2019, 04:38 PM
Wayne A. Pflughaupt's Avatar
Quoted: 398 Post(s)
Liked: 319
It will require a serious soldering iron to solder two pieces of 12-ga. wire together, and it will probably end up melting the insulation. Better to use crimped connections instead. Look for a handy guide to splicing wire in my signature.
Wayne A. Pflughaupt
fill35U likes this.
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
