NX4-6000 With DSP? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By johnson636
post #1 of 13 Old 04-19-2019, 09:09 AM - Thread Starter
doodoobutter's Avatar
Quoted: 45 Post(s)
NX4-6000 With DSP?
My google action doesn't return any results. Are they going to put out this amp with DSP like they did with the NX6000D? It would be nice to run mains, center, and subs off of one amp (assuming I can run different resistance on different channels).
doodoobutter is offline
post #2 of 13 Old 04-19-2019, 10:27 AM
Quoted: 1468 Post(s)
Liked: 1044
No, you’d need a MiniDSP of some sort. Also, why would you need 2000 something watts per channel of your LCR? Not to mention that iNukes aren’t generally known for having the better quality sound. Your AVR’s amp section will sound better. At least mine does.
Leave it at 8 ohms and call it a day :)
Russdawg1 is offline
post #3 of 13 Old 04-19-2019, 10:49 AM - Thread Starter
Quoted: 45 Post(s)
It's a 4 channel amp. The 2 channel version does have a DSP option, so I was hoping this one would too at some point. My mains and center are going to be HT-12s. That would give 440 watts each to the mains and center at 8ohms, and 860 watts from one channel to 4x 12" subwoofers at 4ohms. I don't think it's overkill, and honestly I'm leaving a couple hundred watts on the table with the subs. I could do 2 ohms with the subs if the amp will let me.
I'd really like them to put out this amp with DSP.
post #4 of 13 Old 04-19-2019, 10:52 AM
Liked: 1044
They didn’t release the old NU4 6000 in a DSP form which is why I don’t think the NX series will come out with one.
Might I ask what the efficiency of your HT-12’s are?
And the NX does 2 ohms last time I checked.
post #5 of 13 Old 04-19-2019, 11:08 AM
smcmillan2's Avatar
Quoted: 809 Post(s)
Liked: 707
I think you'll be surprised at how easy the HTMs are to drive. I can easily get my HTM-10s to uncomfortable levels with AVR power - ~70W/channel max. So I would say 440W is overkill, but what the heck, this is the DIY subforum.
smcmillan2 is online now
post #6 of 13 Old 04-19-2019, 01:52 PM
Oklahomie's Avatar
Quoted: 227 Post(s)
Liked: 763
I was told at some point in time not use a pro amp for LRC duties. You might ask Erich what he recommends for an amplifier, but even a receiver can make those speakers shine.
For reference, I am driving my titans from my receiver and they sound incredible. I think I’m pushing 110 watts per channel.
Aaron H.
Aaron H.
Oklahomie is offline
post #7 of 13 Old 04-19-2019, 03:32 PM
johnson636's Avatar
Quoted: 1146 Post(s)
Liked: 671
I'm really not sure where all this "pro amps are bad for mains" business is coming from. I've run my mains, rears and atmos with a combination of pro amps and I can't tell any difference at all when I used the avr to power them; whether it be measurements or my ears. I'm currently running my mains with a clone 10k. If there is a difference it certainly not discernible.
SpinMonster likes this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #8 of 13 Old 04-19-2019, 04:39 PM
smcmillan2's Avatar
Quoted: 809 Post(s)
Liked: 707
I don't see where "all this "pro amps are bad for mains" business is coming from." is in this thread. Once the OP disclosed that they were looking at the DIYSG HT line the responses were fairly static, that the OP would likely be very happy with them on AVR power (with the possible exception that I mistook the OP's HT response to be HTM).
In short, run the HTs on AVR power. If you feel the need to get them going harder than that, look into outboard amps.
post #9 of 13 Old 04-19-2019, 04:49 PM
johnson636's Avatar
Liked: 671
The avr being very capable of running speakers is different from saying using pro amps on mains is bad. This sentiment has been post in various thread as of late. I do agree that most diysg speakers can be driven well by the avr
post #10 of 13 Old 04-19-2019, 06:08 PM
rr14's Avatar
Quoted: 110 Post(s)
Liked: 31
there have been several people that switched from reputable amps to inukes and wouldn't go back. I'm sure someone will chime in soon. An emotiva to inuke 4-6000 discussion a while back comes to mind.
rr14 is offline
post #11 of 13 Old 04-19-2019, 08:08 PM
Oklahomie's Avatar
Quoted: 227 Post(s)
Liked: 763
Sorry guys, my intent was not to dog on inukes for LRC duties. I guess more importantly than what if they are good or not for that use, I do think it’s probably too much power for the duty, but I’m not an expert, so I’ll hush. I’m sure it would work great!
Aaron H.
Aaron H.
post #12 of 13 Old 04-21-2019, 07:51 AM - Thread Starter
Quoted: 45 Post(s)
Sorry for the delay, 16 hour shifts, ugh.
I guess I'll give up on the 4 channel amp coming out with DSP and get 2 amps. I'm kind of hesitant to beat on an AVR with these, I tend to blast music and it's a large space. I'll drive the center with the AVR and the mains and subwoofers from pro amps. I guess I'll try driving the HTs from both and see if I can hear the difference. I can always use that amp for more subwoofers if I don't like it driving the mains.
To answer a question, the HTs have a sensitivity of 97db. I do plan to run them at reference from time to time. Possibly some live concert blurays with hearing protection on because beer and I might be crazy.
post #13 of 13 Old 04-22-2019, 09:14 PM
matt/E's Avatar
Quoted: 38 Post(s)
Liked: 33
Something like an Emotiva XPA-3 or XPA-5 would be my recommendation, and then an iNuke or NX for the subs.
Marantz AV8801/ Sherbourn PA 7-350/ Dayton APA102
Minix NEO U9-H / WDTV Live/ LG BP-620/ Sharp Aquos 65" 4K UHD TV
Klipsch RF-83's/ RC-7/ RS-62's/ RS400's/ RB-10's
Lab Gruppen FP14000 clone/ 2 Peerless STW 15's
matt/E is offline
