BOSS Build with 3 JBL 12” drivers - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 192Likes
post #61 of 119 Old 05-17-2019, 11:03 AM - Thread Starter
Sekosche's Avatar
Quoted: 1361 Post(s)
Liked: 3333
Ok, so gluing/brad nailing both boards together first and then routing is way easier. Can knock out 6 holes in no time...can’t believe I didn’t do this the first time.
Hard part is done!
mp3truck, Nalleh and bubbrik like this.
Speakers: PSA MTM-210T x2, MTM-210C, MT-110SR x2; Atmos-SVS Satellite x2, DIY Volt-10 x2
Subs: PSA V1801 x2, DIY: 18" RSS460HO, 15" RSS390HO x2, BOSS w/JBL CX1200 x6
MA’s: Crowson Tech x2
Processing: Denon X4200, NU6KDSP, 3KDSP
Video: Epson 3700; Screen: Silver Ticket 106" High Contrast
Sekosche is online now
post #62 of 119 Old 05-17-2019, 01:04 PM
Nalleh's Avatar
Quoted: 2385 Post(s)
Liked: 3039
Looks great, good job, man
Sekosche likes this.
Dual Atmos Receivers - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 4xSI-HT18v2 in 2xDO Sonos - 12x12" JBL GT-X1200 NF - 3x2 stacked Crowson MA - 4xBK-LFE - 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XBox OneX - Apple TV4K - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873 - Harmony Ultimate.
Nalleh’s HT
Nalleh is online now
post #63 of 119 Old 05-17-2019, 01:50 PM - Thread Starter
Sekosche's Avatar
Liked: 3333
Awww haha, I bought a 3/8” inch rabetting bit with 1/2” depth to counter sink the driver, because that’s all the first store I went to had and that slight difference means another trip to a different store now, was hoping they’d magically fit. Looks like this is going to bleed into tomorrow, family plans tonight. Oh well, liking how this one is turning out!
1/4” too small for the driver to sit flush!
Nalleh likes this.
post #64 of 119 Old 05-17-2019, 01:52 PM
BryceDH's Avatar
Quoted: 171 Post(s)
Liked: 154
It may not fit yet but it sure looks nice. I cant do that with my jigsaw. Lol
Sent from my SM-N960U using Tapatalk
Equipment: Yamaha 3050, Oppo 103d, PSA mt 110s (L,C,R), Polk tsi200 (SR/L), 2 VBSS, FullMarty, 4 driver BOSS build, umik-1, Epson 3700
BryceDH is online now
post #65 of 119 Old 05-17-2019, 05:22 PM - Thread Starter
Sekosche's Avatar
Liked: 3333
Sure it’s round, but not flush yet, lol. I should’ve cut the outer diameter larger for the flush mount first, but I was just thinking of the ease of cutting both holes at the same time and using a rabetting bit, didn’t realize the rabetting bits are all a hair too small to do what I wanted. So instead of free hand trimming around each hole which would work fine, and it’s not like anyone will ever see it, I’m getting creative with a 45 degree chamfer bit to take a little more off the inner diameter; and hopefully after all that it’ll allow me to use the 3/8” rabetting to get what I need to drop the drivers in flush. If it doesn’t, guess I’ll cut a larger circle jig to trim around the edges.
post #66 of 119 Old 05-17-2019, 06:25 PM
jcmccorm's Avatar
Quoted: 587 Post(s)
Liked: 435
I couldn't find the right size rabett the size I needed locally so just made a new hole for my circle jig (a couple holes actually; needed to make two passes) to recess these JBLs. Anyway, I feel your pain. Luckily for me, I figured it out before cutting out the first big hole. What will you attach the circle jig to?
jcmccorm is offline
post #67 of 119 Old 05-17-2019, 06:54 PM - Thread Starter
Sekosche's Avatar
Liked: 3333
Didn’t realize it would be this much of a pain to flush mount after the fact...lessons learned.
Tried my chamfer bit idea, and it sort of works but is more work than just creating a larger circle to place around the hole as a guide with a half inch bit set to a half inch depth...doesn’t really matter how it looks. I guess I’m being silly, as it’s literally hidden underneath a couch, lol.
post #68 of 119 Old 05-17-2019, 07:55 PM
lizrussspike's Avatar
Quoted: 1091 Post(s)
Liked: 1610
Impressive @Sekosche ! Looking forward to your review of the BOSS Six.
lizrussspike is offline
post #69 of 119 Old 05-17-2019, 09:15 PM - Thread Starter
Sekosche's Avatar
Liked: 3333
So the outer diameter of these driver frames are 12 and 1/4”! No wonder, I was thinking just 12” even after routing out a little more on top of the 3/8” rabetting bit they still wouldn’t fit. Would need a 5/8” cut around the inner diameter for a flush fit. Guess I’ll just stick with cutting a larger circle guide and run a 1/2” straight bit on top of the 3/8” rabetting to finish up.
post #70 of 119 Old 05-17-2019, 10:11 PM
Nalleh's Avatar
Liked: 3039
HAHA, jiis man, i though you had learn by now: measure twice, cut once
ALWAYS check measurements
Nalleh’s HT
post #71 of 119 Old 05-18-2019, 06:54 AM - Thread Starter
Sekosche's Avatar
Liked: 3333
Haha, instructions and spec sheets? What are those for when I have experience, lol?
I blame the rabetting bit plan not working like I hoped to flush mount, lol, otherwise it’s a minor setback that‘s added time. I saw a lot of 1/2” rabett bits but totally spaced on the driver outer diameter being 12.25”, needing essentially a 5/8” extra cut to fit flush with the 11” holes. Also, most of the 1/2” rabetting bits are in respect to depth and not the radius of the cut, so I was off either way.
Building a new jig and getting back to work on it shortly.
How’s your 18” TR ejector seat coming along?
post #72 of 119 Old 05-18-2019, 07:51 AM
Stereodude's Avatar
Quoted: 4144 Post(s)
Liked: 2942
It's not that hard to do after the fact. Hot glue a strip of wood across the hole and then glue a spacer that's the thickness of the boards in the center of the hole on the strip. Find the center of your hole, mark it on the block sitting in the approximate center, drill a hole for the pin of the router circle jig, and you can use your normal plunge router base on the circle jig to make the recess (like you would have done in the first place). When done, knock the hot glued strip off. I've found that hot glue is surprisingly strong between two pieces of wood, so don't use too much.
Stereodude is online now
post #73 of 119 Old 05-18-2019, 09:48 AM - Thread Starter
Sekosche's Avatar
Liked: 3333
I was going to make a circle jig or just use my previous Milescraft guide, but in the end I chose to just free hand it. I only need a 1/4” taken off all around after the 3/8” rabetting, so instead of all that work per hole free hand won out. Sure, it’s not perfect, but the recess doesn’t matter to me. Wasted too much time on worrying about it already; I’ll be able to sleep at night with this being the only thing I didn’t finish correctly.
Good enough, just traced a 1/2” around each after the 3/8” rabetting and free hand routed, much faster, should have just done this yesterday! One of these days I’ll get a project right from start to finish as intended.
post #74 of 119 Old 05-20-2019, 05:17 AM
Quoted: 154 Post(s)
Liked: 217
Looks like a fun build.
Question for the experts. Why go with a quantity of 3 subs? I though the rule of thumb was to use multiple of 2 in order to keep the ohms at 2/4/8? Are two sheets of plywood necessary for couch support or would one sheet of plywood be sufficient for the average couch?
lmidgitd is offline
post #75 of 119 Old 05-20-2019, 05:39 AM
markmon1's Avatar
Quoted: 4438 Post(s)
Liked: 2777
How silent are the subs in this configuration? I realize that completely open air, you get equal wave cancellation but this is a little different. You have some of the subs under a mostly enclosed couch and that couch can easily act as the speaker box. And while it may not be a great speaker box, it's probably enough to at least let the BOSS create some sound.
Even when I mounted my earthquake MQB-1's in my couch I was able to hear some resonation from them. I had to move them externally and the sound was gone.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #76 of 119 Old 05-20-2019, 06:08 AM - Thread Starter
Sekosche's Avatar
Liked: 3333
I just did 3 to fit easily where I have little spaces in my couch frame, and now I’m adding 3 more behind the couch. It is probably easier to do multiples of 2, but the amplifier won’t know the difference as long as it has enough power and is stable to drive the end load.
One sheet of plywood might be enough, but I’m not really sure there how much flexing would depend on all the other design variables. I’ve only built the BOSS with two sheets, but one 3/4” sheet is still pretty darn stiff in my mini riser that’s bolted to the couch frame so you might be OK.
My design is actually totally open with big gaps all around and above the drivers so I get no added SPL or awkward noises from this configuration even with minimal ground clearance; the BOSS 2.0 will move the drivers ups further 1/2” off the ground too.
I did notice with my ear to the floor in the front where I have a shag carpet, there’s a faint noise of chuffing/air blowing under heavy use on the rug. Otherwise, they’re totally silent how I have them set up. I’m not sure if the resonating you heard from the MB Quart was mechanical driver noise or your furniture vibrating or added SPL, but the JBL’s are silent to me in this application.
lmidgitd likes this.
post #77 of 119 Old 05-20-2019, 06:13 AM
markmon1's Avatar
Liked: 2777
The MQB-1's are transducers not subs so they should be silent. But even those moving around a tiny bit in the empty couch cavity caused some audible sensation if you paid attention and at lower volume.
I really like the BOSS idea.
markmon1 is offline
post #78 of 119 Old 05-20-2019, 07:02 AM - Thread Starter
Sekosche's Avatar
Liked: 3333
Ah sorry, had the BOSS drivers on the brain and they’re named similar . I could also hear buttkickers vibrate some during quiet scenes when I tried them, so I’m guessing that’s just the nature of those shaker’s engineering. If you’re interested in a BOSS build, definitely try it out. You can also combine the two for truly ridiculous amounts of TR like a few people currently are.
post #79 of 119 Old 05-20-2019, 02:44 PM
markmon1's Avatar
Liked: 2777
Ya buttkickers are very noisy. The mqb1s are silent. It was the couch cavity causing the noise. As I said, moving them out of inside the couch solved it 100%.
markmon1 is offline
post #80 of 119 Old 05-22-2019, 07:45 AM - Thread Starter
Sekosche's Avatar
Liked: 3333
Finishing up BOSS 2.0 this afternoon. Nearly done! Have to run errands a while but hopefully will finish up by tonight. I’ve got Hellboy II and Godzilla (1998) with BEQ ready to break them in tomorrow.
Flush mount cuts
45 degree bevel on the edges instead of a roundover just to change it up, can’t really tell from the pic
A little darker stain than BOSS 1.0
post #81 of 119 Old 05-22-2019, 09:27 AM
notfastenough's Avatar
Quoted: 161 Post(s)
Liked: 191
Looks like that platform will remove fillings!! Pretty cool build for something going under a couch lol. Gotta say, I'm a bit envious of how this is going, great stuff!!
Not sure if it was nature of the build or not, but I noticed a router gouge for the beveled edge. Something I've had to do to prevent that is managing the piece being worked on. It looks like the bevel was added with the BOSS on the ground. Setting it up on trashcans or sawhorses makes a world of difference. If it shifts around too much while moving the router along the edge, add weight to the platform.
Being more aware of this has helped improve my hand-held router results to beyond my actual woodworking skill level haha!
notfastenough is online now
post #82 of 119 Old 05-22-2019, 09:56 AM - Thread Starter
Sekosche's Avatar
Liked: 3333
Thanks, it’s a fun little project that’s for sure! I figure most people have couches with multiple sub drivers built into them...right?
Any imperfections were due to the plywood voids in a couple spots that the router bit guide ran deeper into, no worries. After quickly free handing the flush mount, I can live with some minor imperfections. This new platform will be almost totally hidden under the seating, not really sure why I always router the edges of nearly everything I do, but it pleases me.
My wife asked me last night why I didn’t just modify the last platform instead of the new build, and I told her well then I wouldn’t have been able to fit the other 3 drivers of course, lol. She just shook her head.
Stuck for an hour getting my tires rotated and car maintenance done, and all I can think of is finishing up the BOSS BOSS BOSS...
SBuger, lmidgitd and Nalleh like this.
post #83 of 119 Old 05-22-2019, 10:30 AM
trhought's Avatar
Quoted: 518 Post(s)
Liked: 932
Looks awesome Sekosche! Can't wait to hear your impressions of BOSS 2.0!
You're in for a treat with Godzilla (1998) with the BOSS and BEQ. We watched it a couple nights ago with that combo....nice use of layered ULF throughout the entire movie. So much better than 20 years ago when my wife and I first watched it on DVD back in the day after first finishing our theater! What a difference 20 years of technology advances has made in our hobby!
The movie is better than I remembered also....lots of campy humor that seemed just right for the story line. Makes me want to revisit some of those 90's action films all over again....Face/Off, Con Air, The Rock, The Heat, T2, Broken Arrow, Mission Impossible I, Bad Boys I....
But, the bass in Godzilla, OMG....you're in for a treat.
Hellboy 2 is a great suggestion....haven't tried that with BOSS/BEQ yet. I remember it being a bass-feast even without those tools when we first watched it. Should be a nice surprise this time around!
Sounds like you have a great afternoon and evening coming up......Enjoy!
trhought is offline
post #84 of 119 Old 05-22-2019, 11:37 AM - Thread Starter
Sekosche's Avatar
Liked: 3333
Hardest part of disassembling BOSS 1.0 is removing the Hudson isos! These little suckers are on there good. Going to use rubber cement to reapply them, but no worries about these accidentally coming off should you move your furniture around a lot.
They all came off in one piece. You can tell where the pressure points are as the front half were a bit more adhered to the plywood than the rear, which makes sense for mine.
post #85 of 119 Old 05-22-2019, 12:14 PM - Thread Starter
Sekosche's Avatar
Liked: 3333
About as flush as you can get!
post #86 of 119 Old 05-22-2019, 01:27 PM
Liked: 1610
WooHoo @Sekosche. Shake Rattle, and Roll!
post #87 of 119 Old 05-22-2019, 01:48 PM - Thread Starter
Sekosche's Avatar
Liked: 3333
Almost there! Going to drop the drivers in after bringing the platform inside, learned that with BOSS 1.0, because it was a little awkward and off balance to move on a furniture dolly.
Don’t think I’ll even get them wired up until later tonight after the kid’s sports or first thing tomorrow morning. After sitting on the “normal couch”, I actually like the height the BOSS adds on top of my mini riser for the MA’s because we’re a tall bunch of people.
Soon my pretties!
SBuger, Nalleh and bubbrik like this.
post #88 of 119 Old 05-22-2019, 01:52 PM
Nalleh's Avatar
Liked: 3039
Looks great Will be fun to hear your impressions
Nalleh’s HT
post #89 of 119 Old 05-22-2019, 03:23 PM
trhought's Avatar
Quoted: 518 Post(s)
Liked: 932
Getting closer! Bet you're excited Sekosche. I hear you about the kids sports....getting ready to go watch my daughter, who will be a freshman in HS next year, try out for the high school softball team. Directly after that is my son's varsity spring football game...busy night!
One question....what are those 2 isolators in the middle of your platform above. They look different which is why I'm asking. I've found mixing isolators (different impedances under the BOSS platform) has adverse effects on the BOSS performance. The platform response will be largely effected by the highest impedance isolator underneath. If those isolators are harder than the Hudson's they might be taking away some TR from the BOSS.
Just wanted to mention that if those are indeed isolators and part of the platform design.
trhought is offline
post #90 of 119 Old 05-22-2019, 04:20 PM - Thread Starter
Sekosche's Avatar
Liked: 3333
Luckily, I’ve only got one in multiple sports now and thank goodness soccer is over; the other one just started walking.
The two isos in the middle are a pair of first gen Crowsons I had extra, they’re a tad shorter than Hudsons but are very squishy. The ones in the middle don’t get much pressure, so they’re more for piece of mind, but they do bear a little weight. I ran out of isos after ordering I forget how many, I think 22 total for both platforms of the 2.5” and I bought some of the tiny 0.5” ones for around the house. If the slightly heavier BOSS 2.0 feels less jiggly, I might order another 4 pack, but I doubt it’ll be necessary with 14 on the bottom and 8 on the top layer.
trhought likes this.
