DIY Subwoofer Dilemma - AVS Forum | Home Theater Discussions And Reviews
 16Likes
  • 1 Post By Red Five
  • 1 Post By LastButNotLeast
  • 1 Post By JediMindTrick
  • 1 Post By rontalley
  • 1 Post By BassThatHz
  • 1 Post By blake18
  • 1 Post By blake18
  • 1 Post By SpinMonster
  • 5 Post By LastButNotLeast
  • 1 Post By smcmillan2
post #1 of 28 Old 04-26-2019, 01:27 AM - Thread Starter
Liked: 0
Hello all,
I am planning to build a Marty Cube Sub with 26.5", 24", 24"
1. Driver - Dayton Audio UM15-22 15 Ultimax
2. Amplifier - Behringer NU3000 iNuke
Currently I have a SVS PB 2000 hence I opted for a ported instead of a sealed one. But I have apprehensions regarding DIY as such and especially building a ported one. I think sealed one is easier to make.
I do not have any experience in building a subwoofer cabinet, but I will be taking local carpenter's help in cutting and building them.
Do you see a huge risk in making a DIY Sub. I don't not want to spend a lot and end up with a crappy Sub
If I compare with the price of PB 3000 in my place,
PB 3000 - 1600 USD
DIY Sub Woofer - 1200 USD. But with the amp I can go for one more similar sub for much lesser as amp can drive one more Sub.
Questions..
Is it okay to build a 24" 24", 24" Sealed instead of ported?
Or should I ditch the DIY idea altogether and spend the extra 400$ and go for PB 3000 instead of DIY?
Frankly I am very excited about the DIY route and want to go this route, so your advice is much appreciated.
BeeCR is offline
post #2 of 28 Old 04-26-2019, 05:54 AM
Red Five's Avatar
Quoted: 338 Post(s)
Liked: 383
Originally Posted by BeeCR View Post
Hello all,
PB 3000 - 1600 USD
Questions..
If you are not comfortable with your wood working skills and want to ensure a good end result have you considered purchasing a flatpack? www.gsgad.com has a nice selection to choose from
Just a recommendation, if you are going with a UM I would strongly suggest moving up in cabinet size or considering a different driver if it must be a cube. The UM15 is okay in a cube, but those drivers like bigger boxes.
BeeCR likes this.
Stormbreaker a B&C 21DS115 Subwoofer Solution | Wisconsin Home Theater Meet Thread
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | Yamaha A3070 | Crown XLS 1502 | iNuke 3000 DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Sub 21" Stormbreaker | Epson 5010e | 120" DIY AT Screen
Red Five is offline
post #3 of 28 Old 04-26-2019, 06:18 AM
LastButNotLeast's Avatar
Quoted: 2350 Post(s)
Liked: 1980
Get the DSP version of the amp (any amp):
https://www.parts-express.com/behrin...-dsp--248-7013
Have fun.
And welcome to AVS.
Michael
BeeCR likes this.
Did you really need to quote that entire post in your reply?
Welcome to AVS - Get out while you still can!
Don't guess, measure: https://www.avsforum.com/forum/91-au...l#post22789786
LastButNotLeast is offline
post #4 of 28 Old 04-26-2019, 06:43 AM
Quoted: 89 Post(s)
Liked: 54
Hello all,
PB 3000 - 1600 USD
Questions..
FWIW, I had an absolute blast building a mini-marty! Pretty much no wood-working experience (unless you count using a chop saw to make cuts in trim-work); did it mostly myself (some of the cuts were hard to do without someone holding the other side 'down.' I went to home-depot and had them rip cut each 4'x8' sheet of mdf so I could easily transport it; then used a circle saw + guide and a table saw to do the rest (and a jig-saw for driver hole).
Personally, I think they are pretty hard to 'screw' up (aside from the looks); I had a ton of 'f-it' moments with 'bad cuts' that I didn't feel like redoing and I definitely didn't put as much bracing as others, but it seems to have turned out great.
Just wondering, how did you come up with that price? $1200 for a marty cube seems high to me (unless you are using some really nice wood/the carpenter is making a really nice box)?
I think I spent a good bit less than that on my mini-marty + tools (jig-saw, table saw [used], clamps, etc).
IMO, if you want a sealed sub, I'd probably just buy a Parts-Express flat-pack combo.
GSG is a great option if the freight expenses aren't too high.
BeeCR likes this.
JediMindTrick is offline
post #5 of 28 Old 04-26-2019, 07:13 AM
rontalley's Avatar
Quoted: 775 Post(s)
Liked: 385
I was a union carpenter for 12 years and still went with the sealed flat pack and UM18-22 combo and a 6000DSP. OH MY GOD!!! So much damn bass!!! Used Bondo to fill gaps and make everything smooth. Turned out great!
ID:	2558408   Click image for larger version
BeeCR likes this.
My Media Room
AVR 1-Yamaha RX-A3050 (7.2.4), AVR 2 Pioneer VSX-815-K(Used for 4ch Amp TF+TR)
Mains-Polk Audio RTi8, Center-Polk Audio CSi5, Surrounds-Polk Audio RTi4, Ceilings-Micca M-8C, Sub 1- UM18-22 (4cu.ft DIY) - iNuke 6000DSP Sub 2-Klipsch RW12D,
Projector-Looking, Screen-Da-Lite 100" Model B, TV-Vizio P-65 4K
rontalley is offline
post #6 of 28 Old 04-26-2019, 11:52 AM - Thread Starter
Liked: 0
I need to import the driver and amp as I am not in the US. Cabinet is not much as I will be getting it made locally. And I do not intent to do the cabinet myself as I do not have much experience nor have the tools and space to make.
BeeCR is offline
post #7 of 28 Old 04-26-2019, 12:01 PM - Thread Starter
Liked: 0
Good to know that. The pics look good too. I was thinking about the 18 inch, but then I thought I will settle for the 15 inch for now. But since I have the SVS PB 2000, I am thinking of going the ported way.
BeeCR is offline
post #8 of 28 Old 04-26-2019, 12:06 PM - Thread Starter
Liked: 0
Red face
What size is the box? Is it looking a tad small for the 18inch driver?
BeeCR is offline
post #9 of 28 Old 04-26-2019, 12:14 PM
Liked: 1980
Knowing where you are may help with the recommendations.
Apparently, you're still able to deal with Parts Express?
Michael
post #10 of 28 Old 04-27-2019, 04:20 AM - Thread Starter
Liked: 0
Michael
I am in Muscat, Middle East. Parts express shipping is expensive. I get most of the stuff from Amazon.
BeeCR is offline
post #11 of 28 Old 04-27-2019, 06:14 AM
BassThatHz's Avatar
Quoted: 3657 Post(s)
Liked: 4142
Hello all,
The DSP version of the amplifier is REQUIRED, ported subs REQUIRE a HPF;
and pretty much ALL subwoofers need EQ, especially sealed...
Fear not, as you have it backwards: Why would you want to use a crappy sub like the SVS with the DIY in the room?
Now: Whether or not you can build the DIY box with quality, is another story! That's not a fault of the equipment...
If you can afford it, a UM-18 is MUCH better than the UM-15...
Generally I recommend 1 18 for every 1000cuft of room volume, as a minimum...
BeeCR likes this.
BassThatHz is offline
post #12 of 28 Old 04-27-2019, 06:58 AM - Thread Starter
Liked: 0
Yes, definitely, I will get the inuke3000 with the DSP.
I will definitely consider it, though UM 18 is expensive, it is not out of budget for me. If that is the case I will have to go for the inuke 6000 amp at least I guess.
I have invested in that(PB 2000) and I love it. Also not so easy to sell it either. So I was wondering using it together with the DIY.
Do you think forget about PB2000 and go for a Sealed cube with UM18 is a good idea?
BeeCR is offline
post #13 of 28 Old 04-27-2019, 07:09 AM
blake18's Avatar
Quoted: 627 Post(s)
Liked: 351
The best bang for your buck would be to go with GSG Audio, a Mini Marty or Full Marty, with the UM-18 and a used iNuke 3000DSP.
BeeCR likes this.
Lumenlab "Community driven video lab".
blake18 is online now
post #14 of 28 Old 04-27-2019, 08:00 AM - Thread Starter
Liked: 0
Will iNuke 3000 DSP be enough for UM-18?
Won’t it need iNuke 6000?
BeeCR is offline
post #15 of 28 Old 04-27-2019, 10:46 AM
rontalley's Avatar
Quoted: 775 Post(s)
Liked: 385
It’s 4 cubic feet designed specifically for the UM18-22. Tons of bass for my room.
Specifications:• Panel thickness: 3/4", front baffle is 1-1/2" • Panel material: Medium Density Fiberboard (MDF) • Finished net cabinet volume (subtracting the double thick baffle, bracing, and woofer volume): 4.0 cubic feet • External dimensions: 23" H x 20" W x 20.75" D • Subwoofer recess: 1/2" • Weight: 62 lbs. • Made in the U.S.A.
https://www.parts-express.com/dayton-audio-18-ultimax-subwoofer-and-cabinet-bundle--300-7099
BeeCR likes this.
post #16 of 28 Old 04-27-2019, 03:00 PM
blake18's Avatar
Quoted: 627 Post(s)
Liked: 351
Oh yes, if you run it in bridged mode 2ohm load, it should be plenty.
BeeCR likes this.
post #17 of 28 Old 04-27-2019, 03:12 PM
Liked: 1980
What part of shipping to Muscat, Middle East are you guys missing?
Build a sealed box with the wood and biggest driver you can find and you'll be fine. You can't mess up a sealed sub; it's much easier to DIY ported and get it wrong.
The two subs will be fine together.
Michael
post #18 of 28 Old 04-27-2019, 03:54 PM
SpinMonster's Avatar
Quoted: 486 Post(s)
Liked: 295
Thinking of upgrades afterward, the UM18 in a sealed box can be upgraded to any size ported later on. Changing drivers is a bigger deal.
BeeCR likes this.
SpinMonster is online now
post #19 of 28 Old 04-27-2019, 08:45 PM - Thread Starter
Liked: 0
Michael
Subwoofer Driver and the amplifier are 2 items I have to import. Yes, the cabinet will be made locally.
BeeCR is offline
post #20 of 28 Old 04-28-2019, 04:34 AM
Liked: 1980
Around here (AVS) we don't change drivers, we ADD drivers.
18Hurts, BeeCR, dTorC4 and 2 others like this.
post #21 of 28 Old 05-02-2019, 08:41 AM - Thread Starter
Liked: 0
Red face
I have placed the order for UM-18
It cost me equivalent of 527 $
It takes around a couple of weeks for it to reach my place. I have started the research for finding the best way to get the amplifier now.
BeeCR is offline
post #22 of 28 Old 05-02-2019, 10:06 AM
johnson636's Avatar
Quoted: 1134 Post(s)
Liked: 654
For one UM18
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #23 of 28 Old 05-02-2019, 10:46 AM - Thread Starter
Liked: 0
Yup.. Sad but true. Here we pay a premium for all these especially the heavy stuff, shipping is very high.
BeeCR is offline
post #24 of 28 Old 05-18-2019, 07:28 AM - Thread Starter
Liked: 0
If I buy miniDSP 2x4 HD, I can use a non-DSP Biehringer or Crown .. right? Any pros and cons for going with a miniDSP 2x4 HD instead of DSP ?
BeeCR is offline
post #25 of 28 Old 05-18-2019, 07:40 AM
smcmillan2's Avatar
Quoted: 778 Post(s)
Liked: 683
In my mind:
Pros: REW adjustments plug directly into the miniDSP, the HPF can be set lower (without a workaround), can use pretty much any pro amp.
Cons: Another piece of equipment in the signal chain. Possibly more $$. More wires.
Having a miniDSP gives you more flexibility, introduces a bit more complexity.
BeeCR likes this.
smcmillan2 is offline
post #26 of 28 Old 05-18-2019, 09:08 AM - Thread Starter
Liked: 0
Originally Posted by smcmillan2 View Post
In my mind:
I was thinking with a miniDSP, I can also calibrate my existing Sub ( PB 2000) along with the new MartyCube that I am planning to make. So I can go an non-DSP amplifier for my Marty Cube
BeeCR is offline
post #27 of 28 Old 05-18-2019, 09:41 AM
BassThatHz's Avatar
Liked: 4142
The mniDSP can DSP down to 10hz if I recall. The iNuke stops at 20hz and so you have to fart around to make it extend lower.
Not sure if the miniDSP has a limiter, but that is something you'd have to level match yourself to the external device. Output voltage from the amplifier calculated as per ohm's law.
The inuke 6k would allow for 2 UM-18's to be powered in the future, where as a 3k might struggle.
The old school Class-H amplifiers are very inefficient, often 40-60% at-best, and are about 8 times heavier, the EP4k for example.
Class-D only produces the amount of power needed as it is needed, therefore it is higher efficiency and cooler running, and can make use of smaller heatsinks because they don't generate 50% waste-heat.
The inuke's are Class-D and the Crown 6k and iTech is Class-D, the cheaper Crown's are Class-AB/D hybrids (last I checked, which was 10 years ago... LOL)
PowerSoft K/X and SpeakerPower are also Class-D.
It makes no sense to have 10kW of waste-heat to make 10kW of bass, that would require a 240V 100A breaker just for 1 amp LOL. That's why you don't see old school amps rated for much more than 2-4kW.
MOST music and movies are very bursty/dynamic in nature, making 10-20kW from a bank of caps short-term isn't too big a deal, hence why the K20 is possible.
Pro amps are designed mostly for live music where power is only required in bursts (guitars, drums, vocals.)
Generally the RMS power is roughly half the peak power, many of the higher powered designs have auto limiters to avoid popping breakers or exceeding the thermal/ampere limits of the guts as the fans hit max RPM.
Many rock concerts also play the numbers game, if you throw enough cones and amps at the problem, the SPL at Distance X will be solved. So you'll see 30-100 18's and 30-100 amplifiers, powered with multiple diesel 18wheelers.
Ported is louder than sealed roughly from tuning until about ~40hz.
If this is for movies, 15-17hz is a good tuning point, and 25hz if it is just music.
Ported boxes requiring a HPF at the tuning frequency.
Most sealed boxes start rolling off around 30hz, but the rolloff is less severe than ported, and stays in-phase for the most part, unlike ported.
This always you to boost the ULF flat to 3-5hz. With 4 to 8 18's those frequencies will start to become usable.
Sealed eats up more power and thus is likely to cause melting and bottoming sooner than ported would. No free lunch.
When it comes to making bass, you basically want the biggest cones you can afford, that have the highest power-handling and excursion, and as many of them as you can afford.
db/w/m is important above 40hz, excursion is important below 40hz.
It takes about ~32 watts to push 32 18's to 1mm, but it takes ~3200watts to push 1 18 to 32mm, and both are the same SPL.
and then what happens when the array goes to 3mm's? (or 20mm's?) EXACTLY!
The single melting and farting in seconds/minutes, and the array is bass-for-days with zero distortion the whole time!
Thus: if/when you want it louder, just add more. 6db per doubling.
Doubling the distance is -6db in free-space, in a room it is slightly improved (when not placed in a room-null.)
Groundplane is half-space, a wall is 1/4th space, and a corner is 1/8th space. (Corners are loudest.)
The difference being room-gain, which starts when the wave bounces off 1-or-more of the 6 surfaces and/or when the wave no longer fits in the room.
Sometimes moving closer to a subwoofer makes it sound weaker because of a lack of these additional reflections and/or being in a null zone; or conversely moving away makes it louder for the same.
Nearfield is when your ear is closer to the cone than the closest surface(the floor), then your SPL will be at maximum (minus room-gain though).
Therefore the loudest/smoothest place for a subwoofer is often at head-level directly behind the golden-seat firing into the back of your skull point-blank range and delayed several ms to match the LCR's. Too bad it is not very practical and low WAF!
BeeCR likes this.
post #28 of 28 Old 05-20-2019, 12:15 AM - Thread Starter
Liked: 0
PowerSoft K/X and SpeakerPower are also Class-D......p
This is lot of information. Thanks a lot
BeeCR is offline
diy subwoofer , martycube
