AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   DIY Speakers and Subs (https://www.avsforum.com/forum/155-diy-speakers-subs/)
-   -   1099 build (https://www.avsforum.com/forum/155-diy-speakers-subs/3064660-1099-build.html)
thisismyname123 04-28-2019 04:32 AM
1099 build
Are there documented instructions on building and assembling any diy speakers?
It all seems kinda self explanatory but I've never built a speaker....never really looked inside a speaker ...or done much wood working ever.... especially finish work.
A simple step sheet showing best practices of where to drill holes...where to mount xover...what type of absorption material works best and where to put it....type of wire to use and wire goes where.. after glueing the packs together what's the best next step.....well you get the point
I'm sure I'll figure this all out but would be nice to have a guide
Sent from my Pixel using Tapatalk
thisismyname123 04-28-2019 11:38 AM
smcmillan2 04-28-2019 11:47 AM
Gotta love the flatpacks!
Many of the questions in your original post are already covered on the DIYSG site, under "Helpful Notes"
https://www.diysoundgroup.com/home-t...sive-1099.html
brian6751 04-28-2019 12:19 PM
Keep the denim away from the port areas
Carry on
thisismyname123 04-28-2019 12:23 PM
Carry on
I trimmed the sides so it didn't interfere. Then on the bottom I thinned it out so the ports would rest against it but not block them.
thisismyname123 04-28-2019 02:56 PM
One finished with denim.
Question...is it ok to have the denim interfering with the mid-range? It will be kinda smashed up against it...see photo....unless I trim it.
https://uploads.tapatalk-cdn.com/201...a7d8656797.jpghttps://uploads.tapatalk-cdn.com/201...8bfcff0f4a.jpghttps://uploads.tapatalk-cdn.com/201...6f3e4140ba.jpg
mtg90 04-28-2019 03:15 PM
As long as it is not pushing into the frame and touching the back side of the midrange cones it should be ok.
thisismyname123 04-28-2019 03:38 PM
Ok thanks.....another question...Ive been trying to use 12 awg speaker wire that I had to wire up the xovers. Not working too well.
What awg is recommended for internal wiring? 14? 16?
smcmillan2 04-28-2019 04:25 PM
I've used 14Ga in all my DIYSG builds without issue.
The only time I use 12Ga is when I'm running wires to subs.
brian6751 04-28-2019 05:09 PM
14 or 16 is fine
thisismyname123 04-30-2019 06:43 AM
Craig S King 04-30-2019 07:15 PM
Nice progress so far. I'm envious.
brian6751 04-30-2019 07:40 PM
1099 build
Keep it up. They are worth the effort
kagtha 05-01-2019 02:10 AM
Hmmm, and in 1 day you are testing finished crossovers and finalizing the boxes!?
It doesn't look like you need too much help to me!
Don't forget to enjoy the process and have your wife take a photo of you working on them so you can prove you are now a certified closet high-end speaker builder.
Sent from my Pixel 3 using Tapatalk
thisismyname123 05-01-2019 02:41 AM
Ha...well that was day 2 buy who's counting.
It would still be nice to have a complete set of guidelines I think. Had to do a lot of online searching and several trips to the store for stuff I didn't think I needed
BCRSS 05-01-2019 05:44 AM
Good job so far.
I will leave some constructive criticism. Your lining is good but you will need to mount the cross over board yet. I had mounted mine in the center chamber. Once mounted you will need to drill holes to get the woofer wires to the other chambers. I had used a good glue to seal these holes once wire had been passed through. The last thing I noticed was on your cross over board, the stand offs that Erich supplies are in wrong. Pull them out and turn around, so the longer leg is on the bottom.
You have done a great job so far but just wanted to point out some things that I thought might help you. You will love these once you have listened to them over an extended period.
brian6751 05-01-2019 07:03 AM
Originally Posted by BCRSS (Post 57981402)
Good job so far.
Good catches. Youll still be able to rout the wires but it will just be a bit more of a pain/mess. make sure you take the red and black wires out of that jacket before you rout them through the box walls. The jacket acts as a straw and wont let you get a good seal. That middle section needs to be air tight everywhere. silicone the crap out of the entry/exit holes for the wires.
I used poly fluff in the middle section. I buy the cheap pillows at Walmart for it. they are less than $3 each. stuff it full but not to where the drivers/horn are compressing it when installed.
Another thing I like to do.... just on the baffle. Sometimes everything is not perfectly flush as far as the surfaces on the front where the baffle will be glued to. Even if i use wood glue for everything else, I like to use Loctite PL Premium to glue the baffle on so it fills in any little gaps. It expands and it is super strong. It also does not come off anything including your cloths and skin so where old cloths and rubber gloves when using it!! :D it comes in squeeze tubes and caulk gun tubes
Also, do not wipe the PL Premium off! let it squeeze out and then after it dries, just scrape it right off with a putty knife.
thisismyname123 05-01-2019 09:43 AM
Good job so far.
Thanks for the feedback. I already drilled the holes between the 2 chambers and cut away the denim in the areas to clear the space. I noticed everything will be a tight fit down in there....I need smaller hands!
Will flip around those white stand offs...thanks.....see that's why there should be a manual!
thisismyname123 05-01-2019 09:46 AM
Thanks, will take of the white wire jacket.
I bought a bag of poly fill...that can just go on top of the crossover? what about underneath the crossover, should there be any or just put that mounted on the bare mdf?
brian6751 05-01-2019 09:48 AM
yep. It can go right on top of the crossover. dont put anything underneath the crossover.
thisismyname123 05-01-2019 01:39 PM
What are you guys using for spade connectors to the drivers?
I bought these and they are too loose...
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
smcmillan2 05-01-2019 06:16 PM
I use the same. Just pinch them a bit with pliers. Then struggle to get them attached... But they work.
thisismyname123 05-01-2019 06:29 PM
Hmm. I had a few I got from home Depot and they were a lot tighter. I'll play around with them
lawdogx 05-02-2019 12:16 PM
I found the .25" female disconnects like those to be way too loose. I used the .205 gold disconnects from parts express and found them to be a much better fit. They're a bit snug, but I used a small screwdriver to very slightly open the very ends to "get them started" and they worked (and continue to work) great. Also, don't forget a terminal crimper tool to "cold weld" the wires to the disconnect. Insulated disconnects like the ones you linked to use insulated crimpers like this https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1. Non-insulated like the parts express gold connectors use non insulated crimpers.
You're build is looking great, keep up the good work!
liffie420 05-02-2019 12:23 PM
Good job I'm jealous. I wanted to build a set for my living room, but have neither the room nor the tools to do so. Its an old house with no garage. That an they were a bit to wide to fit in my space. But looking back I DID manage to squeeze 2 JBL Studio 590's for the L and R and those are NOT small speakers. LOL
Edited to add you should have done a search around here there are a TON of build threads for those that have a ton of advice. Did I spy some ultimax 15" woofers as well? Looks like you getting read to build a couple subs too, you picked the "hard" build first LOL
thisismyname123 05-02-2019 02:39 PM
Thanks...I have that crimper tool. Works awesome on these. Been squeezing these .25 together a bit and they are working much better now.
thisismyname123 05-02-2019 02:40 PM
Those are ultimax 18s. Not sure what I'm gonna do with them yet.....or where they can go either!
thisismyname123 05-02-2019 02:43 PM
Baffle glued on 1 with crossover wired and attached.....other 2 are finished with the denim.
Got in a bunch of wilsonart free samples. Need to pick one out now.
Probably will paint black the front, back and bottom...then use one of these laminates for the top and sides.
Need to build some grilles so the kids aren't enticed by these next.https://uploads.tapatalk-cdn.com/201...bf13828702.jpghttps://uploads.tapatalk-cdn.com/201...6a5d576cd2.jpghttps://uploads.tapatalk-cdn.com/201...48e84c4bfb.jpghttps://uploads.tapatalk-cdn.com/201...3fd55c0acd.jpghttps://uploads.tapatalk-cdn.com/201...39acd0a086.jpg
OJ Bartley 05-03-2019 08:49 AM
I like both of the darker options on the bottom row. Depending which one will go better with the rest of your room.
smcmillan2 05-03-2019 12:50 PM
Is that sapele on the bottom right? That could end up looking pretty cool.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
