Where do you find foam port plugs? - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 4 Post By Stephen Hopkins
post #1 of 14 Old 04-28-2019, 11:15 AM - Thread Starter
blake18's Avatar
Quoted: 701 Post(s)
Liked: 408
I'm looking for port plugs for my Marty Cubes and my eD a5-350s. Would need a couple for some 4" diameter round ports and slot ported shaped plugs. Anyone know how to either make some, or buy some premade? What's the best material to use, that's not too expensive?
Lumenlab "Community driven video lab".
blake18 is offline
post #2 of 14 Old 04-28-2019, 01:49 PM
Gorilla Killa's Avatar
Quoted: 1611 Post(s)
Liked: 2407
Gorilla Killa is online now
post #3 of 14 Old 04-28-2019, 11:43 PM
Stephen Hopkins's Avatar
Quoted: 456 Post(s)
Liked: 216
For the round ports, Head to Target or Walmart and find a Nerf ball with a 5-6" diameter...
buggers, jujuman200, Leon! and 1 others like this.
BenQ TK800 | Silver Ticket 106" 16:9 1.0 Grey | Marantz SR6011 | B&W P6 | B&W CDMC SE | Sonance .5 THX SUR | MCM In-Ceiling Atmos | Ascendant Avalanche 12" in 6 ft^3 @ 18Hz w/ BASH 500w Plate Amp | Sony X800 | NVidia Shield TV Pro | XBox One 500gb | Nintendo Switch | Harmony Smart Control | SmartThings Hub | Google Home | AT&T Fiber 300 | YouTube TV | Netflix | HBO Now | Spotify
Stephen Hopkins is offline
post #4 of 14 Old 05-02-2019, 09:18 AM
deauxt's Avatar
Quoted: 38 Post(s)
Liked: 30
Originally Posted by Gorilla Killa View Post
Thanks for the link!
deauxt is offline
post #5 of 14 Old 05-02-2019, 10:10 AM
Leon!'s Avatar
Quoted: 297 Post(s)
Liked: 151
So one can simply plug any subs port to try it sealed, safely? Keep the HPF at the original tuning frequency?
I see an 8.5" ball... maybe need it more "stuffed", an even bigger one for an 8" port. 10"?
Leon! is offline
post #6 of 14 Old 05-02-2019, 10:17 AM
Leon!'s Avatar
Quoted: 297 Post(s)
Liked: 151
Pretty good! Forgot about the foam factory & foam by mail from DIY mattress days. Unfortunately shipping cost as much as the 10" cylinder (unless I went for 6 of them)!
Edit- hey I have leftover polyurethane eggcrate mattress topper for lining... can I roll some of that up tight and stuff it?
Leon! is offline
post #7 of 14 Old 05-02-2019, 10:51 AM
buggers's Avatar
Quoted: 55 Post(s)
Liked: 36
You can use whatever you like...the point is to stop the air flow.
buggers is offline
post #8 of 14 Old 05-05-2019, 06:25 AM - Thread Starter
blake18's Avatar
Quoted: 701 Post(s)
Liked: 408
Anyone have suggestions for slot port plugs?
blake18 is offline
post #9 of 14 Old 05-05-2019, 07:15 AM
Vergiliusm's Avatar
Quoted: 322 Post(s)
Liked: 600
I bought some open cell poly foam from Home Depot a couple inches larger than the height of the slot. I cut it a couple inches wider and about 6" deep, so I could squish it down and really stuff it in. It worked great.
"Rock and roll is alive and alright" Sloan
Vergiliusm is offline
post #10 of 14 Old 05-22-2020, 07:03 PM
Dunk_c's Avatar
Liked: 0
Here you go
Sponge
Round
Cut to length
Virtually no cost.
Dunk_c is offline
post #11 of 14 Old 05-22-2020, 09:12 PM
JMAX2016's Avatar
Quoted: 101 Post(s)
Like V said, I would use mattress foam topper for slotted.
Yamaha Aventage 3060, 7.2.4
Goldenear Triton 1's, Supercenter XXL, 4-MPX, 4-652
4-18" Ultimax's - 16 cu ft ported
JVC RS500 Pro, Panasonic DP-UB820 UHD Blu-Ray Player
137" wide 16:9 V6 AT Screen
JMAX2016 is offline
post #12 of 14 Old 05-28-2020, 04:30 AM
buggers's Avatar
Quoted: 55 Post(s)
Liked: 36
Closed cell foam would give better results but YMMV.
buggers is offline
post #13 of 14 Old 05-28-2020, 09:36 AM
lyle2321's Avatar
Liked: 0
Foam topper is a good idea - would be nice if there was something smaller and less expensive ---
Any more ideas?
lyle2321 is offline
post #14 of 14 Old 05-28-2020, 12:47 PM
a77cj7's Avatar
Quoted: 970 Post(s)
Liked: 1040
Here’s how I build mine.
https://www.avsforum.com/forum/155-d...l#post59130012
Might be more elaborate than you want. The foam alone will work great and isn’t overly expensive from amazon.
Chris
a77cj7 is online now
