How would these settings affect my HPF? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 05-01-2019, 08:44 AM - Thread Starter
Leon!'s Avatar
Quoted: 283 Post(s)
Liked: 138
Subsonic Filter
Selects a subsonic filter with -3dB @ 18Hz, Q=.8.
Bass Boost
Selects a bass boost filter with +3dB @ 25Hz, Q=1.4.
EQ
The freq. knob selects the frequency for the filter,
the bandwidth knob selects how wide or narrow the filter is
(the higher the bandwidth, the broader the effect), and the
level knob can be used to add up to 6dB of boost or 14 dB
of cut.
If I had the above subsonic filter set at 18Hz, but then also EQ boosted at the lowest setting (same, 18Hz), to the max +6b & widest Q=1 bandwidth, what will the effective cutoff be then? I'm particularly interested in knowing if possible how far down that would put me at 16hz.
Leon! is offline
post #2 of 17 Old 05-01-2019, 09:07 AM
johnson636's Avatar
Quoted: 1146 Post(s)
Liked: 671
What equipment is being used to apply these settings? Are you unable to apply the settings as a test and measure the response?
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #3 of 17 Old 05-01-2019, 10:11 AM
Funkeye's Avatar
Quoted: 180 Post(s)
Liked: 99
So I modeled a ported UM18 and applied the filtering (Red). I'm getting an F3 of about 12.8Hz. Green is without filters.
Funkeye is offline
post #4 of 17 Old 05-01-2019, 10:26 AM - Thread Starter
Leon!'s Avatar
Quoted: 283 Post(s)
Liked: 138
Sorry I should have clarified- these are settings on a subwoofer amplifier I'm thinking about buying. Only problem is its subsonic filter is a little higher than I'd prefer.
Just curious if boosting at the hpf frequency and the bass boosted well compensate at all, or will it completely neuter the sub in the teens
Leon! is offline
post #5 of 17 Old 05-01-2019, 10:28 AM - Thread Starter
Leon!'s Avatar
Quoted: 283 Post(s)
Liked: 138
Very cool, thank you! That looks perfect
Edit - in fact from the looks of that graph it might be overcompensating, for 1200w on a 16hz tuned sub could be trouble in low teens. Might dial the boostand q down a little.
Leon! is offline
post #6 of 17 Old 05-01-2019, 10:41 AM
notnyt's Avatar
Quoted: 3731 Post(s)
Liked: 3702
You should check your excursion and port velocity
notnyt is offline
post #7 of 17 Old 05-01-2019, 11:05 AM
Funkeye's Avatar
Quoted: 180 Post(s)
Liked: 99
Excursion was good until 300W and port velocity can be tamed with huge ports (4 x 4" x 26"). The box would be huge as well. I only did the model to see how the filter settings affected response without emphasis on the system. Of course the driver specifics were not mentioned in the OP.
Funkeye is offline
post #8 of 17 Old 05-01-2019, 11:20 AM - Thread Starter
Leon!'s Avatar
Quoted: 283 Post(s)
Liked: 138
Excursion was good until 300W and port velocity can be tamed with huge ports (4 x 4" x 26"). The box would be huge as well. I only did the model to see how the filter settings affected response without emphasis on the system. Of course the driver specifics were mentioned in the OP.
Box is already built, 14cf net with 8"dia. X 35 1/2" port. Just using a PE spa250dsp, which I assume is < 250watts, it's already as much output as I desire, and doesn't start making undesirable noises until I hit right at 8hz, which happens in quite a few movies.
So I have to get a HPF, Just if I'm having to buy a stand alone eq or DSP, I'd just assume get a more powerful amp with it onboard. Especially want to play it safe with 1000 more watts, mid teens would be great.
Leon! is offline
post #9 of 17 Old 05-01-2019, 11:22 AM
Funkeye's Avatar
Quoted: 180 Post(s)
Liked: 99
What driver?
Funkeye is offline
post #10 of 17 Old 05-01-2019, 11:26 AM - Thread Starter
Leon!'s Avatar
Quoted: 283 Post(s)
Liked: 138
What driver?
Ultimax 18"
Leon! is offline
post #11 of 17 Old 05-01-2019, 11:52 AM
Funkeye's Avatar
Quoted: 180 Post(s)
Liked: 99
Ultimax 18"
Lucky guess!
Box is already built, 14cf net with 8"dia. X 35 1/2" port..... want to play it safe with 1000 more watts, mid teens would be great.
High pass = 18 Hz, 0.8Q
EQ = @18Hz, Q=1, Gain=1
Power = 1000W
Port velocity = 18.7 m/s
Excursion = 22.4mm
F3 = 16.1 Hz
Anything I'm missing?
ID:	2561098   Click image for larger version
ID:	2561100   Click image for larger version
Name:	Air speed.jpg
Funkeye is offline
post #12 of 17 Old 05-01-2019, 01:05 PM - Thread Starter
Leon!'s Avatar
Quoted: 283 Post(s)
Liked: 138
Ultimax 18"
Lucky guess!
Power = 1000W
Excursion = 22.4mm
F3 = 16.1 Hz
Haha yeah I was wondering how you already knew.
Edit- no you're not missing anything, it is a 1000 w amp, thank you!
All of that looks good though, excursion and velocity?
Leon! is offline
post #13 of 17 Old 05-01-2019, 01:19 PM - Thread Starter
Leon!'s Avatar
Quoted: 283 Post(s)
Liked: 138
So that's with the level knob turned to 1 right?
That graph looks so awesome, and safe. Thanks so much for taking the time to do that for me.
Leon! is offline
post #14 of 17 Old 05-01-2019, 08:03 PM - Thread Starter
Leon!'s Avatar
Quoted: 283 Post(s)
Liked: 138
Ordered the amp! Thanks all, now feel confident I can still push high output into the teens without damaging my driver thanks to Funkeye's work.
Super excited, greatly appreciated.
Leon! is offline
post #15 of 17 Old 05-06-2019, 01:26 PM - Thread Starter
Leon!'s Avatar
Quoted: 283 Post(s)
Liked: 138
Lucky guess!
Power = 1000W
Excursion = 22.4mm
F3 = 16.1 Hz
I stuffed a removable chimney in the end of my port, to temporarily experiment with 16hz vs. 14hz tune... think I'm safe with the amp settings you provided that resulted in an f3 of 12.8Hz, using that 14Hz extension, or still should keep the gain lower? It looks like the only thing that changed between each combination of settings you calculated, is with the EQ, from "Gain = 6" (12.3Hz) to "Gain = 1" (16.1Hz).
So far with only 250w I think I prefer the 16hz tune, but the 1,000w amp arrives wednesday.
(I shoved this tube extension with the foam in the end of my port):
Leon! is offline
post #16 of 17 Old 05-06-2019, 08:40 PM
Funkeye's Avatar
Quoted: 180 Post(s)
Liked: 99
The "Gain=6" model was not with your box. It was auto-generated from WinISD, and very large in size, much larger than yours. Ignore this one.
The "Gain=1" model was based on your box, port dimensions, and power requirements you specified.
Funkeye is offline
post #17 of 17 Old 05-08-2019, 02:46 PM - Thread Starter
Leon!'s Avatar
Quoted: 283 Post(s)
Liked: 138
IDK how much outut I'm losing in the low teens, going from 16hz tune with a 250w amp with no HPF, to a 14hz tune with 1,000w amp but also 18hz HPF (+ the Gain 6/Q1.0 EQ boost also at 18hz), but the latter still seems much more impactful down low. ALso it no longer makes any unwanted output in certain super low bass heavy scenes that I'd known to happen without a HPF, even with only 250w.
Anyway feel like its perfect now, does not seem like I'm leaving too much on the table down low with the HPF.
Very impressed with this amp.
Leon! is offline
