Is AVR noise floor an issue with high sensitivity speakers? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By notnyt
  • 1 Post By BassThatHz
  • 1 Post By Squirrel!
post #1 of 13 Old 05-06-2019, 02:43 PM - Thread Starter
CrusherW9's Avatar
Quoted: 216 Post(s)
Liked: 132
I'm looking into buying an AVR and I was wondering if I need to be concerned with the noise floor on the amplified and line level AVR outs for high sensitivity speakers like those of DIYSG's offerings? I've read that the MiniDSP can be an issue with high efficiency speakers so I wasn't sure if I have to worry about that with AVRs?
"Becoming educated is more than just acquiring knowledge. It involves the ability to see the world in ways never before conceived."
CrusherW9 is offline
post #2 of 13 Old 05-06-2019, 02:46 PM
notnyt's Avatar
Quoted: 3892 Post(s)
Liked: 3842
Nope, most AVRs are nice and quiet. Really will depend on the AVR, though.
CrusherW9 likes this.
notnyt is offline
post #3 of 13 Old 05-06-2019, 02:52 PM - Thread Starter
CrusherW9's Avatar
Quoted: 216 Post(s)
Liked: 132
When you say "most", are there any in particular to avoid or is it mainly just lower end stuff?
post #4 of 13 Old 05-06-2019, 03:03 PM
notnyt's Avatar
Liked: 3842
Haven't really run into any that were that noisy. I say most because I'm sure there have to be some cheaper / low end ones that are just junk.
notnyt is offline
post #5 of 13 Old 05-06-2019, 03:46 PM
asarose247's Avatar
Quoted: 1308 Post(s)
Liked: 1151
it depends. .
you will probably have more "floor" noise issues with the "household environment" /neighborhood / etc.
my LR is 'typical" at about 40-42 db, depending on time of day and traffic around me
but in my mancave, at the right times, it can be as low as 37
and that's with the HTPC running.
that's quiet
FTR it's a nvidia 1030 fanless 4K card
the Denon X5200 at now about 5 y.o. , nary a peep from it . .
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is online now
post #6 of 13 Old 05-06-2019, 03:58 PM - Thread Starter
CrusherW9's Avatar
Quoted: 216 Post(s)
Liked: 132
Thanks for the info, guys!
post #7 of 13 Old 05-06-2019, 04:20 PM
PrimeTime's Avatar
Quoted: 824 Post(s)
Liked: 518
An AVR will usually be quieter than any setup that runs DSP before the power amplifier, as with separates. The reason is simple: with all of the gain blocks (DSP and power amplifiers) contained within the AVR, the manufacturer can integrate (window) the voltage gains of each block in an optimal alignment that avoids excessive gain. Furthermore, with lower power output the absolute gain of the power stage in an AVR is usually less than an outboard power amplifier. As a general design proposition with amplifiers, less gain equals more feedback equals less noise (and distortion).
Furthermore, when DSP is involved, the dynamic range is reduced in better power amplifier stage designs. Linear amplifiers typically will have a higher signal-to-noise ratio than a DSP stage, although the gap has been closing. Eliminating any DSP from the signal chain will often result in lower noise, although AVRs have a good handle on the DSP integration. The difference may be difficult to discern with lower-sensitivity consumer loudspeakers.
Excessive gain with separates is when you have various outboard units that plug into your power amplifier, and you have to reduce the power amp's Volume or Gain control to attenuate its input signal -- which usually doesn't happen inside an AVR. This just pushes the input signal down closer to the noise floor of the system, reducing dynamic range.
My loudspeakers are over 100 dB/w/m, and with my Yamaha AVR I can't hear any hiss even with ears pressed against the grille. However, when using active electronic crossovers and HF compression drivers with sensitivities around 110 dB/w/m, noise that would otherwise be difficult to hear becomes audible. Of course, in a pro system, the listeners are rarely within eight feet of the speakers -- an important distinction.
PrimeTime is offline
post #8 of 13 Old 05-06-2019, 05:34 PM
BassThatHz's Avatar
Quoted: 3968 Post(s)
Liked: 4486
The hiss in my system is almost non-existent. The biggest and only culprit is the FP's...
My 7705 and Motu's have vanishingly low noise. Neither are a AVR though...
If you have lots of components one thing that can help is using optical HDMI cables and optical usb cables, they can be had for under $100 if you search around. Just keep in mind that optical is signal-only, only usb hubs and HDMI ports on each side are powered in isolation.
18Hurts likes this.
BassThatHz is offline
post #9 of 13 Old 05-06-2019, 11:39 PM
Quoted: 531 Post(s)
Liked: 453
The only AVR I owned that generated the dreaded hiss was a midrange Yamaha AB class AVR.
Trimlock is offline
post #10 of 13 Old 05-07-2019, 06:17 AM
Quoted: 349 Post(s)
Liked: 491
INUKES used as outboard amps for mains in my situation did cause signal noise. I fixed it by pushing the avr to INCREASE gain, the avr does not have any audible signal noise...i think an earlier explanation covered why.
RoboAVS is offline
post #11 of 13 Old 05-07-2019, 06:23 AM
Squirrel!'s Avatar
Quoted: 847 Post(s)
Liked: 534
The noise floor is so ridiculously low in todays equipment, it doesn't really, & shouldn't, garner any consideration.
Chris Popovich likes this.
Main: Mitsubishi 73736|OTA|fireTV|Sony BDP-S1100|Denon AVR4311CI|MartinLogan Preface|Phantom|MartinLogan Encore TF|1-1000watt & 1-500watt DIY 12" Subs|2 Bass Shaker|APC H15 Power Conditioner|Harmony Hub|Sennheiser RS 160|SMSL B1 BT Rx|Linksys SE2500
MBR: Vizio VF550M|OTA|fireTV3|Sony BDP-S1100|Denon AVR-X1000|Chane A1rx-c|Dayton SAT-BK|MartinLogan Dynamo 300|Belkin PF30|Harmony 550
Squirrel! is offline
post #12 of 13 Old 05-07-2019, 07:10 AM
Quoted: 236 Post(s)
Liked: 223
I have a bottom-line Denon and can't even make out a hiss on 90db speakers. That's all I got.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Volt-10 - Micca M-8C for ATMOS
2 @ VBSS End Tables - 2 More VBSS complete!
DIY 110" AT Screen
jevchance is offline
post #13 of 13 Old 05-07-2019, 06:47 PM
mobeer4don's Avatar
Quoted: 174 Post(s)
Liked: 157
My ears have been ringing and hissing since 1987 so noise floor really is a function of your ears and your listening environment...not just the equipment. Ground loops are the only problems I have been able to hear (and fix) in my system. Sometimes I ask my wife to confirm the system is silent though the non-directional nature of tinitus makes it possible to differentiate system noise from the cicadias in my head.
This has been your hearing protection PSA for the day
mobeer4don is offline
