Nu4-6000 bridged not producing sound. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-07-2019, 02:15 PM - Thread Starter
dltnjarrel's Avatar
Quoted: 108 Post(s)
Hello,
I have a nu4-6000 amp and have 2-um18 and 2-um15 subs. I started by taking one of the um15 out of the box and wiring it in series. I wired my 4 pole speakon to 1+ and 2+. Set the mode for a/b to bridge and the crossover to LF. The guy I bought the amps from had 1/4in TRS Stereo Plug to RCA jack adapters on the inputs. I have my lfe cable plugged into input A. I get no output when I run test tones from my receiver. Any ideas? Something I'm doing wrong?
Dalton
Sent from my SM-N950U using Tapatalk
dltnjarrel is online now
post #2 of 5 Old 05-07-2019, 02:29 PM - Thread Starter
dltnjarrel's Avatar
Quoted: 108 Post(s)
I forgot to add. It plays on channel c but not on a.
post #3 of 5 Old 05-07-2019, 06:05 PM
smcmillan2's Avatar
Quoted: 1032 Post(s)
Liked: 882
Have you tried playing from each channel in straight mono (not bridged) to make sure all channels/inputs/outputs are working as expected?
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #4 of 5 Old 05-07-2019, 06:50 PM - Thread Starter
dltnjarrel's Avatar
Quoted: 108 Post(s)
I hooked up the other nu4-6000 and and both sets of bridged channels worked on it. I will try mono through a and b. Also, would I need to change the neutrik connection to 1+ and 1-?
post #5 of 5 Old 05-07-2019, 06:52 PM - Thread Starter
dltnjarrel's Avatar
Quoted: 108 Post(s)
I also ordered xlr to rca cable to see if that helps. Maybe it's something to do with the combo xlr/1/4" trs connection on the inuke.
