New House setup dilemma. Ported Or sealed? - AVS Forum | Home Theater Discussions And Reviews
 9Likes
  • 1 Post By Craig S King
  • 3 Post By plasma_fan
  • 1 Post By Red Five
  • 1 Post By Cichlid109
  • 3 Post By johnson636
post #1 of 21 Old 05-08-2019, 06:55 AM - Thread Starter
jfreeman420's Avatar
Quoted: 37 Post(s)
Liked: 54
New House setup dilemma. 2 x Ported Or 4 x sealed?
I know this has been discussed 1,000 times but I couldn't find anything to help with this particular scenario.
I am moving into a new house within the next month and am planning my new setup. I am limited on space and this is not a dedicated room
It's an area that is about 1150 cuft but it opens to another 600 cuft room to the left another larger room to the right and a kitchen behind separated by a built in bar so there is a lot of open space.
My current setup is 2- SI DS4 18's in 11cuft vented boxes tuned at 17.5 hz. I built these myself. I also have 2 ht18's in 4cuft sealed flat packs 2 x inuke nu6000dsp. My old house was setup completely different without as much open space.
I also have a pioneer sc-lx701 being used as a pre/pro. I have ordered all new onwall m80/vp180 and m3 along with m3 ceiling speakers from axiom audio and will have an emotiva xp9 powering those.
I will be replacing 2 HT 18's with 2 HST18 MKIII's and either keeping the DS4's behind the couch or adding 2 more HST18's
My dilemma is this. I can fit under my 75 inch 4k samsung either 2 full marty's with 2 HST18's or 4 4cuft sealed with 4 HST18's. Either way I may also be able to repurpose the 2 DS4's in stonehenge type boxes behind the couch or on either side giving me either 4 or 6 18's altogether. I will add a third inuke if i go with 6.
I think the array of 4 under the TV will look far better and there will be more of a wow factor with a 4 sub array than the 2 marty's but keep in mind I'm single so there is no WAF i'm just interested in the most bass I can get into this room. If I go with the 4 HST's sealed it will obviously be more expensive and I'm not sure if it's worth the money although I won't mind spending if it's worth it.
So that's pretty much the question. Do I go 4 sealed or 2 ported?
Thanks for your input.
jfreeman420 is offline
post #2 of 21 Old 05-08-2019, 07:11 AM - Thread Starter
Quoted: 37 Post(s)
Liked: 54
I also forgot to mention that the sealed enclosures will allow the TV to be mounted at a more reasonable height. They are only about 20" high. With the 11" center channel the bottom of the TV will be 31" or so. The full marty's on their side will be 25" putting the bottom of the TV 36" which may not be as comfortable for viewing.
post #3 of 21 Old 05-08-2019, 07:20 AM
jcmccorm's Avatar
Quoted: 598 Post(s)
Liked: 444
First-world problems
As far as ported vs sealed, you've got both so you know how they perform. I've not yet built a ported box but am considering it. I'm not sure if the phase-reversal at tuning would give me trouble trying to match them up with sealed subs used for near-field.
Anyway, I've got 2 4cuft 18's I'm using for nearfield. They cover the two center seats pretty well (placed right behind them) but the outside seats don't benefit as much. Would your seating benefit from 4 sealed subs instead of two?
I'm afraid I don't have the experience to offer advice on the front. I'm in a similar situation; 75" Sony with enough room underneath for two full Marty's. I hadn't though of the possibility of doing 4x sealed. I did think of either building larger sealed boxes for the 18's up front (a few db more SPL down low) or going with the full Marty's.
jcmccorm is offline
post #4 of 21 Old 05-08-2019, 07:28 AM - Thread Starter
Quoted: 37 Post(s)
Liked: 54
First world problems indeed
My experience with the sealed subs isn't really valid because I have the HT18's in those currently. You really can't compare those to the HST18's.
My ported boxes are currently near field on either side of the couch. Not the ideal placement but it rocks. I was planning on putting the DS4's in the sealed boxes as a test but again 2 DS4's vs 4 vs HST's is a totally different setup.
post #5 of 21 Old 05-08-2019, 07:43 AM
Red Five's Avatar
Quoted: 401 Post(s)
Liked: 450
20 inches might be pushing it for a width. Can a box be 22 inches wide? I think a surface mounting to the baffle would work than. Two HSTs in ported boxes in that space will tear it up! I think you could get a good internal box volume going 48 on height, which if you put it on its side becomes width and how deep can you go? 48x22x26 would be getting close to 11 cuft internal then do a 17Hz ish tune. If you give me some dimension I can play around with boxes
Stormbreaker | Wisconsin Home Theater Meet Thread | B.M.D. (in progress)
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | Yamaha A3070 | Crown XLS 1502 | iNuke 3000 DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Sub 21" Stormbreaker | Epson 5010e | 120" DIY AT Screen
Red Five is offline
post #6 of 21 Old 05-08-2019, 07:51 AM - Thread Starter
Quoted: 37 Post(s)
Liked: 54
I was planning on using the flat packs from gsgad and the width is 25 inches when laid on their side will be 25 inches high. The sealed boxes can be as low as 20 inches.
I don't have the tools or desire to build another set from scratch.
post #7 of 21 Old 05-08-2019, 08:16 AM
Craig S King's Avatar
Quoted: 359 Post(s)
Liked: 510
While I definitely think 4 18’s in a row under your TV would look great, and definitely meet the “wow” factor, I don’t know if putting the HSTs in small sealed cabinets would be doing them justice. As we are aware, they are absolute monsters in large ported cabinets. My ears are still ringing from the get together and @Jk7.2 ‘s setup back in January.
That being said, I would probably go for the HSTs in full Marty’s and keep the ported DS4s nearfield. Perhaps you can keep the SI HTs and use them in small sealed cabinets in between the full Marty’s? Then you’ll still have 4 18’s up front, plus the 2 nearfield. The SI HTs should fit between the Marty’s and under your TV.
Or sell the HT18s to me.
Jk7.2 likes this.
Craig S King is offline
post #8 of 21 Old 05-08-2019, 08:51 AM
plasma_fan's Avatar
Quoted: 82 Post(s)
Liked: 104
I vote sealed and keep the TV at a better height. While nothing impressive on this forum, 4 - 6 sealed 18" are still really excessive for 99.9% of the population, haha
plasma_fan is offline
post #9 of 21 Old 05-08-2019, 11:00 AM
johnson636's Avatar
Quoted: 1154 Post(s)
Liked: 679
This sounds like a "what works best for your room" deal. You have to make that call. Space restrictions = sealed. No space restrictions = you can go big and ported...simple
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #10 of 21 Old 05-08-2019, 11:06 AM
Russell Burrows's Avatar
Quoted: 67 Post(s)
Liked: 26
What lf tactile transducers are you useing? I.E. 8 lfe buttkickers and 4 nx6000 dsp amplifiers will add wow factors when movie watching.
Yamaha avr, diy l c r surround Behringer nx3000 dsp Fi car audio ib318 v2 310 cubic foot concrete ib lg pf 1500 projector.steren projector mount.
Pending create diy riser Bass shakers , buy fourty 6 inch drivers for some new mains get new 4k projector
I can hear my wallet screaming already
Russell Burrows is offline
post #11 of 21 Old 05-08-2019, 11:22 AM
uniquepattern's Avatar
Quoted: 808 Post(s)
Liked: 857
Id say drop the HST's in some ported boxes...
I mean seriously...
Run everything else nearfield... You know the drill man!
uniquepattern is offline
post #12 of 21 Old 05-08-2019, 11:27 AM - Thread Starter
Quoted: 37 Post(s)
Liked: 54
Can anyone model this in winisd for me? I did it but it doesn't look right. I think i'm missing something it's been a while since I used it.
It looks like I'll get more output from 4 sealed above 20hz.
post #13 of 21 Old 05-08-2019, 02:10 PM
Red Five's Avatar
Quoted: 401 Post(s)
Liked: 450
Red 4.0 cuft sealed
Blue 11 cuft 17Hz tune 15Hz HPF. The xmax is so ridiculous you could probably push the HPF down more.
Above tuning they look pretty similar. More cones is more cones if you have 4 sealed
Red Five is offline
post #14 of 21 Old 05-08-2019, 03:19 PM - Thread Starter
Quoted: 37 Post(s)
Liked: 54
Originally Posted by Red Five View Post
Red 4.0 cuft sealed
Thank you for that. For some reason my model didn't even hit 100db.
post #15 of 21 Old 05-09-2019, 05:20 AM
EndersShadow's Avatar
Quoted: 1186 Post(s)
Liked: 1455
I agree with those above. Dollar for Dollar ported is a better price to performance if you can build a big box, and tune it low. Ported boxes utilize power better, meaning you need less of it, they can perform better than 2 of the same subs in sealed boxes, etc....... The trade off is that you normally need pretty dang large boxes, especially for the HST (due to its T/S Parameters).
From what I remember the goal of the HST drivers was to make a driver that would perform well in smaller boxes..... but with a CRAP-TON of power and some boost down low to take advantage of its large XMax. So the HST drivers can work in smaller sealed boxes, just keep in mind to really utilize the motor and xmax down low (which is what your paying more for over say a UM18) you will need a powerful amp and a device capable of adding a lot of boost below 30hz.
Speakerpower, Peavey and Clone amps come to mind as the better options for a sealed HST. A ported HST can be driven to fairly loud levels with more cost effective amps like iNukes, Crown XLS's, etc...
My Setup | Custom MiniDSP Build | FS: If its For Sale, find it all (here)
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is offline
post #16 of 21 Old 05-09-2019, 11:39 AM - Thread Starter
Quoted: 37 Post(s)
Liked: 54
I certainly appreciate all of the responses and I have come to a solution.
It seems as though I would not be doing the HST's justice in sealed boxes.
I'm going with 2 ported baltic birch from DIYsoundgroup for the HST's and 2 sealed I already have for the DS4's. These are only 29 inches high and will all fit under my screen with the center channel between will put the bottom of the screen at about 33 inches perfect height.
I'll have the wow factor of 4 subs in front and still have space for 2 more behind the couch.
I'm quite excited about this setup 6 x 18's all together.
Does anyone think the NU6000dsp won't have enough power to run the 2 HST's at 4ohms? I'm going to need another amp for subs 5 and 6 behind the couch so an upgrade for the HST's may be in order.
I will post more as the project gets underway.
post #17 of 21 Old 05-09-2019, 12:12 PM
Liked: 1455
Honestly if it was me, I'd stick with the 4 you have. Build two big boxes for the HST's for up front that take up the space you were going to use for all 4 subs. That extra space will let you make a larger box, and tune it lower. The wow factor there will be how far the cones move when asked. It also lowers your power handling requirement to really get the SPL out of them.
Build two ported boxes for the DS4's for behind the couch. The wow factor there will be how much it makes the seats move (or build into a riser if your building one).
I think that would get you what you want and not require you to buy 2 more drivers.
post #18 of 21 Old 05-09-2019, 12:56 PM - Thread Starter
Quoted: 37 Post(s)
Liked: 54
The birch enclosures are 8cuft each tuned to 16hz exactly the specs on SI's page. They will fit in the space just fine and Eric says they sound amazing. The two HST's is probably more than most people could need or want by themselves but I've always gone a bit overboard.
Plus if it isn't overkill or simply ridiculous what fun would that be?
post #19 of 21 Old 05-09-2019, 03:38 PM
Red Five's Avatar
Quoted: 401 Post(s)
Liked: 450
If you want to get everything out of the HSTs get a bigger amp Your output with the 6000 will still be impressive in that space. I do not see a wrong answer here, just a lots of bass!
Sent from my Moto G (5) Plus using Tapatalk
jfreeman420 likes this.
Red Five is offline
post #20 of 21 Old 05-10-2019, 03:32 AM
Cichlid109's Avatar
Quoted: 256 Post(s)
Liked: 154
Just thought I would reply great subs!! I have the same only difference 2 HST's and 2 DS4's. Space for me is a concern so I went with sealed my HST's are in a 8cuft DO cabinet in one corner the DS4's are each in a 7cuft sealed in the other corner. If I had the space ported would be great but room is not big enough. The HST's love power I am using a clone and so far not one issue. Another factor for me going sealed I like being able to get into the single digit range granted not all movies have it but those that do pretty cool. Wish you success on the build.
Denon AVR-4520 LCR BIC PL89ii's w/ 2 SX2400 amps, Volt6 front height w/nu3000, Volt6 rear height w/EP-2000, BIC DV84's w/EPX2800
Infinity1262's in Quad Opposed box w/ nu6000,SI DS4's in 2 sealed Marty Cube w/ IT 8000, 2 SI HST18's in Dual Opposed w/ A14K
Cichlid109 is offline
post #21 of 21 Old 05-10-2019, 04:35 AM
johnson636's Avatar
Liked: 679
Not most people around here
Cichlid109, jfreeman420 and Jk7.2 like this.
