Question for people who have installed Fi IB318 subs - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 1 Post By GrandPixel
  • 1 Post By markmon1
  • 1 Post By Bigus
  • 3 Post By michael hurd
post #1 of 9 Old 05-19-2019, 10:51 AM - Thread Starter
GrandPixel's Avatar
Quoted: 293 Post(s)
Liked: 64
I’m ready to install two of my IB318’s into a manifold. The screw holes in the speaker frame are covered by the part of the rubber surround that is glued down. If I put a screw through it, the head of the screw seems like it might be awfully close to the surround itself, cutting into the part that is glued down. Are these meant to be mounted some other way?
chadsmith013 likes this.
GrandPixel is offline
post #2 of 9 Old 05-19-2019, 03:19 PM
Gorilla Killa's Avatar
Quoted: 1320 Post(s)
Liked: 1811
Most large xmax subs are like that. Make sure screws aren't sticking up or at a angle. It's fine.
Gorilla Killa is online now
post #3 of 9 Old 05-20-2019, 10:08 AM
BassThatHz's Avatar
Quoted: 3654 Post(s)
Liked: 4136
If you want to be safer you could drill a smaller pilot hole perpendicular to the surface, that way the wood won't split and the screw will be guided.
BassThatHz is offline
post #4 of 9 Old 05-20-2019, 06:31 PM
Russell Burrows's Avatar
Quoted: 63 Post(s)
No no no screws.Use round head bolts that require hex allen wrench.
No no no drilling into speaker frame as all speaker frame holes are predrilled at factory
Mark with pencil on mdf where bolts holes go then place speaker off to floor carpet and gently drill on mdf and only mdf then place bolts then after wrenching bolts all the way in mdf then remove bolts from mdf then place speaker frame and gently place speaker bolts use bolts nuts with flat washers and bolts nuts with plastic anti spin ring aka security nuts.
Remove rubber gasket from speaker frame and notice on back of speaker frame 8 predrilled bolt hole s now gently use a small nail to remove rubber from these 8 predrilled bolts hole and only from these 8 predrilled bolts hole so that the 8 bolts can fit into the 8 predrilled bolts hole and place speaker gasket then place speaker frame on mdf then gently gently place bolts into holes
Yamaha avr, diy l c r surround Behringer nx3000 dsp Fi car audio ib318 v2 310 cubic foot concrete ib lg pf 1500 projector.steren projector mount.
Pending create diy riser Bass shakers , buy fourty 6 inch drivers for some new mains get new 4k projector
I can hear my wallet screaming already
Last edited by Russell Burrows; 05-20-2019 at 06:42 PM. Reason: Forgot to mention gasket
Russell Burrows is offline
post #5 of 9 Old 05-20-2019, 08:39 PM
markmon1's Avatar
Quoted: 4418 Post(s)
Liked: 2768
You can just bend the rubber towards the edge of the speaker and screw in behind it
Tyborg likes this.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #6 of 9 Old 05-21-2019, 06:16 PM
Bigus's Avatar
Quoted: 577 Post(s)
Liked: 535
Don't think anyone mentioned drilling the speaker frame.
Type of screw and type of head are not linked. I like square or Allen socket head screws so I don't slip and punch a hole through speaker.
Many people use normal wood thread screws without issue. They are better in plywood than MDF.
If using machine thread bolts, definitely spend some time making sure nut can't spin. Nothing more frustrating than being unable to remove a bolt because the nut spun free. There have been many threads over the years debating the merits of T-nuts, hurricane nuts, epoxy, screw adjacent to nut flange..
Chris Popovich likes this.
Bigus is offline
post #7 of 9 Old 05-21-2019, 09:17 PM
michael hurd's Avatar
Quoted: 631 Post(s)
Liked: 666
Having my share of fun with spun out T-nuts, screws are all I use now. Deep, coarse threaded screws have better holding power, either marketed for particle board or sheet metal.
Ask your doctor if DIY is right for you. Side effects of DIY may include anxiety, elevated blood pressure, lightheadedness, rapid heartbeat, skeletal muscle flaccidity, euphoria, psychological dependence, insomnia, confusion, blurred vision, implusivity, uncontrolled or repeated movements.
michael hurd is offline
post #8 of 9 Old 05-21-2019, 10:08 PM
Tyborg's Avatar
Quoted: 102 Post(s)
Liked: 66
I did this and used leftover pocket screws from my screen build.
Snug Fastener 100 Qty #8 x 1-1/4" Coarse Pocket Hole Screws w/Washer Head (SNG228) https://www.amazon.com/dp/B07L48Q1GM..._eIn5Cb0MV280N
Tyborg is online now
post #9 of 9 Old 05-21-2019, 10:30 PM
N8DOGG's Avatar
Quoted: 1291 Post(s)
Liked: 1524
#8 wood screws....
N8DOGG is offline
