Subwoofer Rut - Help! Polk DSW 660 Pro vs DIY - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #31 of 81 Old 05-22-2019, 06:32 AM
notfastenough's Avatar
Quoted: 161 Post(s)
Liked: 191
12x11 room would rock with a pair of 18's up front.
You've got room behind the chairs for a lilwrecker. It'd be a lot cooler if you had that too
Honestly, coming from the Polk to a pair of well designed DIY 18s is going to blow your mind in that sized space, even if it's not a closed off room. Is it open to another part of the house, or able to be sealed?
notfastenough is online now
post #32 of 81 Old 05-22-2019, 07:00 AM
Zarkoff500's Avatar
Quoted: 172 Post(s)
Liked: 132
With slight modifications, you could have two sets of two VBSS's. Two up front, two in the rear for more even bass throughout the room. Plus you could build all four for well under 1K, higher grade plywood for a nicer finish if you would like. They are about 31.5" H, 23.5" W and 20.5" deep (with 1/2" for recessed woofer). I use two in a 1500 CFT space and am not wanting in the bass department (other than wanting two more .
Zarkoff500 is offline
post #33 of 81 Old 05-22-2019, 07:11 AM
Red Five's Avatar
Quoted: 313 Post(s)
Liked: 341
Since you are in Canada have you looked at Mach 5? You could try messaging them, the UXL-18 would do very nicely in a cyclops up front
Stormbreaker a B&C 21DS115 Subwoofer Solution | Wisconsin Home Theater Meet Thread
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | Yamaha A3070 | Crown XLS 1502 | iNuke 3000 DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Sub 21" Stormbreaker | Epson 5010e | 120" DIY AT Screen
Red Five is online now
post #34 of 81 Old 05-22-2019, 08:01 AM
Jedi940's Avatar
Quoted: 260 Post(s)
Liked: 179
Coming from your polk, anything DIY will sound amazing. Since you've lived with it this long, you are probably not much of basshead. Please let me know if this in incorrect because coming from a single 12 to ANY 18" sub will be night and day. One sub would probably be plenty for you but two would offer better uniformity in the room. It would be helpful to know at what level you normally watch movies as well. Is that near reference level or are you -10 to -20 on the dial? If you aren't pushing your system to the limits, you don't need to go as crazy on subs. And one final question is what is your budget for this project? Sorry if I missed it but I didn't see one listed.
2 V.B.S.S. is a great option. It will give you plenty of bass for cheap but will struggle a bit on the low end at high volumes due to the limited excursion. Another good option is the marty sub design with an ultimax 18" or new Fi HT1. A marty cube or bigger would be a great option and give you better low end since they have much higher excursion. Note that any ported sub will require either a inuke that has built in DSP or the purchase of a miniDSP so you can protect the sub from frequencies below the tuning. If you find the box sizes too large for your space, dropping back to a 15" PA380 in the VBSS line or the ultimax 15" would still give you a substantial amount of bass. There are plenty of people on here that would help you amend the box sizes to accommodate those options.
Nice room BTW.
Jedi940 is offline
post #35 of 81 Old 05-22-2019, 08:57 AM
S_rangeBrew's Avatar
Quoted: 109 Post(s)
Liked: 123
Originally Posted by Rowan611 View Post
DIY is a community about exploring alternative solutions to problems. Not looking down on those solutions.
It's a joke. Have some fun.
S_rangeBrew is offline
post #36 of 81 Old 05-22-2019, 09:01 AM
Rowan611's Avatar
Quoted: 602 Post(s)
Liked: 697
I think you need to learn how to use emoticons then
Didn’t come off as a joke. I’m sure I’m not the only one who didn’t take it as such.
HT: Oppo UHD-203 | Crown Amps | NX3000D | NX6000D | 1299s | Volt 8s | THTs | Crowson Shadow 8s | BOSS riser | Panamax 5300PM | LG OLED 65B6P
Family: Denon AVR-S740 | PSB Alpha AVs | Sony X900F | X1
Rowan611 is offline
post #37 of 81 Old 05-22-2019, 09:20 AM
Quoted: 109 Post(s)
Liked: 123
To get serious, the flexible platform thing is something I agree with. My home theater is above a basement on a standard 2x10 floor and it provides quite a lot of flex. It makes a lot of sense to replicate the same thing with a false floor or riser if you have a more rigid floor.
Also, being serious again: IB subwoofer *really* don't require any calculations if the backwave is exiting into a large area like a basement or attic. I REALLY do think they are the best type of subwoofer if the space can handle it and I don't think they are mentioned as options nearly enough.
post #38 of 81 Old 05-22-2019, 09:25 AM
Rowan611's Avatar
Quoted: 602 Post(s)
Liked: 697
I agree with you on the IB. It’s actually the direction I’d like to go when I remodel my current room (it’ll be split into two separate rooms and I’ll build a storage area for the IB to go.
I wish mine was on a floating floor. Lol. But, the riser is pretty cool man. Lots of fun, as I’m sure your room is.
Rowan611 is offline
post #39 of 81 Old 05-22-2019, 10:59 AM
optoguy's Avatar
Quoted: 41 Post(s)
Liked: 33
Also look at the 21" FTW LTE from Mach 5 if the UXL 18 is too expensive. I don't know if the IXL-18 is available (may have to call Mach 5 to find out) as it might be an alternative to the UM18 (it is pretty expensive to ship, especially with the exchange rate). If your looking for the 460 for the VBSS, it can be found in Canada from solen.ca (about $150, not including shipping?).
Definitely not as many reasonably priced options for us in Canada!
Darren.
optoguy is offline
post #40 of 81 Old 05-22-2019, 01:56 PM - Thread Starter
KevinMRoach's Avatar
Quoted: 46 Post(s)
Liked: 45
Nice room BTW.[IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
Trust me I’ve been well aware of the issues in the bass department for awhile! It’s finally time to sort this out. Typically volume for me is -25 to -20 below reference, so nothing too crazy. Although I might go louder if I actually got some decent LFE for once. VBSS will probably fit my needs both for budget, size, and expectations.
Since you are in Canada have you looked at Mach 5? You could try messaging them, the UXL-18 would do very nicely in a cyclops up front [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
Darren.
Yeah I’ve been in touch with Solen, I’ve bought a multi room amp from them before. Canada is great but sucks for Auto Parts and Speaker Components!
KevinMRoach is offline
post #41 of 81 Old 05-22-2019, 02:25 PM
trilkb's Avatar
Quoted: 630 Post(s)
Liked: 322
It's amazing how LFE can change your listening level. For me it's just more enveloping though and you can really get into the movie. Nothing bad ever came from subwoofers, except maybe neighbors complaining. I'm not a bass head but I do like a house curve. The best part is going to the movie theater and saying "are the subwoofers on?"
Jedi940 likes this.
- 6 BA CR6 array center channel, QSC AD-S82 L/R, 4 jbl 8330a surr , 8 jbl 12" subs w/Inuke 6000. JVC rs420, Denon x4000, Sony x800 -
trilkb is offline
post #42 of 81 Old 05-22-2019, 08:08 PM - Thread Starter
Quoted: 46 Post(s)
Liked: 45
Ok I thought I had it narrowed down to two VBSS, but after doing more measuring my head is starting to hurt.
I simply don't have room to put two standard sized VBSS units in the front, or even one on it's side. The Center speaker can't go any higher without getting in the way of the TV, which is arguably too high already.
1. Is it possible modify the VBSS to be no wider than 20 inches(so 20 inches tall on it's side) do I simply make it taller by the exact same amount? This is assuming I keep the depth the same, but the ports would be closer to the side walls of the interior of the cabinet.
2. Does the port position matter as much? Can I "squash" the sub and make it very long and short?
I have been reading the forums looking for examples that others have tried that would be a fit for my needs, no luck yet. If I can modify one to fit under the Center Speaker, I can fit another in the back behind the recliners and I believe that would be enough to knock my socks off during movie night.
If I can't find a good solution I'll probably have to go smaller than 18", but I did kind of have my heart set on 15HZ..
post #43 of 81 Old 05-22-2019, 10:33 PM
Rowan611's Avatar
Quoted: 602 Post(s)
Liked: 697
Why not build several sealed 15s and place them upfront and in the back? I know the desire to go to a 18. But, in your room 4 sealed 15s would work great. Or, even 4 sealed 18s. I have nothing against ported subs...but sealed can be built smaller and go lower without needing to be huge like a ported sub.
jcmccorm likes this.
Rowan611 is offline
post #44 of 81 Old 05-23-2019, 05:45 AM
Jedi940's Avatar
Quoted: 260 Post(s)
Liked: 179
Box size is what matters. You can make the dimensions whatever you want as long as the internal volume doesn't change. As for the ports, I would keep them at least 1/2 the port diameter away from any walls or they will start to affect the tuning.
Jedi940 is offline
post #45 of 81 Old 05-23-2019, 06:14 AM - Thread Starter
Quoted: 46 Post(s)
Liked: 45
Understood, also I have been reading Port distance from the back wall internally matters as well. So I can keep the VBSS design, keep depth the same, rotate it into its side, and stretch it out.
Or this is getting too heavy of a modification and I could just put two regular sized VBSS in the back of the room and be done with it. Would a single VBSS Pair well with a smaller unit that I could place up front?
Edit: I apologize all the questions and I appreciate all the advice. It’s been so long since I’ve done DIY I seem to have forgotten everything. I built some ZDT3.5s and a ported 15” years and years ago, but it’s been awhile.
post #46 of 81 Old 05-23-2019, 06:41 AM
Jedi940's Avatar
Quoted: 260 Post(s)
Liked: 179
Definitely not to heavy of a modification. You can read the designers post HERE where he states that a +/- 10% change in box volume would be too noticeable.
Also, if you have the skills to build the box anyway, it can be modeled in WinISD with a slot port instead of purchasing the round ones. Slot ports can wrap around corners and give you more flexibility.
Slot Port Build
Here is an example of using two triangular ports with LTD02's stamp of approval for something different.
Jedi940 is offline
post #47 of 81 Old 05-23-2019, 08:18 AM - Thread Starter
Quoted: 46 Post(s)
Liked: 45
Slot Port Build
Well if that’s the case then I’m sure I can make some minor modifications. Looks like I’ll be teaching myself how to use WinISD. Essentially I need a VBSS that is only 20” tall or 20” wide but placed on its side. Not a huge difference, as it’s only 23.5 wide to begin with. A bit narrower is all I need.
post #48 of 81 Old 05-23-2019, 08:33 AM
Jedi940's Avatar
Quoted: 260 Post(s)
Liked: 179
Here is mtg90's driver file for the PA460. This should speed things up quite a bit. Entering the driver parameters can be frustrating. Change the extension to .wdr and you can use it in WinISD.
File Type: txt 00 WT3 Dayton PA460-8 #2.txt (879 Bytes, 5 views)
Jedi940 is offline
post #49 of 81 Old 05-23-2019, 08:40 AM
smcmillan2's Avatar
Quoted: 773 Post(s)
Liked: 671
20W x 37.5H x 20D gets you there (lay it on it's side). This is the volume calculator I use: https://www.the12volt.com/caraudio/boxcalcs.asp
smcmillan2 is online now
post #50 of 81 Old 05-23-2019, 10:27 AM
Quoted: 77 Post(s)
Liked: 77
The spirit of DIY right there. Get after it!
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Eosone RSF 600 - Micca M-8C for ATMOS - 2 @ VBSS End Tables
DIY 110" AT Screen
jevchance is offline
post #51 of 81 Old 05-23-2019, 10:33 AM
Zarkoff500's Avatar
Quoted: 172 Post(s)
Liked: 132
Make sure to keep the end of the port the same distance from a baffle/piece of wood to keep the effective port length.
post #52 of 81 Old 05-23-2019, 11:04 AM
Jedi940's Avatar
Quoted: 260 Post(s)
Liked: 179
If he is switching to a slot port, it will be completely different anyways. None of the previous dimensions will matter as they were based on using 2 circular ports. WinISD will will tell you how long to make the port based on the width and height you enter and the tuning you select. One thing to remember is to subtract the width of the center bracing in the port. Usually that is .75 assuming you use 3/4" mdf.
Jedi940 is offline
post #53 of 81 Old 05-23-2019, 12:17 PM
trilkb's Avatar
Quoted: 630 Post(s)
Liked: 322
Sounds like 8 jbl 12's would work very well for this room. they dont take up that much space @ 1.5-2cu ft per sub.
trilkb is offline
post #54 of 81 Old 05-23-2019, 12:33 PM - Thread Starter
Quoted: 46 Post(s)
Liked: 45
Thanks to everyone for all the advice. I’m going to go with two slightly modified slotted VBSS. One in the front under the center channel no higher than 20”, which is about as small as I can do with an 18” driver anyways. I’ll make an identical matching speaker for behind the recliners. In a month or two I’ll create a build thread and track my progress,
Cheers!
Jedi940 and bear123 like this.
post #55 of 81 Old 05-23-2019, 01:50 PM
Quoted: 77 Post(s)
Liked: 77
Good luck with your project!
DIY 110" AT Screen
post #56 of 81 Old 05-24-2019, 08:21 AM
uniquepattern's Avatar
Quoted: 807 Post(s)
Liked: 857
A pair of modded VBSS? That should be a decent setup...
Looking forward to following the build!
uniquepattern is offline
post #57 of 81 Old 05-29-2019, 04:38 AM - Thread Starter
Quoted: 46 Post(s)
Liked: 45
Before I start a build thread I’m hoping I can get some input/help with my modified VBSS design. I only had an hour to play with SketchUp this morning but this is a rough idea. Apologies for the crude drawing
Driver PA460-8
- A shorter VBSS with slotted ports. - Very close internal volume to original design - 20HZ tune with both ports open, about 15 with one port blocked
I messed up a bit on the SketchUp drawing, the dimensions should be,
39.5” wide
19.5” tall
19” deep
Two slotted ports, essentially I tried to take the original Slotted VBSS 20HZ design and just move the ports to either side for WAF.
Two ports at:
11” wide
1.5” tall
24.75” long(this is confusing me a bit, had some issues nailing it down in WinISD)
Thanks for any advice
ID:	2573012   Click image for larger version
notfastenough likes this.
post #58 of 81 Old 05-29-2019, 09:13 AM
Red Five's Avatar
Quoted: 313 Post(s)
Liked: 341
Driver PA460-8
39.5” wide
19.5” tall
19” deep
Two ports at:
11” wide
1.5” tall
What is the confusing part with WinISD?
post #59 of 81 Old 05-29-2019, 09:37 AM - Thread Starter
Quoted: 46 Post(s)
Liked: 45
I just need some help nailing down the vent calculations.
If I take the original VBSS design, I should theoretically should be able to keep the vent sizes the same, as long as I’m close to the same Internal Volume. Where I’m a bit confused is within WinISD how do I model “plugging” one of the ports to get 15HZ?
post #60 of 81 Old 05-29-2019, 09:52 AM
Jedi940's Avatar
Quoted: 260 Post(s)
Liked: 179
You would need to change the number of ports to 1 and the tuning to 15. The port length should be about the same with those changes. Also remember that port length is calculated down the middle of the port. Someone can check my math but I come up with an effective port length of 25.5.
Sent from my SM-G950U using Tapatalk
Jedi940 is offline
