AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   DIY Speakers and Subs (https://www.avsforum.com/forum/155-diy-speakers-subs/)
-   -   Amplifier for Marty Cube with Dayton Audio UM 18-22 (https://www.avsforum.com/forum/155-diy-speakers-subs/3069412-amplifier-marty-cube-dayton-audio-um-18-22-a.html)
BeeCR 05-25-2019 06:34 AM
What is a good option for a Marty Cube with Dayton Audio UM 18-22 ?
  • Crown XTi 2002
  • Crown XLS2502
  • Behringer NU3000 iNuke
Or any other option? I am planning to use a miniDSP for even an amp without DSP would be ok (?).
Please let me know based on your experience.
BCRSS 05-25-2019 07:19 AM
  • Crown XTi 2002
  • Crown XLS2502
If it were me I would get the NX6000. Better to have extra power, so when you decide to go with another Marty you have the needed wattage to use. Otherwise if your plans never exceed the 1 Marty any of the above would suffice.
Getting a miniDSP for just 1 sub might not be the right choice. Better off with a amp with dsp then.
BeeCR 05-25-2019 08:23 AM
I may go for another one in the future. So yeah 6000 will be a better option. I will think about it
Also, I have a svs pb2000. That is why I thought getting a miniDSP will be a good idea. I may decide to sell pb2000 if the Marty cube is so overwhelming and it doesn’t make much of a value add to the whole setup.
Zarkoff500 05-26-2019 10:45 AM
I am currently using a 3000DSP for my UM18 Marty Cube in bridged mode with the limiter set at about 1200 watts. I am using the inuke for DSP at this point though have a MiniDSP 2x4 HD as well. Two MC's with about 450-600 watts off each channel of the 3000DSP would be decent in a medium-smaller room but the 6000 will give you full potential.
BeeCR 05-26-2019 10:58 AM
Thanks for the information. My room is medium/big size (14x30x12). So and I am currently planning to run one MC. May decide to go for one more. So good to know that you are running 2 MC with one iNuke 3000.
Zarkoff500 05-26-2019 12:14 PM
To clarify, I am only running on MC in about 2000 cft open floor plan. Also, I believe your room would be considered large at more than 5000 CFT so two would fill the space better depending on your listening volumes.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
