Used Behringer EP4000 or new NX3000D to power 2 18" subs? - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By Cichlid109
  • 3 Post By notnyt
  • 1 Post By BassThatHz
post #1 of 9 Old 05-27-2019, 06:33 AM - Thread Starter
toothboy's Avatar
Quoted: 25 Post(s)
Liked: 33
Upgrading to 2 18" DIY subs, and have an opportunity to buy a used, good condition EP4000 for $275. A new NX3000D retails for $350 and has DSP, so I'm not sure which to get.
If anyone needs any additional info about my room/setup that would help answer the above question, please let me know an I'll post it.
(this is my first DIY sub rodeo)
“This is not ‘Nam. This is bowling. There are rules.” — Walter Sobchak
toothboy is offline
post #2 of 9 Old 05-27-2019, 06:51 AM
Quoted: 397 Post(s)
Liked: 342
Get the one with DSP, you will need it.
Trimlock is offline
post #3 of 9 Old 05-27-2019, 07:13 AM - Thread Starter
toothboy's Avatar
Quoted: 25 Post(s)
Liked: 33
And I guess I should also ask...is the NX3000D sufficient to power 2 18" subs?
toothboy is offline
post #4 of 9 Old 05-27-2019, 07:16 AM
Jedi940's Avatar
Quoted: 267 Post(s)
Liked: 185
Which subs are you getting, are you building a sealed or ported box and will you be getting a miniDSP?
Sent from my SM-G950U using Tapatalk
Jedi940 is offline
post #5 of 9 Old 05-27-2019, 07:20 AM
Funkeye's Avatar
Quoted: 180 Post(s)
Liked: 99
What subs?
As rated, The EP4000 has 500W @ 4 ohms more per channel.
Funkeye is offline
post #6 of 9 Old 05-27-2019, 08:03 AM - Thread Starter
toothboy's Avatar
Quoted: 25 Post(s)
Liked: 33
Originally Posted by Funkeye View Post
What subs?
Subs will be sealed DIY SI HT-18's.
toothboy is offline
post #7 of 9 Old 05-27-2019, 10:39 AM
Cichlid109's Avatar
Quoted: 255 Post(s)
Liked: 154
the 3000 will do a very nice job on those 18's. Before I went nuts and upgraded I had the nuke 3000 DSP with the same SI HT18's it really did a good job. I had my 18's in the Marty Cube really no complaints other then getting stuck in the rabbit hole and going broke!!
toothboy likes this.
Denon AVR-4520 LCR BIC PL89ii's w/ 2 SX2400 amps, Volt6 front height w/nu3000, Volt6 rear height w/EP-2000, BIC DV84's w/EPX2800
Infinity1262's in Quad Opposed box w/ nu6000,SI DS4's in 2 sealed Marty Cube w/ IT 8000, 2 SI HST18's in Dual Opposed w/ A14K
Cichlid109 is online now
post #8 of 9 Old 05-27-2019, 12:03 PM
notnyt's Avatar
Quoted: 3731 Post(s)
Liked: 3700
What subs?
except the ratings are nonsense, the amps put out about the same power.
notnyt is offline
post #9 of 9 Old 05-27-2019, 05:54 PM
BassThatHz's Avatar
Quoted: 3678 Post(s)
Liked: 4170
The NX3000D is lighter (by a lot...) and has dsp, and likely more efficient too (less watts wasted as heat and $$$).
notnyt likes this.
BassThatHz is offline
