Behringer NX6000D settings for Ultimax 18 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-27-2019, 08:13 AM - Thread Starter
Liked: 0
Question Behringer NX6000D settings for Ultimax 18
Hi guys,
I was wondering how low is it safe to put subsonic filter in mini marty enclosures, Ultimax 18 driver. IIRC the tuning frequency is around 17hz, so how low should i set the subsonic filter in NX6000D to achieve best results without compromising safety. Thanks a lot!
Vilius Abeciūnas is offline
post #2 of 4 Old 05-27-2019, 08:32 AM
smcmillan2's Avatar
Quoted: 813 Post(s)
Liked: 710
The nu/NX lines natively only allow the lowest HPF at 20Hz. You have to use the HS workaround to get the HPF any lower: https://www.avsforum.com/forum/155-d...z-dcx2496.html
smcmillan2 is offline
post #3 of 4 Old 05-27-2019, 08:43 AM - Thread Starter
Liked: 0
I know that, but I was wondering how low can I go using the workaround not to cause subs to bottom out? Thanks
post #4 of 4 Old 05-27-2019, 09:44 AM
smcmillan2's Avatar
Quoted: 813 Post(s)
Liked: 710
Typically to tune or just a touch (~1 - 2Hz) below. The HPF should protect the driver, haven't modeled it myself.
