Styrofoam Speakers - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By JDontee
  • 1 Post By Zarkoff500
post #1 of 14 Old 05-27-2019, 03:27 PM - Thread Starter
JDontee's Avatar
Quoted: 319 Post(s)
Liked: 212
Styrofoam Speakers
There is a YouTube channel called Tech Ingredients that a friend sent me. On the channel, he did a lot of experiments using different materials, sizes and some Dayton exciters. I decided for fun, I'd try to make a line array of exciters using 1" styrofoam. The sheet is 2' by 6.4' with the exciters positioned using the 3/5th's rule. I only built one as of now as an experiment, so all audio is mono. I did some sweeps to see how they performed for some $100 line arrays. The measurements are from 1 meter and my room doesn't have any treatments.
Here is the exciter that I used: Dayton Exciter
JDontee is offline
post #2 of 14 Old 05-27-2019, 04:22 PM - Thread Starter
JDontee's Avatar
Quoted: 319 Post(s)
Liked: 212
Some sweeps. The sub that I paired it with is an old DCM downward firing 10". I didn't spend that much time trying to set the distance, so it's a bit wonky around the XO, which I set at 150Hz.
ID:	2572496   Click image for larger version
JDontee is offline
post #3 of 14 Old 05-27-2019, 04:24 PM - Thread Starter
JDontee's Avatar
Quoted: 319 Post(s)
Liked: 212
JDontee is offline
post #4 of 14 Old 05-27-2019, 04:28 PM - Thread Starter
JDontee's Avatar
Quoted: 319 Post(s)
Liked: 212
Back of the panel.
CrusherW9 likes this.
JDontee is offline
post #5 of 14 Old 05-28-2019, 01:44 PM
Quoted: 86 Post(s)
Liked: 89
Yeah that guy has some interesting videos. I've been contemplating trying these out with some drop ceiling tiles in my basement for invisible speakers.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Eosone RSF 600 - Micca M-8C for ATMOS - 2 @ VBSS End Tables
DIY 110" AT Screen
jevchance is offline
post #6 of 14 Old 05-28-2019, 03:14 PM - Thread Starter
JDontee's Avatar
Quoted: 319 Post(s)
Liked: 212
I think no matter what, they are going to need a subwoofer. I'm currently crossing them at 150Hz. Also, I'd be interested to know how well they perform in a ceiling tile. Right now, they sound the best while hanging from 2 eye hooks. The frame might keep the material from vibrating changing the frequency curve.
Also, these really need to be EQ'd in the higher frequencies (at least in my setup). So think about that before committing.
JDontee is offline
post #7 of 14 Old 05-28-2019, 04:43 PM
asarose247's Avatar
Quoted: 1199 Post(s)
Liked: 1055
What If
"with some drop ceiling tiles"
the tiles /foam panels were laid on some foam weather stripping tape on the metal frame
as opposed to sitting right down on the metal frame
I saw these vids also and glad to see smeone who said what if.
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is online now
post #8 of 14 Old 05-28-2019, 05:55 PM - Thread Starter
JDontee's Avatar
Quoted: 319 Post(s)
Liked: 212
Originally Posted by asarose247 View Post
What If
It's worth a try. If I get a chance, I'll do a sweep without any EQ of the panel hanging, and one with it propped on the floor. Just so you can see how contact points affect the frequency response.
If you could hang them from some wire or string without touching the frame, that might work as well.
JDontee is offline
post #9 of 14 Old 05-28-2019, 05:56 PM - Thread Starter
JDontee's Avatar
Quoted: 319 Post(s)
Liked: 212
I'm thinking about cutting my current panels in half and making two panels for stereo listening. I'm wondering if they will still perform as a line array as they are now with 4 exciters.
Anyone have an idea if they will still perform as a line array?
JDontee is offline
post #10 of 14 Old 05-28-2019, 06:01 PM
Zarkoff500's Avatar
Quoted: 180 Post(s)
Liked: 138
I also have watched these vidoes. The most recent one that has me intrigued was where he tested the damping properties of MDF vs plywood and found plywood far exceeded MDF per weight
. I recommend watching through at least the 45 minute mark. I also am curious to try the Decidamp (https://www.pyroteknc.com/products/d...ecidamp-sp150/) in a build at some point as it seems like we could make our boxes considerably less resonant with this stuff.
JDontee likes this.
Zarkoff500 is online now
post #11 of 14 Old 05-30-2019, 05:57 PM
Quoted: 86 Post(s)
Liked: 89
Well considering I can put together the entire sound system for $50 it’d be a fun and cheap experiment.
DIY 110" AT Screen
post #12 of 14 Old 05-31-2019, 08:34 AM - Thread Starter
JDontee's Avatar
Quoted: 319 Post(s)
Liked: 212
If that's the case, I'd recommend 2 exciters per 2' by 4' ceiling panel. If you can't EQ the higher frequencies, you will probably not like the sound.
JDontee is offline
post #13 of 14 Old 05-31-2019, 11:20 AM
Quoted: 86 Post(s)
Liked: 89
Thanks for the tip, will make sure I get something that allows me to EQ. Wonder if there's a cheap amp board out there with DSP. Hrmmm...
DIY 110" AT Screen
post #14 of 14 Old 06-02-2019, 01:50 PM
bulls's Avatar
Quoted: 260 Post(s)
Liked: 154
yeah i watched him too
i got 2 exciters but havent used them ...
display - vizio p65
AVR x4300h +lepai 2ch amp = 7.2.4
L/C/R - Chane 2.4, SURROUND - dayton 3in cubes *temporary
BASS - 2x Seaton F18 + JTR 1400 "the wind machine" (not port noise)
2100 ft^3
bulls is online now
diy , dml , line array , styrofoam
