Suggestions on grinding noise from Dayton HO390 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-28-2019, 01:27 PM - Thread Starter
keeper's Avatar
Quoted: 601 Post(s)
Liked: 247
So I just finished my nearfield sub build using a Dayton HO390. Installed the woofer today and am temporarily using an old Buttkicker 1000 amp to test it out. I will order another amp soon. Anyway as soon as I connected the amp to the woofer I get a grinding noise from the woofer. The woofer is brand new. Comes and goes and I haven’t the slightest idea what it could be. Maybe coil or possibly the amp. Any ideas appreciated. The sub sounds awesome.
ID:	2572826   Click image for larger version
keeper is offline
post #2 of 5 Old 05-28-2019, 04:07 PM
notfastenough's Avatar
Quoted: 174 Post(s)
Liked: 197
When you push on the cone (try to apply pressure as evenly as you can) does it make the noise then? Can you feel any roughness in the cone movement?
notfastenough is offline
post #3 of 5 Old 05-28-2019, 04:28 PM - Thread Starter
keeper's Avatar
Quoted: 601 Post(s)
Liked: 247
Thanks for the reply. No not really. Feels normal. It comes and goes. I haven’t the slightest idea what it is but sounds metallic. Could be the old buttkicker amp causing the issue?
keeper is offline
post #4 of 5 Old 05-28-2019, 06:22 PM
Quoted: 174 Post(s)
Liked: 197
Only if something is wrong with it I've never tried it myself, but have read that it should be fine.
You can try taking the driver out of the cabinet and play the content that makes the noise. If something is going on with the voice coil, it'll be easier to hear and feel with the driver out. Might try to listen for leaks, but they normally don't make "metallic" sounds. Might check to see if the wiring on the inside of the cab is rattling. Could also take a look at the terminals and make sure they're not broken.
post #5 of 5 Old 05-29-2019, 12:04 AM - Thread Starter
keeper's Avatar
Quoted: 601 Post(s)
Liked: 247
Will do and thanks for your help.
keeper is offline
