Possibly Infinite Baffle? - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By Rowan611
  • 1 Post By Bigus
  • 1 Post By doodoobutter
  • 2 Post By Bigus
post #1 of 19 Old 05-30-2019, 10:04 AM - Thread Starter
doodoobutter's Avatar
Quoted: 60 Post(s)
I'm so indecisive. Vacation starts next week and I'm still brainstorming when I should be ordering.
I have 4 cx1200 right now. I know they aren't ideal for IB, but what if I did (16) of them? It would be 2 separate opposed manifolds in the basement coming up through the floor, with (8) in each opposed manifold. Winisd says it would work with 1000 watts, just tickling xmax at 10hz. I don't know how accurate that is...
I would love to use the IB318 but it's expensive for 4 of them. Are there any cheap alternatives? So after you guys shoot down this stupid idea, I'll go back to just building my original plan.
doodoobutter is offline
post #2 of 19 Old 05-30-2019, 10:21 AM
Bigus's Avatar
Quoted: 660 Post(s)
Liked: 597
IB3 18 may seem somewhat pricey per driver, but it's a huge amount of displacement per driver (and per $). Pretty sure each would be significantly more displacement that. 4 CX1200's. Do the math of displacement per dollar to help guide you.
Not that that's everything. There are advantages to dividing up the work over a lot more coils and keeping excursion down. But disadvantages too (not so much for IB though).
Bigus is offline
post #3 of 19 Old 05-30-2019, 11:01 AM
Zarkoff500's Avatar
Quoted: 224 Post(s)
Liked: 171
Fi gives a 10% discount if you order four or more but I think the turn sound time is two weeks or so.I am in the same situation and was looking at alternatives to the IB318 but nothing models as good. The UM18 isn't bad but still not as good as the Fi's.
Zarkoff500 is online now
post #4 of 19 Old 05-30-2019, 01:15 PM
Rowan611's Avatar
Quoted: 615 Post(s)
Liked: 712
The Fi’s are THE best choice for IB. You won’t regret the extra cash.
Russell Burrows likes this.
HT: Oppo UHD-203 | Crown Amps | NX3000D | NX6000D | 1299s | Volt 8s | THTs | Crowson Shadow 8s | BOSS riser | Panamax 5300PM | LG OLED 65B6P
Family: Denon AVR-S740 | PSB Alpha AVs | Sony X900F | X1
Rowan611 is offline
post #5 of 19 Old 05-30-2019, 01:22 PM - Thread Starter
Quoted: 60 Post(s)
I would love to do 4x IB318 but I have too many projects going on right now to fit it in my budget. 16x jbls are like 1/3 the price.
post #6 of 19 Old 05-30-2019, 03:12 PM
Jk7.2's Avatar
Quoted: 1570 Post(s)
Liked: 2799
What was your original plan?
Jk7.2 is offline
post #7 of 19 Old 05-30-2019, 04:29 PM
Bigus's Avatar
Quoted: 660 Post(s)
Liked: 597
The JBL probably are a better value depending on the price you get them for. However, 2 of the IB3 18's move more air than 12 of the CX1200's. So it isn't far off.
Bigus is offline
post #8 of 19 Old 05-30-2019, 05:02 PM - Thread Starter
Quoted: 60 Post(s)
I wait for them to go on sale for $30 a driver. My original plan was 4x cx1200s tuned to 18hz. Winisd says 118dbl at 20hz. It gets in the mid 120s between 30hz and 80hz.
Theyre so cheap I want a truck load of them. IB is the only way I could get a truck load of them in my living room.
post #9 of 19 Old 05-30-2019, 05:18 PM
lloyd401's Avatar
Quoted: 32 Post(s)
Liked: 54
Do you have to call them to get that? I ordered 4 and saw no discount. Mine are still being made and I ordered May 6th. They're behind right now, guy said plan on 5 weeks.
These things have a ton of Xmax for an IB. I imagine it would take several JBLs to match one IB318. Cant wait to get mine.
Sent from my SM-G950U using Tapatalk
Marantz SR6011 * Outlaw Model 750 * M&K S-150 LCR * M&K SS-150 Surrounds * JBL In Ceiling Atmos * FI IB318v2 x4
lloyd401 is offline
post #10 of 19 Old 05-30-2019, 05:25 PM
Zarkoff500's Avatar
Quoted: 224 Post(s)
Liked: 171
I emailed and asked them. Hopefully they will still apply the discount.
post #11 of 19 Old 05-30-2019, 05:26 PM
Bigus's Avatar
Quoted: 660 Post(s)
Liked: 597
It takes six. Well, six and a bit more.
Bigus is offline
post #12 of 19 Old 05-31-2019, 03:12 AM - Thread Starter
Quoted: 60 Post(s)
Are you saying it takes 6 cx1200s to match one IB318? If so, I might be on to something here on the cheap. And possibly with more mid bass too, which will have to be toned down.
Edit 1: Interesting update. I modeled 16x cx1200 drivers vs 4x IB318 in winisd. The 16 cx1200s are around 132dbl from 30zh to 80hz. The 4x IB318 are around 128dbl from 30hz to 80hz. Under 30hz, they are both exactly the same, hitting 123dbl at 20hz, 119dbl at 15hz, and 113dbl at 10hz.
As soon as these cx1200 go on sale again, I'm going to buy like 20 of them. I hope I don't have to wait for black friday
Edit 2: I tried modeling some other 4x 18" subs and nothing comes anywhere close to 4x IB318 or 16x cx1200. I will post a build thread when they go on sale for $30. I will have to learn to take measurements so I can post results.
post #13 of 19 Old 05-31-2019, 06:14 AM - Thread Starter
Quoted: 60 Post(s)
Before you read this, see my last post. According to this link:
https://www.hometheatershack.com/for...affle-faq.html
The area of the hole in the floor should be no less than the total combined sd of the drivers. So 8 cx1200 is 680in^2. That is a massive hole in the floor. Can I get away with like 12x18 inch hole? Or is this whole project now screwed? I don't know if I want to cut 4 holes in my floor...
JonFo likes this.
post #14 of 19 Old 05-31-2019, 01:31 PM
johnson636's Avatar
Quoted: 1297 Post(s)
Liked: 764
Are you sure IB is right for your situation?
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #15 of 19 Old 05-31-2019, 05:40 PM - Thread Starter
Quoted: 60 Post(s)
I think so. I don't mind cutting holes in my floor, and I don't mind spending $360 to get 12 more drivers to do it. I also don't want a lot of enclosures in my living room, we're trying to keep it minimalist. We're coming from a lilmike f20 so we don't want any less than 115db at 20hz. If I can run 8 cx1200 through a 12" x 18" hole in the floor 2x, and it will work like winisd says it will, I want it and can't think of another way to do it without tons of boxes in the room.
And also WAF has already approved of putting holes in the floor instead of massive boxes in the living room. And she loves bass, the f20 behind the couch made her happy lol.
post #16 of 19 Old 05-31-2019, 06:00 PM
Bigus's Avatar
Quoted: 660 Post(s)
Liked: 597
Smaller than recommended manifold will have some effect on the sound, acting somewhat like a port in a bandpass enclosure. It could probably be modeled in hornresp or something if you really wanted to. Or just build what you can, measure, and eq. It may not be perfect but will still be pretty good. The closer you can get to ideal the better. 12x24 is better than 12x18.
Yes, a host of cheap $30 12" drivers can provide massive displacement. I've thought about it but at some point the drivers themselves take up too much physical space. For example... Putting 16 Fi IB3 18's in an IB alignment is nuts already. But can you imagine trying to find a place to stuff 96 of those CX1200's??
Bigus is offline
post #17 of 19 Old 06-01-2019, 12:12 AM
markmon1's Avatar
Quoted: 5378 Post(s)
Liked: 3494
Start with 2 Fi 318's. My friend runs 2 and they barely move and they crank out plenty of bass for his room.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #18 of 19 Old 06-01-2019, 09:07 AM - Thread Starter
Quoted: 60 Post(s)
If I go with the Fi I would only do 4. I don't think 16 cx1200s will take up that much space in the basement. They will be in a storage area under the living room. I was going to put a driver on each side of the enclosure so it'll extend down from the ceiling just over 2ft.
@markmon1 , if winisd is giving me accurate numbers, I will get more output from the cx1200 over 2x Fi 318s. Pretty much 6db from 10hz to 80hz. I think I'm going to go for the 12s when they go on sale. I'm really curious about what kind of measurements I'm going to get. They're cheap, if I don't like it I'll put them on craigslist and save some for our game room in the basement. Then I can go with 4x Fi 318s since I'll already have holes in the floor and end the upgraditis.
post #19 of 19 Old 10-14-2019, 12:56 PM
Quoted: 23 Post(s)
Liked: 4
Cerwin Vega Vega series 15" might work for infinite baffle. Not as good as the FI driver though.
Ex JL Rep is offline
