Bondo, Glazing Putty, or MH Ready Patch for MDF Seams - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By notnyt
post #1 of 9 Old 05-30-2019, 05:46 PM - Thread Starter
bfb1963's Avatar
Quoted: 28 Post(s)
My box edges have been sealed with 50/50 glue and water, but even with sanding some minor fill is needed. Bondo is pretty thick, and is not spread thin that easily. Does glazing putty work? What about MH Ready Patch?
I think primer has to be applied prior for MH Ready Patch.
bfb1963 is offline
post #2 of 9 Old 05-30-2019, 07:40 PM
Bigus's Avatar
Quoted: 635 Post(s)
Liked: 583
I think there are plenty of products that probably work well but I've tended to just use wood glue mixtures. Thin with water to seal, thicken with sawdust to fill.
The collection bag on a hand random orbital sander is a handy place to store fine sawdust until needed.
Bigus is online now
post #3 of 9 Old 05-30-2019, 08:09 PM
Craig S King's Avatar
Quoted: 408 Post(s)
Liked: 522
Traditional wood filler putty has worked well for me.
Craig S King is offline
post #4 of 9 Old 05-31-2019, 12:54 AM
Quoted: 149 Post(s)
Liked: 68
The pink wood filler putty and drywall spackle, both turn white when dry. I’ve used both now and haven’t had a single seam show even despite a couple rough edges I’ve overcome. In some cases I’ve done both. Wood filler first, sanded, then drywall spackle to ensure a perfectly smooth seam.
Sent from my iPhone using Tapatalk Pro
FOHTech is offline
post #5 of 9 Old 05-31-2019, 03:29 AM
notnyt's Avatar
Quoted: 3816 Post(s)
Liked: 3771
I use spackle. Sands easy, applies easy.
I've also used bondo and glazing putty. Both work, but they don't sand as easy and the mdf comes off way quicker than the filler in those cases.
Jk7.2 likes this.
notnyt is offline
post #6 of 9 Old 05-31-2019, 05:18 AM
Quoted: 446 Post(s)
Liked: 364
Spackle and bondo
Spackle is the easiest and you can add water later if your can dries up.
Bondo is the best IMO and it does spread thin super easy with a straight edge.
Trimlock is online now
post #7 of 9 Old 05-31-2019, 05:53 AM
lawdogx's Avatar
Quoted: 148 Post(s)
Liked: 170
What are you finishing with? The Duratex folks are local to me and they say that some fillers don’t bond well with Duratex. They recommend Elmer’s color change filler and I’ve been using that with Duratex with great results.
SPEAKERS: 3 x DIYSG 1099's LCR; DIYSG HTM 6's and 8's surround; 4 x RSL C34E's atmos.
SUBS: 4 x UM18-22 Mini Marty's (and always building, currently working on Devastators).
SIGNAL CHAIN: Denon X4400; Minidsp 2x4 HD; 2 x Jensen Iso Sub 2RX; 2 x NX6000d.
lawdogx is online now
post #8 of 9 Old 05-31-2019, 06:26 AM
Quoted: 170 Post(s)
Liked: 171
I used regular drywall patch on my VBSS and haven't had any problems.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Volt-10 - Micca M-8C for ATMOS
2 @ VBSS End Tables - 2 More VBSS on the Way
DIY 110" AT Screen
jevchance is offline
post #9 of 9 Old 05-31-2019, 06:58 AM
jcmccorm's Avatar
Quoted: 611 Post(s)
Liked: 461
It's been my experience (so far), that there's a difference between filling and sealing.
I've been able to to completely smooth a joint with either glue&water or spackle along with a lot of sanding. After prime and paint, the joint is invisible. However, I've got boxes that started out with invisible joints but after a couple of months, they pronounce themselves loud and clear. The only thing I can guess is that the smooth surface of MDF doesn't soak in primer/paint while the adjoining MDF piece with the cut edge *does* soak that stuff in in such that it expands a little bit and broadcasts the joint between the two pieces.
So while making the joint smooth can be done any number of ways (along with some elbow grease), I'm looking for the best way to actually seal the cut edge of the MDF so that the joint *stays* invisible. So far, my best results have been with glue&water.
PS. I might add that I'm using paint and primer, not Duratex. The primer/paint is pretty unforgiving whereas I'd imagine that Duratex could hide an unsealed MDF edge.
jcmccorm is offline
