Full marty help. Please make sure I have all the rights parts for my build. - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By lawdogx
  • 1 Post By jcmccorm
post #1 of 16 Old 05-31-2019, 10:52 AM - Thread Starter
Quoted: 31 Post(s)
Liked: 2
What else do I need for dual full martys? I am using the following
Receiver is denon 4400. I also plan to in the near future to get seat kickers. so I may need 2 y splitters?
Not sure which drivers I will use yet.
https://www.parts-express.com/behrin...fier--248-7014
https://www.parts-express.com/dayton...-coil--295-518
Or https://www.parts-express.com/dayton...4-ohm--295-472
I want to make sure I am not forgetting anything. I already have all the wood.
speaker wire. 12G or 14G. Not sure how much I'll need. Anyone know how many feet I need for 1 cable run for this?
speakon connectors https://www.parts-express.com/neutri...mount--092-054
speakon cable to go to the pro amp. https://www.monoprice.com/Product?c_...seq=1&format=2
Y splitter.
https://www.amazon.com/dp/B000068O16..._Cfd8CbWWVZMT4
Anything I am forgetting, or did wrong?
Thank you anyone for helping.
TIV13 is offline
post #2 of 16 Old 05-31-2019, 11:27 AM
Liked: 0
Hey I’m new to this build but am in the middle of a full Marty build myself from everything I read you need a amp with DSP for the HPF (High pads filter) so you’ll actually need the NX6000D which is $100 more but has a built in DSP
(I can’t post the link but just bought one from parts express for $550) like 4 days ago they also had a Memorial Day coupon I don’t know if it’s still good ($50 off $500 and $25 off $200 or something like that)
Austin-scott is online now
post #3 of 16 Old 05-31-2019, 11:30 AM
Liked: 0
Also assuming you don’t have any XLR to RCA cables you’ll need this to go from the NX6000D to your receiver
Monoprice XLR Male to RCA Male Cable - 6 Feet -
If you have prime they have the six foot for like $6 (wish the 3ft was as cheap but it was double the price)
post #4 of 16 Old 05-31-2019, 11:53 AM
jcmccorm's Avatar
Quoted: 597 Post(s)
Liked: 444
Screws to mount the driver.
Gasket tape to go between the driver and the baffle.
Whatever you're using to connect the internal wire to the Speakon connectors and speaker terminals (spade connectors, solder, etc.)
jcmccorm is offline
post #5 of 16 Old 05-31-2019, 11:55 AM
smcmillan2's Avatar
Quoted: 817 Post(s)
Liked: 712
As Austin-scott mentioned, some form of DSP. Either the NX6kD, or a miniDSP.
As much as would be required to get from wherever you put the speakon connector on the cab to the cutout for the driver, plus ~6 - 8 inches. Just grab the shortest roll from Monoprice (looks to be 50' these days): https://www.amazon.com/Monoprice-102.../dp/B001UNGJF6
Plus spade connectors for each end (speakon and driver).
A splitter is not necessary in this case.
smcmillan2 is online now
post #6 of 16 Old 05-31-2019, 11:58 AM
lawdogx's Avatar
Quoted: 90 Post(s)
Liked: 94
If you go on the GSG website they have fantastic parts lists and detailed set-up instructions for Marty subs. While you're there, you should take a look at their pre-cut MDF kits for every variation of Marty sub. They're idiot proof (as this idiot can attest), and sound phenomenal.
ksmchristy likes this.
SPEAKERS: 3 x DIYSG 1099's LCR; DIYSG HTM 6's and 8's surround; 4 x RSL C34E Atmos; 4 x UM18-22 Mini Marty's.
COMPONENTS: Denon X4400; Minidsp 2x4 HD; 2 x Jensen Iso Sub 2RX; 2 x NX6000d; Epson 5040UB.
lawdogx is online now
post #7 of 16 Old 05-31-2019, 07:07 PM - Thread Starter
Quoted: 31 Post(s)
Liked: 2
Why do I not need a splitter if I want dual subs and dual seat kickers?
Thank you for the help.
TIV13 is offline
post #8 of 16 Old 05-31-2019, 07:24 PM
smcmillan2's Avatar
Quoted: 817 Post(s)
Liked: 712
You can drive the NX6k with a single sub out from the AVR-X4400, using Biamp mode to drive both Marty subs.
Use the other sub out on the 4400 to drive the amp for the kickers.
post #9 of 16 Old 05-31-2019, 08:49 PM - Thread Starter
Quoted: 31 Post(s)
Liked: 2
How do all 4 of the males plug into the reciever if there are only 2 sub ports?
TIV13 is offline
post #10 of 16 Old 06-01-2019, 05:26 AM
smcmillan2's Avatar
Quoted: 817 Post(s)
Liked: 712
Huh?
post #11 of 16 Old 06-01-2019, 05:46 AM
Quoted: 142 Post(s)
Liked: 122
One sub out from your receiver goes to the subwoofer amp. Then speaker wire from the amp to the subwoofers.
The other sub out from your receiver goes to the buttkicker amp. Then speaker wire from that amp to the buttkickers.
dorri732 is online now
post #12 of 16 Old 06-01-2019, 12:04 PM - Thread Starter
Quoted: 31 Post(s)
Liked: 2
Oh. Thank you!
TIV13 is offline
post #13 of 16 Old 06-03-2019, 12:33 AM - Thread Starter
Quoted: 31 Post(s)
Liked: 2
How much soldering will I need to do? Can I just use spades and crush the wire?
TIV13 is offline
post #14 of 16 Old 06-03-2019, 05:42 AM
jcmccorm's Avatar
Quoted: 597 Post(s)
Liked: 444
That's correct, you don't need to solder at all if you don't want to. I just have a soldering iron that's handy and like to solder after crushing the spade onto the wire. It's not necessary though.
TIV13 likes this.
jcmccorm is offline
post #15 of 16 Old 06-09-2019, 01:31 PM - Thread Starter
Quoted: 31 Post(s)
Liked: 2
Is there a place I can buy like 10 at, at a decent price? Amazon only has them in bulk.
TIV13 is offline
post #16 of 16 Old 06-09-2019, 01:58 PM
jcmccorm's Avatar
Quoted: 597 Post(s)
Liked: 444
Auto parts stores always have them.
jcmccorm is offline
