My TLAH LCR build. - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 38Likes
post #31 of 43 Old 06-02-2019, 09:20 PM
JDontee's Avatar
Quoted: 319 Post(s)
Liked: 213
I understand not wanting to go through the hassle to take them outside. Maybe just position the mic 1 meter away.
What's the plan for surrounds?
What ended up being your total cost to build per speaker?
notfastenough likes this.
JDontee is offline
post #32 of 43 Old 06-03-2019, 06:52 AM
trilkb's Avatar
Quoted: 657 Post(s)
Liked: 335
Originally Posted by notfastenough View Post
Sound for movies has been great!! Considering what they were replacing, increased capability was going to happen no matter what haha! I rarely listen at reference, normally -10. At these levels they don't sound strained like the Polks did. Everything sounds very clear and the front stage is pretty cohesive when sounds are panning. Mad Max and Deadpool were treats!! I'm ready for Alita: Battle Angel to come out, should be fun as well. The Atomic Blonde was fun, especially when the music came around, great soundtrack.
I've also watched the John Wick 2 tunnel scene at reference and it was certainly loud, yet it didn't hurt your ears from being shrill or sharp. I'd say they are very capable HT speakers and sound good for music too. I really enjoyed Eagles in Melbourne, great sound and clarity. It was really cool to distinguish the sound of different instruments with such a busy stage. Guitars sound so great on these speakers, especially the songs where they were using 12 strings.
Honestly, having the center match and sit at screen level has really improved the movie watching experience. Adding the absorption has really helped the room as well. I feel like dialogue shouldn't be an issue for any seat in the house. All in all, I think the combination of changes along with reasonably good speakers made the difference in this area.
And when I built the THTs, I never though I'd consider adding any more, yet here we are. Upgrading as if a room really NEEDS 4 horned subs lol.
The benefit of a AT screen is worth every penny. Having the audio come from the center of the image, or in your case the entire image, I bet, is just life changing. When you get into 100+" screens its really almost nessecary at that point.
Id love to hear those things compared to the make shift curved SLA I built. Atomic blonde had some great music scenes.
- 6 BA CR6 array center channel, QSC AD-S82 L/R, 4 jbl 8330a surr , 8 jbl 12" subs w/Inuke 6000. JVC rs420, Denon x4000, Sony x800 -
trilkb is offline
post #33 of 43 Old 06-03-2019, 08:04 AM
MKtheater's Avatar
Quoted: 2520 Post(s)
Liked: 2610
IMHO the TLAH sounds better than the SLA that I built. I used better drivers than the plans called for for both. I also have original or stock Tlah to compare with the BFM crossovers. The differences going to better drivers was just a smoother response, which makes them sound more laid back. Of course this is without any EQ. I actually built a ported line array with the same number of drivers but it was 4 inches longer and deeper, My best array.
Building the room, speakers, and subs.
MKtheater is online now
post #34 of 43 Old 06-03-2019, 08:05 AM - Thread Starter
notfastenough's Avatar
Quoted: 190 Post(s)
Liked: 221
Originally Posted by Rowan611 View Post
I’m glad they’ve changed the experience for you. I’ve never heard a TLAH or any line array. I am very curious about them.
As for the subs, think about it this way; 2 more reduces the strain on the first two drivers by almost half, plus adds 6 more dB. Not to mention if you can put them in the back, much better coverage for the whole theater. I love having 4. Hell, if I could talk my wife into it, and if I had the time, I’d build 4 more. They’re so much value for what they cost to build.
Oh yeah, I'm definitely leaning on improving sound for rational with the wife! The back row actually does need some help, so with 4, I hope to smooth it out a bit. Increased peak capability will be my little personal bonus
Sure thing, I can do that. I remember reading something about a specific REW setting for full range indoor measurements though. It had something to do with the ability to ignore some reflections or duplicate readings from reflections, can't recall (the only problem I have with my memory)
Surrounds were a compromise when I first began installing the HT. I went with BIC FH8-W in walls for surround and surround backs. They've been pretty good overall, they can keep up with the TLAHs as far as I can tell so far. They really could keep up with the Polks, but haven't done any real checking since the LCR install.
Not including wire, batting, and tools bought for this job, I spent a little over $160 per speaker all in. Right after buying my first batch of components, the HT line at DIYSG released and I had a moment of buyer's remorse. I wanted to do a MTM HT8 because I think the dimensions could have worked with my desired screen configuration, but decided to press on with the TLAH build. I had essentially seduced myself with the idea of the silver baffles and black drivers with a line array lol.
That build is a cool concept. Summing a group of existing speakers is pretty neat. I was not sure how the effect was going to perform with the tweeter C2C spacing, but I'm glad it worked out!
Next movie on my agenda is Bohemian Rhapsody, then Lego Movie 2 for the family. These upgrades have made movie watching even more enjoyable and immersive. I don't find the speaker colors distracting, but I can see how it would for some. The light from the screen does highlight them some, but for me, it's a psycho-acoustical enhancement
notfastenough is offline
post #35 of 43 Old 06-03-2019, 08:24 AM
MKtheater's Avatar
Liked: 2610
I have speakers with the eminence beta 10s, have owned the deltalites, kappalites, etc. I prefer the soft dome arrays over the CDs I have heard and owned. The TLAH will also sound bigger as well. I have a dual 10 inch eminence beta speaker now and the reason I like it better than my upgraded TLAH is because of the tweeters. The array of 4s sound as good and can play louder than the dual 10s. I have been thinking about combining the 4s with the arrays of the nice tweets.
post #36 of 43 Old 06-03-2019, 11:40 AM
JDontee's Avatar
Quoted: 319 Post(s)
Liked: 213
I have those in-walls for surrounds. For the levels I listen, they do the job. If I upgrade to Atmos, I'd add them in ceiling as well.
JDontee is offline
post #37 of 43 Old 06-03-2019, 11:41 AM
asarose247's Avatar
Quoted: 1244 Post(s)
Liked: 1090
" Upgrading as if a room really NEEDS 4 horned subs lol."
just ask @hd0823
he's got a lot to laugh about
JS
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is online now
post #38 of 43 Old 06-03-2019, 11:56 AM
hd0823's Avatar
Quoted: 847 Post(s)
Liked: 1588
just ask @hd0823
JS
Lol I'm actually building 2 more horns I guess not really a horn but 6th order band pass box. You can never have to much bass lol
Sent from my SM-N950U using Tapatalk
hd0823 is online now
post #39 of 43 Old 06-03-2019, 12:08 PM
Red Five's Avatar
Quoted: 644 Post(s)
Liked: 399
@hd0823 can claim six horns in his setup, the horn does not flare and the rear chamber is vented instead of sealed, but it is a front loaded horn The way in which the system is configured is a 6th order band pass.
Stormbreaker | Wisconsin Home Theater Meet Thread | The Devastator Index
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | Yamaha A3070 | Crown XLS 1502 | iNuke 3000 DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen
Red Five is online now
post #40 of 43 Old 06-05-2019, 09:07 PM - Thread Starter
Quoted: 190 Post(s)
Liked: 221
Yeah, I was setting this up for tonight, but ran out of time before everyone came home. Be patient with me, it's tough getting some time to set up and have a quiet house. I'll get it though!!
JDontee likes this.
post #41 of 43 Old 08-02-2019, 07:10 PM
MKtheater's Avatar
Liked: 2610
How are you liking the setup?
post #42 of 43 Old 08-04-2019, 11:44 AM
BP1Fanatic's Avatar
Quoted: 227 Post(s)
Liked: 193
Thumbs up
That's why I love this forum! AWESOME build notfastenough!
hd0823 and notfastenough like this.
Sony XBR65x900e / STR-DN1080 / original PS4 / WOW! Ultra TV / Quantum Access Mini PC Stick w/Windows 10 / 8 x Rockville SPG88 8“ DJ PA Speakers / Dayton Audio SA1000 / Kicker 08S15L74 in a Tapped-Tapered Quarter Wave Tube (negative flare tapped horn).
BP1Fanatic is offline
post #43 of 43 Old 08-04-2019, 03:24 PM - Thread Starter
Quoted: 190 Post(s)
Liked: 221
I'm really happy with them overall. The vertical pattern control is pretty cool, standing up changes the HF response tremendously. When you're in the butter zone it's almost like wearing headphones. Still very happy with the aesthetics. I've seriously enjoyed watching The Eagles Melbourne Bluray with these. I'm relatively happy with imagining, but they didn't really start to "disappear" until I added the Atmos channels.
So far, my only gripe is that the center has a particular frequency in speech that is pretty harsh or sharp. It just doesn't sound as smooth as the rest of the sound. Not sure if it might be a component, a side effect of the rear mounted tweeters, or normal. But it's not significant enough for me to start troubleshooting.........yet. one day I'm sure I'll feel the urge to figure it out.
Sorry I haven't done measurements yet, it just hasn't been able to get prioritized over other upgrades or repairs, or life lately. I haven't forgot though, I'll knock it out when I can, hopefully sooner than later.
