The Tesseract Sub Build - AVS Forum | Home Theater Discussions And Reviews
 15Likes
  • 1 Post By jevchance
  • 5 Post By Chris Maxey
  • 2 Post By Chris Maxey
  • 1 Post By Chris Maxey
  • 4 Post By Stephen Hopkins
  • 1 Post By lawdogx
  • 1 Post By trilkb
post #1 of 13 Old 06-04-2019, 08:33 AM - Thread Starter
Here is my first DIY sub! The bracing on the inside is a bit over-engineered, but it should at least be well braced and I think it looks cool. I was going for the window-pane style bracing, but required some of the portions to be circular to fit the subwoofer. I also added extra bracing to make sure no portions of the outer panels had too much surface area without bracing, in case there were any resonance issues. I designed the box in Solidworks and then had the pieces CNC'd. Unfortunately I goofed the tolerancing a bit, so some of the datums and grooves required a bit of sanding to fit. It uses a ton of wood glue and I sealed the inside seams with epoxy.
The subwoofer used is a SI HST-18 MKIII. It's a beast of a sub! The weight of the box was ~80 lbs and the sub is another ~80, giving a total weight for whole thing at 160+ lbs. The dimensions of the box itself are 22" x 22" x 22" and there is a neutrik connector in the back.
I'm calling it "The Tesseract" because it's a complicated cube structure that is blue (and I love the Marvel movies). Hope you enjoy seeing it!
Chris Maxey is offline
post #2 of 13 Old 06-04-2019, 08:43 AM
Quoted: 119 Post(s)
Liked: 131
Looking forward to seeing it. Make with the pics!
Chris Maxey likes this.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Eosone RSF 600 - Micca M-8C for ATMOS - 2 @ VBSS End Tables
DIY 110" AT Screen
jevchance is offline
post #3 of 13 Old 06-04-2019, 08:44 AM - Thread Starter
Here is the CAD image and some initial fitting pics.
EDIT: The CAD pic is an older version, it's missing the circular window-pane style brace nearest to the sub opening.
ID:	2575720   Click image for larger version
ID:	2575722   Click image for larger version
ID:	2575724   Click image for larger version
ID:	2575726   Click image for larger version
post #4 of 13 Old 06-04-2019, 08:45 AM - Thread Starter
Some painting pics.
ID:	2575732   Click image for larger version
ID:	2575734   Click image for larger version
Trimlock and eljaycanuck like this.
post #5 of 13 Old 06-04-2019, 08:47 AM - Thread Starter
Pic of the sub and final assembly.
ID:	2575738   Click image for larger version
ID:	2575740   Click image for larger version
ID:	2575742   Click image for larger version
ID:	2575744   Click image for larger version
eljaycanuck likes this.
post #6 of 13 Old 06-04-2019, 10:22 AM
Stephen Hopkins's Avatar
Quoted: 424 Post(s)
Liked: 196
Damn, I thought I was going to find a glowing blue glass sub when I opened this thread... but still, great work, especially the intricacy of the bracing.
BenQ TK800 | Silver Ticket 106" 16:9 1.0 Grey | Marantz SR6011 | B&W P6 | B&W CDMC SE | Sonance .5 THX SUR | MCM In-Ceiling Atmos | Ascendant Avalanche 12" in 6 ft^3 @ 18Hz w/ BASH 500w Plate Amp | Sony X800 | NVidia Shield TV Pro | XBox One 500gb | Nintendo Switch | Harmony Smart Control | SmartThings Hub | Google Home | AT&T Fiber 300 | YouTube TV | Netflix | HBO Now | Spotify
Stephen Hopkins is offline
post #7 of 13 Old 06-04-2019, 10:28 AM - Thread Starter
That would be awesome. Next build perhaps!
post #8 of 13 Old 06-04-2019, 10:32 AM
lawdogx's Avatar
Quoted: 116 Post(s)
Liked: 115
That's some excellent and intricate woodworking! Nice job!
SPEAKERS: 3 x DIYSG 1099's LCR; DIYSG HTM 6's and 8's surround; 4 x RSL C34E's atmos.
SUBS: 4 x UM18-22 Mini Marty's (and always building, currently working on VBSS's).
SIGNAL CHAIN: Denon X4400; Minidsp 2x4 HD; 2 x Jensen Iso Sub 2RX; 2 x NX6000d.
lawdogx is offline
post #9 of 13 Old 06-04-2019, 11:17 AM
Red Five's Avatar
Quoted: 430 Post(s)
Liked: 473
Would it be possible to use plexiglass on a few panels? Throw a few blue LEDs in there for effect
Stormbreaker | Wisconsin Home Theater Meet Thread | B.M.D. (in progress)
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | Yamaha A3070 | Crown XLS 1502 | iNuke 3000 DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Sub 21" Stormbreaker | Epson 5010e | 120" DIY AT Screen
Red Five is offline
post #10 of 13 Old 06-04-2019, 12:26 PM
Quoted: 119 Post(s)
Liked: 131
Looks great! That's some intricate stuffing work.
DIY 110" AT Screen
post #11 of 13 Old 06-04-2019, 08:21 PM
Quoted: 420 Post(s)
Liked: 348
Hah that would be awesome! But that thick of plexi would probably cost as much as the sub
Trimlock is offline
post #12 of 13 Old 06-06-2019, 05:24 AM
trilkb's Avatar
Quoted: 654 Post(s)
Liked: 331
I was thinking some printed "veneer" to look like the tesseract would be the easy way. like a vinyl wrap. Ive actually seen a way with epoxy counter tops with fiberoptic lights embeded that had a really cool effect.
- 6 BA CR6 array center channel, QSC AD-S82 L/R, 4 jbl 8330a surr , 8 jbl 12" subs w/Inuke 6000. JVC rs420, Denon x4000, Sony x800 -
trilkb is offline
post #13 of 13 Old 06-07-2019, 07:16 PM
BassThatHz's Avatar
Quoted: 3702 Post(s)
Liked: 4213
I was thinking more like glow-in-the-dark radioactive-blue mixed with 2-part clear epoxy for a high-gloss look.
ID:	2577294   Click image for larger version
ID:	2577304   Click image for larger version
BassThatHz is offline
