NX3000D No Sound - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Kpilk
  • 1 Post By audiosq
post #1 of 7 Old 06-05-2019, 07:06 PM - Thread Starter
audiosq's Avatar
Quoted: 24 Post(s)
NX3000D No Sound
I just got an NX3000, hooked it up and no sound, any ideas? Everything seems secure. Trying to run two subs dual mono, AVR has two sub outs. The only thing I can guess is the Speakon NL2FX connectors aren't right somewhere, but it only has two holes to screw in the wire and things seemed tight before I screwed everything together. Now I can't get them unscrewed to check to make sure they are tight so any help there woulds also be appreciated. I haven't messed with any of the dsp settings yet. Do I need to do something there to get sound? Photo attached.
Also the signal strength indicators don't even light up unless I turn the knobs all the way up and then they only show one tick of green, even with the AVR at +12. Any help would be appreciated.
audiosq is offline
post #2 of 7 Old 06-05-2019, 08:58 PM - Thread Starter
audiosq's Avatar
Quoted: 24 Post(s)
It's tough being ignorant.. figured it out.
audiosq is offline
post #3 of 7 Old 06-06-2019, 05:43 AM
jcmccorm's Avatar
Quoted: 597 Post(s)
Liked: 444
Ha! Nice. Care to share? We've probably all done it before (whatever it was). Might save someone else.
jcmccorm is offline
post #4 of 7 Old 06-06-2019, 09:26 AM
Kpilk's Avatar
Quoted: 63 Post(s)
Liked: 69
Yes...we must know the depths of this stupidity...so we can feel better about our's.
kaiforce likes this.
Kpilk is offline
post #5 of 7 Old 06-06-2019, 11:55 AM - Thread Starter
audiosq's Avatar
Quoted: 24 Post(s)
When I plugged in the Speakon cables I didn't know you had to turn them..
LTD02 likes this.
audiosq is offline
post #6 of 7 Old 06-06-2019, 12:11 PM
jcmccorm's Avatar
Quoted: 597 Post(s)
Liked: 444
Ah that's not so bad. I've never seen a Speakon connector before getting into DIY. The stuff most of us are familiar with, 1/4" TRS, RCA, XLR, etc. doesn't require a twist.
Glad you got it sorted out.
jcmccorm is offline
post #7 of 7 Old 06-06-2019, 03:25 PM
Red Five's Avatar
Quoted: 398 Post(s)
Liked: 448
The generic name makes more sense - twist and lock. At least it was a simple issue and not an RMA request
Stormbreaker | Wisconsin Home Theater Meet Thread | B.M.D. (in progress)
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | Yamaha A3070 | Crown XLS 1502 | iNuke 3000 DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Sub 21" Stormbreaker | Epson 5010e | 120" DIY AT Screen
Red Five is offline
